Welder advice
/ Welder advice #1
Mailman17
Georgia
2005 Mahindra 4110 TLB
I am thinking of buying a new welder. I have not welded before but what to learn. Not as a career but to learn so I can use when I need it. Any suggestions or questions are welcome .
Thanks for your help.
/ Welder advice
Sorry.... it will be for light or average work .
/ Welder advice #3
Have you though about which welding process you are interested in?
Stick, Mig, Tig, Oxy/fuel. And to help answer that question, think about the type and thickness of the metals you intend to weld. Also think about how much money you want to invest up front. I have a nice DC stick rig, it was cheap to buy, and consumables are cheap and easy. It does most of what I need. But your needs may be different. There are plus and minus points to each process. Professional welders will likely have equipment for all of the processes and choose based upon the job at hand. Welding is a subject you could spend a long time becoming an expert welder, or it could be something you just play with on the weekend, It all depends on how much time, money and effort you want to put in to it.
James K0UA
/ Welder advice #4
It has alot to do with how mouch you want to spend. I bought a used bus box for $100.00 an another 50 or so to run the 220 power supply. Mask an some rods a few clamps an chipper, gloves. I gess you'll lay out $250.00, before you draw your frist bead. If you can find a used one.
I did alot of work with it, Under a program with the VA I got a wire feed miller. ALL THE DIFFERENCE IN THE WORLD!!! It cost more but I can weld really good after just a little practice.An use it for up to 1/4" stuff.
Also youll need a 4 1/2" side grinder that's another $50.00, safety glasses:)
Go to Lowe's they have both their user friendly, price the stuff.
Army Grunt
/ Welder advice #5
My advice would to be if you know someone who has both stick and MIG welders to have them let you get the feel of them, before actually going buying one,;) You may even fine a seminar class to set in on, many years ago I made the mistake in buying a low amp MIG welder and struggled when using it, constantly making adjustments in effort to get a good weld, One day when taking something over to an actually welding shop to have weld it, I asked if I could try welding with the stick welder he was using, of course at first the rods would stick until he pointed out that I should make a sweep on the steel quickly dragging the stick to the welding point and then start making the weld, I then easily caught on and was welding better with the short time of using a stick than all the time I had been using the MIG welder,:cool: Now I prefer a sticker welder over a MIG;)
This is why I say as a beginner/ learner give it a try on each type then choose the one you can actually use best, otherwise choosing the wrong type welder can result in lost time learning on how to make a good weld,
I'll let the actual professionals here make recommendation on the name brand welder,
/ Welder advice #6
If I had never welded before and didn't have access to a welder to play with to learn the first thing I would do is sign up for a welding class somewhere close to where you are. There should be several to pick from but start out with the basics and don't get in a hurry and skip over some of the classes and go straight to a tig welding class from the start. They will likely start you off with gas welding so you get the idea of how different medals pool when heated and how the filler material relates to the finish product.
Welding is not as much about sticking two pieces of medal together as it is about knowing about the medal itself, thickness, how much heat to use, getting the medal prepared, and the type of medal you want to weld.
Personally, if I really wanted to learn how to weld I would definitely take a class or two. I would not go out and buy a wire feed welder to start off with because you would be cheating yourself and skipping over a real important part of the learning process. Also those el' cheapo' 115 wire feed machines everybody buys are a pain in the azz especially to learn on. No offense to anyone who has one of these machines as I also have one that has been sitting on a shelf for years because the cheap parts on the wire feeder broke after a short time and it cost more to fix it than it would to replace it with another piece of *##% just like it.
Another reason to go to one of the tech schools for a few classes to get the hang of it because welding with a good machine takes a lot of the guess work out of the picture and you can concentrate on the task at hand rather than a wondering weather the machine is doing what it is supposed to do or not.
I would look for a good Buzz box, one that has the capability to weld both AC and DC because you can't burn all rod types with just an AC machine. There are a lot of these machines out there to pick from and don't be afraid of picking up an older used machine because the older stuff was built really well and will last a long time. It's not a sin to weld with a buzz box and you can do a lot of work with one of these machines and they are a great tool to learn on.
Once you get the hang of it and know this process then move on to other welding processes if you like but welding is one hobby that should be taken rather seriously. Regardless of weather you are just welding something around the yard or for your neighbor it is likely that this weld could turn deadly if it failed at the wrong place or time. Also you have to understand what is going on during the welding process, really high heat, smoke, fumes, sparks, and that really bright light you and your family members and pets will be exposed to all need to be taken into consideration before you take to the task of welding up the lawn mower deck in the garage this weekend. Beware of the spark, these tiny little bits of burning medal will roll up under a counter and curl up with a lost and forgotten dust bunny and lay there for hours waiting for you to go in to the house so that they can do the nasty and ignite into a blazing fire that will burn off half the house before you know what happened. Don't ask me how I know this because it is kind of embarrassing to think about it now but the dangers of welding are real to both life and property.:thumbsup:
/ Welder advice #7
James K0UA
Can you give some clarrification on what type of welder is suited for different tasks. What type of system is better for general machinery repair of thicker metals, ie: 1/4" and thicker, etc.
/ Welder advice #8
1/4 " An up use a stick type.Thats your cheapest way out.
Army grunt
/ Welder advice #9
MM, looking at the equipment in your signature your going to want something that can weld 3/8's-1/2" ish thick steel.
I started(self taught) with a 90 amp 110v MIG welder. I build a couple of small items but the thing has very limited applications and they spatter everywhere. I moved up to a MillerMatic 210(210 amps) and it has done everything I have needed. I have run 5-6 spools of wire though it..great machine/many thickness options from sheet metal on up, and easy to learn on.
/ Welder advice #10
i would use a stick welder for a 1/4 or bigger,i like the miller acdc thunderbolt.it will work off of 50 amp breaker.sheet metal i would get a 110 mig i like the lincoln's 140 amp.a 220 mig is capable of heavier steel.oxy/fuel you really need for cutting and heating .i also use mine for brazing.
/ Welder advice #11
I'm still waiting on the process, and budget. I'm pretty good at spending my money, but I'm sure I'd be excellent at spending someone else's money!:laughing:
/ Welder advice #12
Stick. A good DC stick rig sounds like what you need. AC works too, but usually have to deal with more spatter and not quite as easy to make pretty welds for a beginner. Of course AC only units typically cost less than AC/DC rigs. I have an Everlast PA160 that does all I need. When we start talking brand names is when the fangs come out on a lot of the fellas, kinda like the old chevy ford, toyota debates that can go on forever. In my opinion there a lot of good welders out there made by all manufactures. My rig is up to 160 amps DC only with a 60% duty cycle. If your metal trends a little more towards the thicker end you might want to look at the PA200 in that same line. There are usually good used Miller and Lincoln units on Craigs list and e-bay as a lot of people give up on welding or just needed to weld something and dont want to hang on to the machine after the project is done. To sum up for general repair and farm machinery repair involving thicker material, Stick is the way to go in my opinion. Remember you will get a lot of opinions, and they are just that opinions. It is up to you to read a lot and sort them out.
James K0UA
/ Welder advice #13
I'd get a good AC/DC stick welder (mine is a Hobart LX Stickmate, 220VAC input power, $400 from Tractor Supply).
Then, if you plan to teach yourself, get the welding instructional videos (CDs) from Wall Mountain and study them while you get the hang of it.
Instructional Welding Videos
Start with easy to use rods: 1/8" 6013, 7014, 7024 before tackling the more difficult rods (6011, 7018). I generally use 1/8" 7014 drag rods, DC positive, 100-130 amps depending on the thickness of the work piece for most of my general purpose farm welding.
You're most essential tool is a good 4-1/2" angle grinder with grinding and cutoff wheels, which you'll need to prepare the joints (beveling, removing mill scale, general cleanup). You'll find that joint preparation is probably 75% of a good welding job.
You'll need a good helmet. Mine is an auto darkening unit from Northern Tool
Wel-Bilt Solar-Powered Auto-Darkening Welding Helmet | Welding Helmets | Northern Tool + Equipment
I wear tight fitting motorcycle type goggles under the helmet to keep stray UV light from getting to my eyes.
Global Vision Eyewear - Wholesale - Paragon Assortment
Figure you'll have to burn through a few hundred rods before you really get good at stick welding.
Good luck
/ Welder advice #14
Did you mean to say "pounds" of rod before you really get good at stick welding?
And to get really good it will be tons!:D
/ Welder advice
Thanks for all the advice so far.:D The thickest I would weld is 1/4" steel probably. I just figured I would get a mig because I've heard it's the easiest to use and learn(flux core). I already have angle grinder but would need to get the rest. I was thinking I would spend $300-$500 on all of it.The videos may be my first action to decide on exact welder.
/ Welder advice #16
If you want to weld 1/4" mild steel with fluxcore-SS you'll need a machine that is capable of running .045 wire, in the neighborhood of 200-amps, and 18 to 20 volts. I suggest Lincoln's NR-212.
/ Welder advice #17
You mean in a single pass right?
While a 220V machine can handle 1/4 inch easily, proper technique with even a cheap o MIG can technically handle the occasional 1/4" weld. I make the point because too many new weldors focus on max capacity even though they rarely use it. Kinda like HP with tractors. It just takes longer with smaller equipment.
I started to hobby weld a couple of years ago. So far oxyfuel and tig are my favorites because of the control they offer. Stick is the most challenging. Mig/fluxcore is technically the easiest to get started with but to this day I have trouble really seeing the puddle through the smoke. Mig/gas solves that but is more $ and limited field use.
My 2 cents: take an oxyfuel course first because it teaches the fundamentals and is slower and more controllable for a newbie. The other techniques have many advantages in practice (sometimes) but oxyfuel is the best way to start.
/ Welder advice #18
Yes I do.
Unless you're doing full penetration welds on 1/4 inch material, I don't see the need for multiple passes. Even then I'm sure I could carry enough iron to do it in a single pass.
Here is a full pen overhead weld with .045 NR 212 on 1/2 inch material, double 37 1/2 degree bevels.
/ Welder advice #19
Good advice....The thing that strikes me most about the OP's opening post was in the first 3 or 4 words, the desire to learn. There has been a lot of good advice passed along in this thread but it seems to me a lot of it is somewhat misdirected....This is my opinion only of-course and is not meant in a off handed way it is just an observation on my part.
If someone truly wants to learn a new trick you have to start out walking not running full blast. Where it is possible to learn to weld by just picking up the stinger and making contact with the medal you are working with but you are putting the cart in front of the horse and I guess you could train a horse could push a cart down the road but that would be mainly for show. If the OP truly wants to learn the art of welding he must first get the basics down pat and then take this information home with him and burn rods and or wire until you get the hang of it.
It really doesn't matter what process you use because any of the processes can handle 1/4 welds with ease with good equipment. The reason I would not opt out for a wire feed machine as the first choice is that they are easier to get results from and the user would tend to get lazy and not get the full picture of how the process works.
You could weld just about needed for around the house use with a good AC/DC stick welding machine and an acetylene torch setup. In fact you could just skip the welder altogether and gas weld the parts for most uses. True this takes time and in most cases is not cost effective but it would be nice to know for the time when the nice new inverter machine has blew out the control board and you have to make an emergency repair on something you need. It's always a good idea to be able to fall back on the basics in times of need than to try to learn them in an emergency situation.
With the budget the OP has stated he wants to stay in he will almost have to stay with the basics, $500.00 won't get you far when you are talking about wire feed machines that are able to make consistent welds on 1/4 inch or heavier material. You can spend $500.00 on safety gear and consumables alone, then you have all the other tools that are needed to do most common jobs and that's just the start. I don't want to make you shy away from wanting to learn to weld, I'm just pointing out it that welding can be an expensive hobby just like hunting and fishing or anything else you do to pass the time.
I can't stress enough the need for the proper safety equipment because just one bout with your, or a family members eyes being burned and the pain it causes is a bad way to learn. Not to mention skin cancer and breathing problems that can be added to the mix. You will learn about all these things and more and how to prevent them from a well trained staff instructor at a local tech center.
I know these things because I am a self taught welding amateur and have spent the nights awake with potato wedges taped to my eyes trying to find relief. Then several surgeries removing the bumps from my eyes that welding with cheap welding gear can bring. Then you add in the many trips back and forth from the doctors having skin cancers removed from my arms, legs, face, neck, and ears from not wearing the proper gear. I learned to be a pretty good welder but it came at a price and the sad thing is that it all could have been prevented. It's like cigarets you don't know what they are doing to you until it's too late.:D Well you do but these dangers need to be drilled into your mind so that you can teach your kids the wonderful art of welding the proper way.
2019 Cadillac Sayers and Scovill 70IN Limo w Only 7729 Miles (A63689)
2019 Cadillac...
PORTER CABLE AIR COMPRESSOR (A67714)
PORTER CABLE AIR...
More info coming soon. (A64557)
More info coming...
2015 Chevrolet Silverado 2500HD 4x4 Crew Cab Knapheide Service Truck (A68183)
2015 Chevrolet...
Heavy Duty Booster Cables (A64557)
Heavy Duty Booster...
2014 Jeep Grand Cherokee SUV (A66738)
2014 Jeep Grand...
