John Deere 2040 cuts off
   / John Deere 2040 cuts off #1
mikesells4u
My John Deere 2040 is not running smoothly and randomly cuts off for no appearant reason. The fuel tank is full and I have cleaned the bowl and priming pump beside the filter. Any suggestions?
   / John Deere 2040 cuts off #2
Check the strainer in the fuel tank above the tank shut off valve. Crud can clog it and limit fuel flow. Ifyou live in the SE, algae can be a real problem in diesel fuel tanks.
Look for kinked or damaged fuel lines and make sure the fitting are tight so you can't suck air in.
2013 FREIGHTLINER CASCADIA (A50854)
2013 FREIGHTLINER...
2019 TOYOTA 8FGCU25 PROPANE FORKLIFT (A51222)
2019 TOYOTA...
2017 UTILITY VS2RA 53FT REEFER TRAILER (A51222)
2017 UTILITY VS2RA...
1996 NEW HOLLAND 3930 WITH LOADER (A51243)
1996 NEW HOLLAND...
2013 John Deere 544K Articulated Wheel Loader (A50322)
2013 John Deere...
2019 JCB 457 ZX T4F Articulated Wheel Loader (A49461)
2019 JCB 457 ZX...
