John Deere 2040 cuts off
   / John Deere 2040 cuts off #1
mikesells4u
My John Deere 2040 is not running smoothly and randomly cuts off for no appearant reason. The fuel tank is full and I have cleaned the bowl and priming pump beside the filter. Any suggestions?
   / John Deere 2040 cuts off #2
Check the strainer in the fuel tank above the tank shut off valve. Crud can clog it and limit fuel flow. Ifyou live in the SE, algae can be a real problem in diesel fuel tanks.
Look for kinked or damaged fuel lines and make sure the fitting are tight so you can't suck air in.
2019 John Deere 6175M (A50120)
2019 John Deere...
CATERPILLAR VC60DSA SHOP FORKLIFT (A52472)
CATERPILLAR...
John Deere Gator Utility Cart (A50324)
John Deere Gator...
Wood Fence Posts (A50121)
Wood Fence Posts...
2025 Auto Darkening Welding Helmet (A50322)
2025 Auto...
2005 Toyota Tundra Limited Crew Cab Pickup Truck (A51692)
2005 Toyota Tundra...
