3-point not "floating" on 850
/ 3-point not "floating" on 850 #1
DieselSJ
Member
Deere 850
So I finally got all of the 3 point brackets to finish putting together my 850. I played with a blade over the weekend and it didn't seem to want to float at all. If a front tire went over a gopher mount it would cause the blade to dig in. I thought that putting the lever all the way forward was supposed to let the rear implements float? Any ideas?
/ 3-point not "floating" on 850 #3
If you lift on the arms, do they come up?
If you have a bucket, try lifting the nose off of the ground with the blade attached.
Aaron Z
/ 3-point not "floating" on 850 #4
From your description, it is very hard to figure out what you are expecting the "float" to do. If the front raises and the blade digs in, then it has to do with the weight of the blade and not whether in "float" (control lever all the way down). So am thinking you need to figure out more about what the 3 ph does, and how it is supposed to work so you can give us an idea what "float" means to you. ;)
We want to help.
I don't have a 850 but yes your 3pt should float up and down but some do not flex side to side.
The up and down is what I'm trying to figure out.
Aaron Z
I'll try pulling up on the arms. No bucket (yet) to test with.
We want to help.
Float basically means that it us just the weight of the implement itself on the ground, and the implement can move up over something if it needs to. In other words, it isn't locked into a position.
In my example, say I push my 3-point control all the way forward so the full weight of the implement is on the ground. I can pull across hard packed dirt and it will scrape almost nothing. Now if the front goes over a gopher mound and lifts the front of the tractor, it is like it is putting additional force on the blade because it causes it to dig into the ground. If it was "floating" then I would not expect anything more than the weight of the implement to do the work no matter what.
One of my neighbors suggested today that I try making my top link shorter, which will change the angle of the blade on the ground and may make it dig in less.
/ 3-point not "floating" on 850 #6
Thanks, now I have a better idea what you were expecting.
Put a short chain in place of the top link, and the front end then can raise without putting additional force on the rear blade.
It does take considerable force for the 3 ph attachment to cause the 3 ph arms to raise just from the way they work.
A longer chain will also allow the front wheels to drop in a depression without raising the rear blade.
/ 3-point not "floating" on 850 #7
Do you have several holes on the tractor to mount the top link to? If so try the lowest one.
larry
/ 3-point not "floating" on 850 #8
If you look at the lower holes to the 3 point lift arms there are two settings. There is a slot which allows the "float" to work. You turn the T type pins and plates verticle to float and horizontal to lock the lift arms. If you look at it it all makes sense.
I need to add a correction, The slots are only on the newer 850's about 1984 and up. I think the serial number break is 16000.
/ 3-point not "floating" on 850 #9
That is ONLY for floating from side to side (ie: letting the left side ride over a bump while the right side stays down). Most of the floating is done by the short arms on the rockshaft which lifr the arms in your picture.
Aaron Z
Thanks! I'll give that a try.
larry
I do - there are 5 different pin locations. I've got it in the highest...neighbor told me that I "always" wanted the upper and lower links to be parallel. I'll move it down and play with it.
Thanks guys!!
/ 3-point not "floating" on 850 #11
Your 3 pt does float, many of us wish we could have an option to prevent it or control down pressure but that is only available on much larger machines.
What I think you are experiencing is when your front end rises over the mounds it's making the blade angle more aggressive, that's why it's digging in.
You will need to manually adjust the blade height to compensate.
Rear blades are difficult to use and require some serious seat time to get efficient with, as you are now learning. Get a box blade they are much more forgiving and easier to use.
The only thing I do with my rear blade is clear snow from hard surfaces. The few times I tried doing dirt work I made a mess, put the box blade on and all was good.
JB.
/ 3-point not "floating" on 850 #12
Taking a quick stab here...It seems the reason the float is not good when the front of the tractor goes up and down is because the forces involved aren't just up and down on the lift links, which is what floats nicely. With an implement on and well behind the tractor, the top link comes into play. When raised it's in tension, when lowered it's in compression. When the front end goes over a bump, the top link is pushed backwards forcing the rotation of the implement. The lower links of the implement can float up in reaction, but they can't move foward which would be the primary reaction, thus significant downward force is applied when the front end goes over a bump.
/ 3-point not "floating" on 850 #13
Thats what Im thinking. A toplink in a low mount point on the tractor will be angled upward [or not down as much]. Put that link in compression and it wont fight float.
larry
/ 3-point not "floating" on 850 #14
You hit the nail on the head right there.
Your neighbor is incorrect in telling you that the TL and lower links need to be parallel ALL the time. What that does is make your implement raise more level. In the case of going over a bump, the blade actually needs to rotate instead of trying to be raised straight up.
Lower the TL position on the tractor. This will make it rotate more through out its travel. It will also allow it to be raised higher than before. Which may come in handy. Like when getting the tractor stuck crossing a little ditch and the blade diggs in and wont go high enough. Or when loading on a trailer.
2017 Freightliner M2 106 AWD Terex Hi-Ranger 5TC55 55ft. Insulated Material Handling Bucket Truck (A60460)
2017 Freightliner...
FLEX HEADER REEL FOR 20' HEAD (A63291)
FLEX HEADER REEL...
H&H 500 GALLON T/A SPRAYER (A63291)
H&H 500 GALLON T/A...
Rotary Brush Cutter Tractor Attachment (A61572)
Rotary Brush...
2026 SDLANCH IRGC40 Two-Seat Electric Tricycle (A64194)
2026 SDLANCH...
2008 Case IH 2152 Combine Header (A63688)
2008 Case IH 2152...
