What Bends/Breaks First :) Stump pushing or pulling...
/ What Bends/Breaks First :) Stump pushing or pulling... #41
heavy chain over a larger log is a great idea for pulling short stumps
and pull from the drawbar.
recoil is not really an issue with chain, but I'd still drape a HEAVY coat over the chain a few feet from the tractor
Go slow, and take several attempts at it to loosen. I usually roll the tractor into the pull with the clutch in. Stops you fast, but won't hammer the gears
I watched a guy who rolled into the chain, then back up and ram the stump with the drawbar, then roll into the chain again. took awhile but appeared to be low stress on the tractor
being jackpine, and only 12" diameter, the roots CAN get extensive, but not usually so. But I have seen stumps from blowdown well over 5ft diameter with a 12" dia stump
take it slow, use common sense
/ What Bends/Breaks First :) Stump pushing or pulling... #42
Best thing I've ever heard of is to use an old fire hose (doesn't have to be water tight) to sheath the chain or cable. Defintely reduces springback.
/ What Bends/Breaks First :) Stump pushing or pulling... #43
I once tried breaking the roots on a stump with a 3-point-mounted plow--not a subsoiler-- and quickly learned the importance of having the pulling point below the axle. Currently I'm removing stumps, most freshly cut but some old; maximum diameter 15"; mostly water oak and black cherry, but some live oak (tough!) and yellow pine. The tricky thing on yellow pine is a very strong taproot. I've been using a backhoe on a Massey-Ferguson 1635, and it's a good deal easier and more certain than trying to pull them. Doesn't take exceptionally long--most of the process is repeatedly tearing at the roots until they break. Longest I've spent was one hour for 2 water oaks, a cherry and a 4X4 all clustered together. I am working in sandy soil. Another option for cutting stubborn roots once the dirt is pretty much cleared away is to use a Sawzall with an aggressively-toothed blade.
/ What Bends/Breaks First :) Stump pushing or pulling... #44
It sounds like you want to do it yourself, but I've seen a mulching head on a tracked skid steer in action. It does a beautiful job incredibly fast. Afterwards, it will not be necessary to wad up and burn the stumps because they will be shredded into mulch. Burning can be a problem depending on location, burn bans (for example the state of Texas). Good luck with your project.
/ What Bends/Breaks First :) Stump pushing or pulling... #45
I removed this stump by digging, with a pick and shovel, all the way around and cutting off the roots with an axe. It took pulling with my truck and pushing with my B2320 to get the stump to where I could pressure wash off enough dirt and clay to flip the stump over and remove the rest of the dirt and clay. It was then easy to drag the stump the 200 yards to my stump pile with my tractor. BTW The stump is eastern hemlock about 30" in diameter.
/ What Bends/Breaks First :) Stump pushing or pulling... #46
THAT is a stump!
/ What Bends/Breaks First :) Stump pushing or pulling... #47
Thumbs on on that stump!..attaBoy!
/ What Bends/Breaks First :) Stump pushing or pulling... #48
Ouestion James, Would you mind describing the tool you refer to as a maul, that you have to sharpen from time to time..
Thanks, Cwadsgo ( Claude )
/ What Bends/Breaks First :) Stump pushing or pulling... #49
they say a picture is worth a thousand words, see the picture, but in case you cannot open the
document, think 8 pound sledgehammer with one end sharpened like an axe but not quite as sharp, usually used for splitting wood manually by hand the old fashioned way. Or google splitting maul
James K0UA
/ What Bends/Breaks First :) Stump pushing or pulling... #50
Thanks Roy...didn't think of that...I guess because I have never owned and/or operated a tractor :)
Just out of curiosity...how do you "link" the chain to the stump? Does this require part of the stump lifting so you can wrap under the stump?
Thanks...TMR
Here's how I removed some old stumps in my almond orchard with my 1964 Massey Ferguson 135 diesel (45 hp engine, 37 hp pto, ~33 hp drawbar). Those big rear tires are loaded with water for increased traction.
No way I could pull that stump without a lot of preliminary digging and cutting the horizontal roots with an ax or chain saw. Even with that preparation, I had to jerk it a few times to loosen it and then I could extract the stump with a continuous pull.
Be careful when pulling stumps with the drawbar. Search the Safety form on TBN for tractor flipping threads--there is a long recent thread on this subject.
/ What Bends/Breaks First :) Stump pushing or pulling... #51
That tractor's track looks wider than it's wheelbase! Must be nice on side hills.
/ What Bends/Breaks First :) Stump pushing or pulling... #52
The previous owner modified a 135 field tractor for use in his olive orchard. Replaced the 28" dia rear rims with 16" dia rims carrying Goodrich 6 ply 18.4-16A rubber (like you find on combines or self-propelled swathers) for high floatation and low squat to work under the tree branches (mowing, discing). The front axle spindles were shortened to keep the tractor level.
It would be a great tractor for mowing steep slopes with its low center of gravity--but my 10 acre place is flat pasture so I don't get to enjoy that experience:). But for folks with mowing jobs like that, this is an easy way to convert a tractor to do that work more safely.
/ What Bends/Breaks First :) Stump pushing or pulling... #53
wow I envy you people without the roots growing around boulders. Mine if the come out,usually have a few rocks to them and now and then Ill get a bolder..lol
/ What Bends/Breaks First :) Stump pushing or pulling... #54
I would suggest cutting the pine tree up about 18 -24 inches above the ground thensaw on top of stump across north and south ,but don't go completly across as the intended purpose os this is to make the stump hold water also saw east and west about 2 inches apart ;forget about the stump for three to four years then go kick it out with your foot. this works very good on cedar all you have to do with cedar is cut it off about two feet high and make sure there's no limbs left on stump come back 2-3 years and kick out ,if you cut it off at the ground the stump will be there 10-15 years . thanks holt50
/ What Bends/Breaks First :) Stump pushing or pulling... #55
everyone else pretty much has it, with just a generic tractor. but myself prefer a "backhoe" so much easier to just backup put the out riggers down. take a few swipes around each side of the stump to break roots. and if need be. move tractor around to another side, to break roots. and pop comes the tree stump.
i have gotten more skiddish over the years. with chains, cables, and ropes. and recoiling back at me. they can and do snap back at you. and at bare min, when i am in gear, i will refuse to drive straight in line with cable or chain. but will always drive off at an angle. so if something does snap or come loose. it will more likely wip dangerously pass me. vs directly into my back or head killing me.
if you have enough stumps, i would say just rent a backhoe or excavator. and be done with it. quicker and easier.
if you were only dealing with a couple stumps. ok, using a subsoiler to help cut through roots around the tree. and then using a chain to pull stump out. i would give it a go. but there is a point between time spent and hassles and headaches. vs just getting it done. there are multi ways of doing things. no wrong or right way, though sometimes having the right tool for the job makes a night and day difference. and like many folks another trip to hardware store or like.
in your case, if buying a tractor, i would encourage a backhoe. if backhoe is out of price range, then rent a backhoe or excavator. open the old paper phone book (internet yellow pages for me are a joke) and look up "equipment rental" or machine rental, or something like that in the phone book, call around even up to 1 to 2 hours away driving distance. and get prices for renting from daily to weekly. price can be HUGE even if rental place brings it out to you and picks it back up even a 2 hour drive for them. could be chump change compared to actual rental costs.
personally. now having the TLB (tractor loader backhoe) i could not live without the backhoe. comes in very handy, granted it is a costly little item. besides cost of tracker and front end loader. but money well spent. from digging a hole to plant a tree, to a couple swipes to redo a flower bed, / moving a flower beds. to lifting some things in and out of a truck. to post pulling, culverts, etc..
as far as front end loader. you can bind them up. and twist the arms. and damage a general duty bucket. and you normally need to pay extra for a heavy duty bucket for the loader, then pay extra for a good either cutting edge or tooth edge on front edge of bucket, then like many folks, putting some hooks and re-enforcement on the front bucket. so you have a place to hook chains to. the end loader, are not the best things to use like others have said for stumps. granted i have put them through the riggers of death. but others doing same thing have had very costly repairs.
/ What Bends/Breaks First :) Stump pushing or pulling... #56
With 10+ year old stumps, a small tractor might make easy work of the pine stumps.
I've got a lot of 1-5 year old pine, oak and cedar stumps and they cause more jolts to the tractor and me when trying to work them out than I care for. My bent up front bumper, smashed hood and bent bucket will testify to that.
Take your boot and an axe to a few of them. If they are still stout, you'll tear up your tractor. If they are something that just seem to be a little too much work for hand work, the tractor will be fine for 100+ or so of them.
Some old guy once said you could knock a few holes near a stump and push corn down them.. the wild hogs will come and dig for the corn and in the process work the stumps loose. I'm guessing the old guy was FOS but he may have a point. I don't mind letting the wild hogs do something.. they roam through here already. A few of them getting smoked makes tasty eats too.
-Luke
-Luke
/ What Bends/Breaks First :) Stump pushing or pulling... #57
<snip>
-Luke
-Luke
Someone told me a similar story - said when his father had a stump to remove he used to put a fence around it, throw some corn in the holes and put one of their farm hogs in the pen. He said they didn't remove the stump, but they did a fair job of exposing all the roots, making removal much easier. He also told me that to keep them from digging under their regular pen they'd throw in a bowling ball and they'd spend all day digging around that instead.
Smoked does sound tasty!
/ What Bends/Breaks First :) Stump pushing or pulling... #58
One better than that is a rope threaded through a chain link every foot or two.
Use the heftiest rope you can thread through and have a few feet extra slack at each end. Tie off one end to the tractor, the other end to the load, not to the chain itself.
Oh yeah, if the chain breaks DO stop the tractor before the rope goes tight (-:
The rope is in no way a back-up for a broken chain.
/ What Bends/Breaks First :) Stump pushing or pulling... #60
I can't seem to do that. The tractor or truck will slide the front or rear sideways until it is a straight in-line pull, unless the load is light enough I don't worry about a break anyway.
Bruce
a chain is as strong as the weakess link in it. other words. keep the chain short as possible. chain / rope / cable for that matter.
i understand about rear or front end sliding sideways. but that is what i do on purpose (causing the sliding some). so if the chain / cable / rope does break. and if it does come flipping back at me. my body will not be in direct line of the snap. (well hopefully anyway)
and with above, i have had more close calls than i care to admit with breaks and snapping back at me. and just being that 1 inch to 2 feet off center between what ever, the chain and rear end of truck or tow bar of tractor has saved me by just driving at an angle and letting things slide some, and if i get to straight in line, i will back up some, then drive back at an angle to keep my body off center.
when you see that chain / cable / rope sling past your head and missing you barely. a few times like i have, ya start thinking.... hmmmmsss is there a better way of doing this?
Caterpillar Tractor-Scraper Service Manuals (A63117)
Caterpillar...
2020 FREIGHTLINER CASCADIA 116 6X4 T/A SLEEPER TRUCK TRACTOR (A59912)
2020 FREIGHTLINER...
2007 DRAGON 130BBL VAC TRAILER (A60736)
2007 DRAGON 130BBL...
2001 KENWORTH W900 72" STUDIO SLEEPER (A62613)
2001 KENWORTH W900...
KUBOTA SVL97-2 SKID STEER (A64279)
KUBOTA SVL97-2...
Kubota V3600-T-E2 Turbo Diesel Engine - 3.6L - 84 HP - 2018 - Tier 2 - Pump Takeout (A63689)
Kubota V3600-T-E2...
