How to read a Span Table???
/ How to read a Span Table???
Just on the ground before you start adding your 2x6's and after your concrete has set up for a day, might even want to toss a few mothballs on the plastic before the floor goes down as well, as a critter deterrent. Low height buildings have been known as hangouts for mice etc...the same ones that eat electrical wires on shiny motorcycles in winter. You also want to seam seal every gap in the wood, do this by placing a work light in the structure at night before you do any siding, seal up any area you can see light coming thru, in the long run you will be glad you did this.
Fix,
Are you saying I should make my own footers? Poured concrete into some kind of frame to be a footer?
I was thinking the pre cast ones...
An idea is gelling, but I gotta go get ready for Church...
More later...
David
/ How to read a Span Table??? #22
LD1,
#1 I suspect my lumber costs are higher than you are quoting (that is not helping my case;))
#2 - I believe I need to excavate approx 6' to do what you suggest. Lay down 4" of gravel, build a frame for the concrete pad that is 4" tall (not 3 1/2" like a 2x4 is). Then I need some kind of rebar etc. (something wire?) inside the pad space. Then I can pour, smooth, and cure. I end up with a NICE:thumbsup: patio. How do I attach the wood for the shed?
#3 - see pic.
#4 - I currently have a non-level pad in th carport, complete with a giant crack and a low spot that becomes my 4th pond every time it rains... I do not want to repeat that on this shed.
Also keep in mind "No Permit"...
#5 - One bag of crete each post should do, but I'm giving up on that idea...
David
Rebar or metal screening is not needed...there is concrete with fiber in it now that is great. I used rebar for height markers. Pound them in the ground to know where the concrete will fill up too. ( I have a laser level if you want to borrow it, sister in-law lives in Ladysmith so we are over that way once in a while, we live in Spotsy).
I did a garage some time ago and had all the leveling and gravel work done. then paid a group of guys to come in a pour the concrete. It cost me $150 for labor, money well spent. I supplied the concrete.
One thing with concrete floors is to make sure you do not disturb the soil below where the concrete will be poured. Remove only what is necessary when leveling ground. Maker sure you put some kind of pitch from back to front so water will drain out if you happen to get any in the shed.
Attaching wood to the concrete can be done either with anchor bolts or anchor straps. They get set in the concrete during the pour. I went a little over kill on the straps and put them every 12 or 16 inches can't remember now. The straps will lay flat and fold around the outside of the bottom board and nail in the top. Bolts come up through the middle of the sill plate and have a washer and nut to hold down the wall.
/ How to read a Span Table??? #23
LD1,
[/qoute]
If it were mine, I would build it like a pole barn.
Dig your holes for the 4x4 posts. These need to be long enough to go in the ground ~3' and stick above ground the height you want your walls to be. Then attach "band boards" as they are called. Usually 2x6 PT toungue and groove around the base. THAT now becomes your form for the concrete floor.
And if you want, you can just go ahead and build the building NOW, and pour the concrete whenever you want.
Just a mini-pole barn is all it needs to be. And probabally the sturdiest and cheapest method of construction for what you want.
/ How to read a Span Table??? #24
LD1,
[/qoute]
I actually just got back from looking at a guys pole barn he is building. I like that method. I may have to do it that way for my covered storage. His building is 42' by 120' with what looks like 20' tall ceilings. Very nice pole barn. I don't think I need that big but it would be nice. I need one for tractor, trailer, boat, trailer and dirtbikes and gocart. I might be able to fit that in a 42' by 120'. Just need to convince the boss to release the funds:licking:
/ How to read a Span Table??? #25
Red Horse,
I was not planning to permit.
I'm not sure I see how 4 chunks of 4" thick concrete canbe MORE stable that a 4x4 2 feet deep in a hole filled with concrete, and the 2x6 sitting ontop of the 4x4 (doubled 2x6's on the outside and a couple more in the middle). See pic. I was thinking about all 4 corners, plus the 4 centers of each side and then maybe 3 along the centerline down the 20' direction.
I can envision how to level and cut off all the 4x4's, but I do not know how to do what you describe as "get a good straight 2 x 6 as your straitedge, (assuming you don't have a transit) and just set your first block to height that suits you and level off to the others from there. Then just mark your end rim joists at 12" and start pounding nails."
David
Dave, Take a deep breath. Its not difficult. Also what CrazyAl has suggested is the same as me- except I'm saying you just set on SOLID 4" x 8" x 16" blocks. Trust me, I would trust a 12 x 20 platform resting on 4" or 8" of solid block, long before I would a spindly 4 x 4. Plus, it is not good practice to bury the 4 x 4's (if you must use them) IN the concrete. If you want 4 x 4,s, you pouir the sonotubes, place a hold dowen bolt in the middle, and then use one of many gaqlvanized products that are available to attach PT to concrete footings/piers.
As we speak, I am building a 10 x 12 precut post and beam shed that I bought from Pine Harbor. Its2 x 6, on 16' centers and its resting on 4" block- three piers on each of the 20' length. Only thing I'm deviating from is I bought an extra 2 x 6 and I am cutting bridging blocks to run down the middle (the 6' line). Solid bridging does an amazing job of making a deck structure a lot more rigid. It takes all the "bounce" out of it.
I also second CrazyAls comment on Advantech. I paid a 120 buck premium in the kit over plywood (comes out to a buck a sq. ft or 32 a sheet). It looks like crap particle board but it supposedly does the job-that WILL be the finish floor.
I'm goofing off right now having lunch and waiting for the start of the race at Dover (Go Blue Ovals!!) but I will try to get some pix this afternoon.
LD1,
That is an interesting idea... I would need to us minimum of 12' 4x4's if I had 3' in the ground (In concrete?), 8' ceilings inside, plus whatever roof I could get... Hmmm...
How many poles would I need. I've not seen 2x6 tongue & groove yet...
I'm getting SO MANY different ideas I m having a hard time keeping them all straight.
David
Istinhot,
HOWDY neighbor! We have a rental near Lake Anna (off 208, not on water) and another big house rental in Fredericksburg. We've been Spotsy residents for the last 7 years. Now we are Caoline Co. folks.
Thank You! you just reminded me I have a laser level somewhere in the basement! :thumbsup:
It is also nice to know we have "added fiber" concrete options. :D
You want to come over and play construction guy with me?:laughing:
David
Red Horse and CrazyAl,
I want to make sure I am hearing you guys correctly. Are you suggesting I go get precast deck footings and just scrape away the top soil and set them on the clay?
This would be WONDERFUL and easy except for what about Frost? I've been told I need to go down 18" to pass the frost line...
David
/ How to read a Span Table??? #29
LD1,
David
Typically they are spaced 8' appart. On your 12' direction, you could get by with 6, but still use 12' lumber all the way across.
On the 20, for what it is, you could porbabally stretch the span to 10' without any issues, But I would consider making it a 24' building w/ posts on 8' centers.
8' lumber is the cheapest per foot. So any time you can build in increments of 8', the better.
2" x 6" x 8' #2 & Better Tongue & Groove Pressure Treated at Menards
So I have learned that a 200 square foot shed does NOT need a permit.
So in order to be legal I will try to do this within 200 square feet! Something like 12' 4" x 16' 4" it seems... I am digging into the building codes to get clarity...
David
How do I interpret this...
General. All exterior walls shall be supported on continuous solid or fully grouted masonry or concrete footings, wood foundations, or other approved structural systems which shall be of sufficient design to accommodate all loads according to Section R301 and to transmit the resulting loads to the soil within the limitations as determined from the character of the soil.
Footings shall be supported on undisturbed natural soils or engineered fill.
Exception: One-story detached accessory structures used as tool and storage sheds, playhouses and similar uses, not exceeding 256 square feet of building area, provided all of the following conditions are met:
1. The building eave height is 10 feet or less.
2. The maximum height from the finished floor level to grade does not exceed 18 inches.
3. The supporting structural elements in direct contact with the ground shall be placed level on firm soil and when such elements are wood they shall be approved pressure preservative treated suitable for ground contact use.
4. The structure is anchored to withstand wind loads as required by this code.
5. The structure shall be of light-frame construction whose vertical and horizontal structural elements are primarily formed by a system of repetitive wood or light gauge steel framing members, with walls and roof of light weight material, not slate, tile, brick or masonry.
/ How to read a Span Table??? #32
Pretty simple actually...
You are allowed to build up to 256 sq ft building pretty much by whatever means you want without having to do it on a foundation or other "approved" method. Which I am pretty sure post-frame construction is an approved method. Or do all the barns on the farms in your area have a concrete/block foundation?
Pretty simple.
You dont want that anyway right?
Dont build on a mountain side and use PT for exterior lumber
Look up the code for your area. But I am pretty sure that a post-frame with posts anchored into the ground will be within code
A post frame meets all of these requirements. IE; light construction, repetitive wood, etc. Just dont use a slate, tile, brick, or masonry for siding or roofing.
Vinyl, shingles, and metal all fall into the "light" category:thumbsup:
/ How to read a Span Table??? #33
David
Correct-You are not concerned about the frost issue as you are not putting anything IN the ground-therefore nothing to heave! Think of the shed as just floating on the ground. Does your whole yard "swell up" in the winter? No.
Case in point. We just placed a 28 x 52 double wide at our fairbgrounds. Now we can have 3 feet of frost easily if we don't get enough early snow cover. This thing sits on a level pad about 4-6inches of compacted asphalt millings and rests on dry block piers which sit on 2 x 2 HDPE pads for better weight distribution. To comply with state building code, it is secured to ground with steel strapping that connects to one inch steel rods driven about 3' into the ground at opposed 45 degree angles. This is to keep the wind from lifting the building.
Bottom line, no footings, no ground penetrations other than the rods that keep the building secure in the event of high winds.
LD1,
I agree, I thought it sou nded pretty simple also.
What is "Post Frame"?
If I am floating on piers, how do I anchor it against the wind?
Thanks,
David
How many of the prefab concrete footings/piers should I use? (I assume these are just like deck footing/piers
Can you send pics of how you attached the dblwide to the "anti-wind" rods etc.?
Be well,
David
/ How to read a Span Table??? #36
Here are pix of what I did today. this is a 10 x 12 saltbox roof storage shed.
/ How to read a Span Table??? #37
LD1,
Thanks,
David
Post frame is just another name for pole barn.
I just checked the building codes for VA and "post frame" and "Pole barn" are not in it.Pole is only mentioned one time, for utility poles.
I assume that means ANYTHING GOES!!! :D
David
I am going to start a new thread later today on my actual plans and get some feedback from TBN.:thumbsup:
Here is a rough outline 200 square foot shed needs no permit. I can easily fit all 4 Harleyç—´ in a 10 x 20 as long as I have a 10 door centered on the 20 side (I can get any one I want out for riding without moving the others). I am planning to æ“¢loat the shed on prefab concrete footings like used in building decks.
Right now I have a couple specific questions
1 Do I need to remove the topsoil? If yes, how deep do I go? Do I need gravel?
1a When removing topsoil, I assume I use the FEL bucket (take off toothbar) and then just back drag the topsoil off? Or do I use the cutting edge and scoop it out (gently and only down a couple inches)?
2 How many footings? (I was thinking 5 each on the 20 side, and a couple on each 10 side).
3 How do I level either the footing or the PT foundation? Gravel under the footings? Shims? Scrape soil out from under the footing?
4 Where do I put the moisture barrier? Under the footings is my bet.
5 Do I need a central span to support the (PT 2x6 should EASILY span 10 or less, right?).
6 Do the 20 sides need to be a single 2x8? Or can I use two 10 boards? Is there any advantage/disadvantage to miter cutting the ends for a flush fit in the corners?
7 Can I put Tyvek or similar UNDER the ï½¾ plywood as a barrier, do I need PT plywood for the floor? I am considering that fancy Advantech flooring. My goal is to keep moisture and critters OUT of the shed. I was planning to also use liquid nails atop the joists to glue the flooring (and nail it also of course) to prevent squeaks and creaks & increase rigidity
What am I forgetting?:confused2:
Thanks in advance,
David
/ How to read a Span Table??? #40
I would also suggest to check the zoning code on the number of "accessory" buildings you are allowed--sometimes it is only 2!
2018 Chevrolet Equinox AWD SUV (A61569)
2018 Chevrolet...
UNUSED KJ 20'X12' LIVESTOCK METAL SHED (A62131)
UNUSED KJ 20'X12'...
2012 VOLVO DBL SLEEPER ROAD TRACTOR (A62130)
2012 VOLVO DBL...
KUBOTA L353 FRT LOADER ATTACHMENT (A62130)
KUBOTA L353 FRT...
Pallet of Fork and Frame Mini Skid Steer Attachment (A61567)
Pallet of Fork and...
2017 Freightliner M2 106 AWD Terex Hi-Ranger 5TC-55 55ft Insulated Material Handling Bucket Truck (A60460)
2017 Freightliner...
