3000 SERIES FENDERS
/ 3000 SERIES FENDERS #1
glc24
Southwestern, Pa.
Hey all
I'm thinking of trying to kitbash the front fenders for the 3000 series onto my 2520. Bare tires sure make a muddy mess of the tractor,not to mention the wet grass piling up on the MMM.
I was considering using a utility trailer fender which I still may do,but I'd rather use genuine JD,if the mod wouldn't be too involved. The 3320 uses a 25-8.50 x14,while the 2520 uses a 23-8.50 x12 for R4's. Hopefully,the fender would still look decent over a 12" wheel.
I would appreciate anyone with a 3320 willing to post a few pics of their fronts with the fenders.Especially how they are attached. I looked on JD parts,and there seems to be quite a few pieces to the brackets.
Any comments or suggestions would be appreciated.:)
Greg
/ 3000 SERIES FENDERS #2
This would be interesting to see....Although I have not seen many front fender kits on here.
/ 3000 SERIES FENDERS #3
We have a set of front fenders for our 4520. I know the brackets that bolt down to the axle have to be the perfect size because they do a partial wrap around the top and bottom of the axle so they fit snug with no play. You could probably get by with some fabrication though.
/ 3000 SERIES FENDERS #4
I'm not even sure if front fenders are an option in the US or North American market. Pretty common in Europe though...
/ 3000 SERIES FENDERS #5
Yes, they are a option in the US, code LVB25686 and sells for about +/- $400.00
/ 3000 SERIES FENDERS #7
Looks exactly like the front fenders on my 3720 except I replaced the 9A and 10A parts with bolt and nut to provide a good tight fit (eliminate wobble).
/ 3000 SERIES FENDERS #8
Pictures please:thumbsup:
/ 3000 SERIES FENDERS #9
glc24 said:
Hey all
Greg
Nice idea. I am interested in your mod.
I should have known better,than to think they would be reasonably priced!:mad:
If I just got the plastic fender and nothing else,they would run me 130 beaners!
I think I will look into using the utility trailer fenders.I've already Googled them and they can be had in plastic. Quite a bit cheaper too.:)
I don't know what the fender mount on the front axle of a 3000 series looks like,but I'm guessin' it will be like comparing day and night as far as what a 2520 mount will end up looking like. I'm confident that it still can be done.
Greg
/ 3000 SERIES FENDERS #11
Hey all
I'm thinking of trying to kitbash the front fenders for the 3000 series onto my 2520. Bare tires sure make a muddy mess of the tractor,not to mention the wet grass piling up on the MMM.:)
Greg
Had a 3320 O/S with MMM - no fenders. Now 3320 CAB with fenders. Can't say I notice any appreciable difference in the amount of grass on the MMM after a cut. I actually removed the two plastic spindle covers and at least it's easier to remove the grass. Have not had much experience with mud on either so no comment.
/ 3000 SERIES FENDERS #12
Greg
The one thing you probably already thought off is MMM clearance. I know the X-series fenders would pivot with the wheel do the 3000 series pivot or are they stationary. The 3000 fenders used to say they were not compatible with mid mowers and that must have changed.
Yeah,PCABE it will be close.Maybe too close. If so,I'll only use them when I do other (dirty) work,but I want fenders.:) I want them to pivot with the wheels too. If that can't be accomplished,I figure what is the point then.:(
Greg
PCABE thanks for posting those pics.
That is what I don't want.The fender is too far away from the tire,but has to be that way so it clears the turning radius. I want the fender to rotate with the tire,that way it will be much closer to the tire. Hopefully I can find something (fender) with the same radius and width as my tire.
Does anyone know if the steering arm,part #1 is weldable? If not, I'm sure it can be drilled and tapped.
Greg
/ 3000 SERIES FENDERS #16
Greg
Don't know for sure, but by the shape of it I suspect it's cast, it would be better to drill/tap it IMO.
