wooden bridge beam size
/ wooden bridge beam size #1
jonsstihl
Quebec, Canada
I need to replace a bridge on my property span is 10 feet tractor is b7800 with loader to aprox. 2800lbs and capacity for another 800 in bucket so say 3800 lbs load with operator
is an 8" X 8" hemlock beam going to do the job.
I found a formula that had this constant for hemlock set at 76
W X H squared X constant
________________________
span
so 8 X 64 X 76 divided by ten gives me 3891.2 Lbs
does this make sense.
thanks
/ wooden bridge beam size #2
What's the bridge design? Do you have two beams or four? What's the surface? How is the tire load spread onto the beams?
I'd be more concerned about hemlock rotting away than about its strength. If the ends are on stone or on conrete, might last a few years, if you keep the dirt away. Got a drawing?
How about PT? If you need it stronger, put more beams in.
Jim
/ wooden bridge beam size #3
By my tables (assuming 1000 psi) an 8x8 nominal beam, 10 feet long, is rated for 4690 lbs. However, I don't know how you would build a bridge with a single beam.
I'm planning a similar bridge. I will use two beams under the approximate vehicle tracks each made of 2 treated 2x10s, sandwiched with a layer of plywood. Each of these nominal 4 x 10 beams (at 10 foot length) will have a capacity of 3640 lbs. I will probably add a center beam, perhaps a single 2 x 10. This should give me a total safe load of about 9000 lbs, meaning I can drive my truck over it if I need to.
If you add up the costs of 5 treated 2x10s and a little plywood, that's a pretty cheap bridge structure. Your bridge deck and foundations will cost a lot more. What I'm saying is, overbuild the substructure - it doesn't cost much.
/ wooden bridge beam size #4
span
thanks
My calculations are comming up about right in the middle. But there is more than one way to calculate it, and more than one type of stress involved as well.
The formula I used is (w*d^2)/(9*L) x (k/f)
Where:
w=width of bean in inches
d=depth of beam in inches
L= length of span in feet
(k/f)=same modulus of rupture for hemlock, which is 750
So...(8x8^2)/(9x10) X 750=4266lbs
And that is just a basic point load calculation for a load supported in the middle of the beam. Obviously the tractor isnt going to have ALL its weight at the point at the same time. Simce the load will be distributed a little, that will help.
And I also assume you use 2 beams, so it should handle the tractor fine.
But as others have pointed out, wood deterioriates over time. This will reduce the load bearing capacity. I would look at a GOOD PT beam, or even steel. A couple of steel beams 10' long to support that weight isnt going to cost that much. Maybe $300 at most. And would give added peice of mind. I dont like wood bridges.
Sorry about that I guess the obvious stuff is not so obvious when you look at it from another point of view.
The current bridge is two logs half circle in cross section maybe six inches thick with 2X6 decking . it works but one of the logs is broken so I get a lot of deflection when driving over it. luckily the bridge is not high off the stream bed and I think it is bottoming on a rock.
the new bridge will be two beams the appropriate width apart for the track of my tractor and I was thinking of trying to position a rock half way through the span to limit the deflection . the end supports will be those small cement blocks they use in parking lots aprox. 6" X 9" X 72" long. the decking will be 2x6
I was led to believe hemlock was fairly rot resistant.
I completely forgot that there are two beams there so the load is not as borderline as I thought.
thanks
/ wooden bridge beam size #6
All the other TBN members had sound advice. I built a bridge 32 feet long, 14 foot wide 6 years ago- still standing strong over the creek. I used a mobile home frame with pressure treated 6x6's spaced every three feet and covered with 1-one inch marine plywood with 1x2's on top of the plywood to prevent sliding somewhat. I finished the sides with 2x8's to provide a minute safety feature, but the psychological effect is huge. You may derive some ideas from our posts but the ending decision is yours. It depends on how long the structure is expected to last, amount of construction time, and last but not least how much money you have available. Good Luck.:):tractor: By the way,I used lumber that a neighbor of mine had left over from his barn building. This helped in keeping the cost down. The 14x70 mobile home frame cost me $50.00 plus my time transporting it.
/ wooden bridge beam size #7
I recommend leaving a generous gap between your deck boards. Makes it easier to clean out between the boards and keep them from rotting. Also if you put runners the length to drive on, it spreads the load across more than one deck board.:thumbsup:
/ wooden bridge beam size #8
Man, we ought to all get together and build something (like my bridge :laughing:). I got my numbers from Marks Handbook for Mechanical Engineers, the 1967 edition (shows how far I go back.) The trailer frame is a great idea if you can find one. If you are looking at timbers, keep in mind that height contributes more than width. A 5 x 10 beam is stronger than an 8 x 8. A 3 x 12 is almost as strong as an 8 x 8. You only need enough width to keep the beam from buckling or twisting. I still think treated is the way to go. Under a bridge deck it will last almost forever.
/ wooden bridge beam size #9
Not quite.
You are correct that height contributes more than width. But an 8x8 is still a tad stronger than a 5x10. At least in all the tables I looked at and in the formula I used.
And it is significantly stronger than a 3x12.
IF we isolate JUST the beam in the formula I provided, taking out the specif type of wood species and its properties, and the length of the span:
the first part of the formula is JUST based on beam size. W x D^2 (width times depth squared)
So JUST that variable gives an 8x8 beam a # of 512. A 5x10 is 500. And a 3x12 is only 432. And the span tables I looked at confirmed this as well. So basically, an 8x8 is 3% stronger than a 5x10 and 19% stronger than a 3x12.:thumbsup:
So when rough guessing on beam sizing and what is stronger than what, just remember....depth squared times width. Pretty accurate for comparing beams of different widths:thumbsup:
And I do agree that PT would be the way to go. Unless you decide on steel.
/ wooden bridge beam size #10
I know this much: a square beam will sag quite a bit, even under just its own weight.
I hope it's different from our western hemlock. That stuff is highly prone to rot. However, it takes wood preservative better than most woods, as it is like a sponge. Western hemlock is the hardest firewood to dry out, and the quickest to get wet again. It is extremely popular for pressure treated, ground contact, lumber (great for that). But untreated, it makes compost in a hurry.
/ wooden bridge beam size #11
NOT TRUE.
The figures I was comming up with, with a point load of ~4200lbs in the middle, that was all using L/240 deflection.
In short, what that means is the 4200lb load centered over a 10' span with an 8x8 hemlock beam will only deflect (sag) the beam 1/2".
And I have a 6x6 beam over a kids playset spanning 12', and it doesnt even sag under its own weight.
/ wooden bridge beam size #12
NOT TRUE.
Also note that just because it is square, doesnt make it sag more.
The depth determins "sag under its own weight". NOT width. So what I am saying is, an 8x8 isnt going to sag anymore than a 2x8, 3x8, 4x8, or 6x8 of the same species spanning the same distance. Becasue comparing a 4x8 and 8x8, sure the 8x8 doubles the weight, but it doubles the strength too.
Think about it this way, you have a 2x4 spanning a given distance. It sags some under its own weight. You put another 2x4 Right beside it and laminate it to the existing 2x4. Thus making a roughly square beam of 3.5" or so. Does that magically make it sag anymore????
/ wooden bridge beam size #14
Divide the span in 1/2,Simply support a 4x4 pt an set it in a cutoff 55 gal barrel in the stream bed.You need to rember the day the hem hits the ground it starts rotting, or gets eaten by bugs. set it on a pt. pad.
Army Grunt
/ wooden bridge beam size #15
I still vote to go steel. It may actually be cheaper than the hemlock.
Without having a chance to throw some #'s at it, so I am only guessing at the moment, but a steel beam in the 15lb per foot range sould suffice.
That is only 300lbs of steel beam. (steal is usually priced by the lb)
And beam is usually 0.50-0.70 per lb. So you are only looking @ $150-$200 to have a steel bridge.
I may run some actual #'s when I get a chance
/ wooden bridge beam size #16
I had a similar dilemma with a 12' span, we simply searched out some railroad switch ties and took four of them and used threaded rod to bolt them together, creating two heavy side beams. We decked it with cutoffs/rejects from construction jobs and I have crossed it several times with machines weighing in excess of 17,000lbs. Total cost was time and about $50 in threaded rod.
/ wooden bridge beam size #17
I had some time to run some deflection #'s.
The formula for steel I-beam deflection is
d=(F x S^3)/(48EI)
Where:
d=deflection in inches
F=Force applied in pounds
S=span in inches
48=constant
E= modulus of elasticity (for steel, this is 30,000,000psi)
I=Moment of inertia (I^4). Can be found online and is different for every beam.
Deflection limits for i-beams sould use L/360. So a span of 120"/360 would give you an allowable deflection of .333"
So reverse figuring to solve for I we get the following(assuming 4300lb point load becasue that is how strong you 8x8 woudl be):
(4800 x 120^3)/(48 x 30,000,000 x I)=0.333
5.76/I=0.333
result, I>17.28 (I must be greater than or equal to 17.28 to have the same strength of the 8x8 hemlock).
So now we can look at some beam charts to do some shopping:thumbsup:
I like this website for that Structural Steel W Flange Section Properties Moment of Inertia, Steel Beam Size,Cross Section Area - Engineers Edge
So it looks like a W8x10 beam is the lightest beam that would meet the criteria with an I4 in the xx axis of 30.8 That is a 8" beam that weighs 10lb per foot. So only 200lbs of steel:thumbsup: Probabally will only cost you $150 at the most. And with the I4@30.8, would actually hold a point load in the middle of over 8500lbs. So a good bit of saftery factor as well.
BTW, how much are these 8x8 hemlock beams going to cost you???
sorry haven't had much time lately but thanks for all the input
the beams are 36 dollars each so they are significantly cheaper than steel.
The real issue is time. I only have one more week off work so this needs to come together quickly.
I'm planning on making concrete bases similar to the blocks in parking lots. to set the beams on and then building up gravel ramps to match the deck height.
I just need to figure out the appropriate track.
I agree that steel would be a better long term solution but more $$ and more complicated to attach a wooden deck to the steel beam.
/ wooden bridge beam size #19
d=(F x S^3)/(48EI)
Where:
S=span in inches
48=constant
5.76/I=0.333
DAYUM! I learn SO MUCH on TBN... :thumbsup::thumbsup:
I've been lurking in this thread because probably next summer I need to build a tractor/horse bridge over a small stream that only runs ~11 months of the year and feeds the branch which is my northern property boundary.
I had no idea I could get steel by the lb like that, and no idea how to estimate the right size etc....
You TBN fellers ROCK, and LD1 you are one smart hombre!
Good to have you on my side!
Be well,
David
/ wooden bridge beam size #20
Be well,
David
Well, I am unsure what you mean by "get steel by the lb like that"
You can get steel however you want. Typical lengths, like 20' may be a little cheaper than shorter parts because the supplier doesnt have to cut it, which may add to the cost.
But I dont think they will actually tell you a price per/lb. They will usually quote you by the foot for a given beam + whatever cut fee.
But I assure you, the root of the price is based on weight. And it is usually in the 0.50-0.70 per lb for steel. Wether it be angle, channel, tube, whatever.
I was really just trying to point out the weights of the beams. Obviously a lighter beam is going to be cheaper. So, sometimes going taller and ligher will be just as strong.
And...Thanks for the kind words:D
2018 Kia Forte Sedan (A59231)
2018 Kia Forte...
MITER SAW MOUNTED ON STEEL ROLLING CABINET (A60432)
MITER SAW MOUNTED...
HUSQVARNA RIDING MOWER 46IN DECK (A56859)
HUSQVARNA RIDING...
2019 Ram 4500 4x4 S/A Dump Truck (A59230)
2019 Ram 4500 4x4...
2014 International WorkStar 7300 4x4 Altec A55F 55ft. Material Handling Bucket Truck (A60460)
2014 International...
500BBL WHEELED...
