Oil pressure too high?
/ Oil pressure too high? #1
Elkins45
KY
Kubota L3800
I posted some questions about my Massey 245 in the MF forum and got a couple of responses, but I wouldn't mind getting a little more input on the one question I really care about the most.
My oil gauge is reading high. I changed the oil and filter and it didn't make a difference. Here's the needle at 1000rpm. Should this concern me or is this just possibly a gauge calibration problem? Or is high pressure a good thing unless it's pegged? It's a Perkins 3cyl diesel if that makes any difference.
/ Oil pressure too high? #2
G'day is that cold? I would say that is not a prob, cold those motors run about 65- 70psi @ 1000rpm . If you are worried and have acces to a pressure gauge to give you an accurate reading you could check it out with that. Better that side of the gauge and not the other:D
Jon
/ Oil pressure too high? #3
Jon
I suggest banjodunn have the oil pressure checked with an independent gage. If it's reading wrong, the actual pressure may be at the other end of the scale.
/ Oil pressure too high? #4
yep.. use a 'real' gauge listing psi.
also.. is this hot or cold..a nd what oil? 15w40? or?
and what are your temps.
does it go lower when warmed?
how many hours on machine?
it just start doing this or been doing it a while?
soundguy
soundguy
Hot and cold. Doesn't vary with temp. The temp gauge doesn't work so I can't give you actual numbers.
15W40 Delo
1600 hours and the machine is new to me so I don't know if it's always been that way or not.
What would be the highest safe number if I hook an actual pressure gauge to it?
I'm still happier it's reading high than if it were reading really low, at least I think I am.
/ Oil pressure too high? #6
too much oil pressure can be an issue too.. like washing out bearings.. etc.. or leaking.. can also be an indicator of major problems ( spun bearing..e tc.. )
put a delinieated gauge on it and read it. if 80+ be worried..
as another said. I've sene an old gauge be 'half a scale' wrong... thus I always check gauges. if it's an oem you want to keep.. just swap in another to double check it..
soundguy
/ Oil pressure too high? #7
definitely, do as others have suggested, put a live gauge in it... and I would suggest installing it in the same port as the current gauge. Purchasing a "T" will allow oyu to run both at the same time....
I am not familar with MF equipment, is this a live gauge or does it use a sending unit at the engine connected to the gauge by a wire???
There's an actual tube running from the block to the gauge. It should be pretty easy to unscrew the fitting and attach a graduated gauge. I guess I need to buy myself an oil gauge now.
/ Oil pressure too high? #9
i keep a reference one in my tool box for just such reasons.
that way I can keep an oem gauge with a tractor IF it is reading ok.. etc.
soundguy
So I took Soundguy's advice and picked up a graduated gauge from Auto Zone and hooked it up to the tractor. Boy was I relieved when it quickly rose to 60 psi cold but went no further. Looks like I won't have to drop the oil pan after all!
Thanks for all the great input. Now all I have to do is weld up the part I broke while removing the loader so I could replace the air filter. It turns out a QD loader really isn't QD when the bolt hasn't been turned in 15 years.
/ Oil pressure too high? #11
Common problem with MF OEM oil pressure gauge. My 150 has shown "high" like that since it was new.
The pressure relief in the oil pump on those Perkins 3-cylinders have a habit of sticking on engines that have a history of poor maintenance. Pressure will go "off the chart" if it does that.
/ Oil pressure too high? #12
so what part didja break? :)
glad the oil pressure deal turned out ok. that's why I like a delineated gauge..
soundguy
soundguy
I twisted off the bolt on the thingie that holds the loader to the frame. The diagram on Messick's calls it a 'clamp weld' and says it costs $74.
I haven't welded in 15 years, but I'm willing to give it a try rather than spending $74 + shipping for a replacement part. Guess now it's time to find out if I can still strike an arc, assuming I can even find my helmet.
/ Oil pressure too high? #14
if I didn't have a torch, grinder, chopsaw and welder I'd be broke. new stuff costs way too much vs fixed stuff.. :)
/ Oil pressure too high? #15
If I were you I would buy a temp gauge that works also. Temps in a diesel are just as important as oil press readings. I take a look at both gauges every minute or so while running my tractors.
Chris
Chris
I need to figure out if the problem is in the gauge or the sender, assuming it's an electrical gauge. Any tips besides pulling the wires and hooking a VOM to it?
2017 Ford Explorer AWD SUV (A59231)
2017 Ford Explorer...
Adams Tilt Trailer (A63688)
Adams Tilt Trailer...
2025 Rippa IREAS Ripper Mini Excavator Attachment (A61572)
2025 Rippa IREAS...
1996 Sunflower 1543-38 Folding Disk (A63688)
1996 Sunflower...
25026SFL (A61569)
25026SFL (A61569)
2017 GMC Sierra 2500 HD 4x4 Crew Cab Pickup Truck (A61573)
2017 GMC Sierra...
