atv flail mower
/ atv flail mower #1
yukon1975
atv flail mower
Hello all,
New to the forum, Looking to see if people are interested in self powered flail mowers to pull behind atv's or tractors. Mows very well. Cuts 5 foot plus tall grass and shrubs and 1.5-2 inch saplings. DSCN8571.jpg
/ atv flail mower #2
NIce
If I didn't have a tractor, I would be interested in one...
How much?
/ atv flail mower #3
Depending on price etc, I would. I have a tree farm that something like this to pull behind a RTV would be a nice addition.
/ atv flail mower #4
How about some more data on the machine. What about a web site, or something.
/ atv flail mower
powered flail mower
will cut and mulch grass, brush and saplings 1.5-2.5 inches in diameter.
Rear roller to protect flails
Easy height adjustment with the turn of a handle
2 inch ball hitch
Weight:280 Kgs
Cutting width:48 inches
Efficiency:2500~ 6500m イ /h
Engine Model: Lifan 389, 13hp gas engine
Engine type: 4-stroke, 25 inclined, single cylinder with Air-cooled
BorexStroke (mm/inch): 88x64/3.46x2.52
Displacement (ml):389
Compression ratio:8.0:1
Max. output (HP/rpm):13.0/3600
Max. torque (N.m/rpm):19/2500
lgnition system:Non-contact transistorized ignition (T.C.I.)
Start mode Recoil and hand-operated/Electric start
Air cleaner Semi-dry, oil bath, dual, double silent and cyclone type
Fuel tank capacity (L/gal):6.5/1.7
Fuel consumption(g/HP-hour):290
Engine oil capacity (L/gal):1.1/0.29
Dimensions(LラWラH) (mm/inch):510x460x450/20.1x18.1x17.7
Will try to post video soon.
/ atv flail mower #6
count me as interested, any clue as to the price?
/ atv flail mower #7
Hello all,
New to the forum, Looking to see if people are interested in self powered flail mowers to pull behind atv's or tractors. Mows very well. Cuts 5 foot plus tall grass and shrubs and 1.5-2 inch saplings. View attachment 229667
Is this like a FREE COMPANY AD or are you trying to sell yours or what?
/ atv flail mower
the price would be around 2200.00+shipping, about 2400 total with shipping. I bought two, using one and looking to sell the other. I can only get a minimum of 5 at a time:eek:, the original shipment was for a product trial, and had to order at least 2, so was trying to find out if people were interested in these mowers.
/ atv flail mower #9
Just my opinion:
I can’t see how anyone could justify that price, when rotary cutters are so common and can be had for less than $1k.
No offense, but I don’t believe that it can cut trees 1.5-2” in diameter. At least, not without getting very beat up.
/ atv flail mower
Just my opinion:
I can稚 see how anyone could justify that price, when rotary cutters are so common and can be had for less than $1k.
No offense, but I don稚 believe that it can cut trees 1.5-2 in diameter. At least, not without getting very beat up.
I'll post a video soon, and yes it can cut trees 1.5 -2 inches and not get beat up, I would not recommend going through and cutting a forest of 2 inch saplings down, that is not what any mower is intended for. It has great ground clearance when needed, and this can also cut your lawn to a finish cut and bush hog. Great when you have more than 2 acres to mow, either to a finish cut or rough cut. I could probably get the price down a bit with larger orders, but probably only down to about 2k+shipping.
/ atv flail mower #12
Just one comment on this. Seems to work very well but the other video you have on youtube of kids running the atv and flail mower scares me. The idea of four kids (all on the atv at once) running an atv with a flail mower sitting behind to be honest sounds like some really bad judgement. The other members can see the video here. As a parent and someone who's seen farm accidents it made me cringe.
kids mowing field with atv flail mower - YouTube
/ atv flail mower
You know, that was the only time I let them try that. I did realize just what I was doing and made them get off. It is a scary thought as to what could happen!
/ atv flail mower #14
seems like a great machine. shouldnt have bother selling it
/ atv flail mower #15
Here's one I built for clearing snowmobile trails. 58" cut, 24 hp Honda, uses Alamo flails and parts. Eats anything you can drive over with the ATV. It cuts at a faster speed than a rotary will in the heavy stuff. It also tolerates hidden obstructions like rocks, downed trees and such better than the pull behind rotaries we also use. I mounted the tires inboard since we have to cross narrow bridges on the trail.
/ atv flail mower #16
must have been going fast in that first pic, cause that grass just looks beat down, not really cut?
/ atv flail mower #17
Yeah I was going too fast. I just started into that field and stopped to take the picture. It got a little better as I went. The problem comes from the weeds and such being stiff and dried out. The ATV pushes them over and the flail has a hard time picking them up and cutting them when they're really long. The second picture is better. He's going fast and the grass/weeds are still green and more flexible. It cuts better that way with less dust and chaff. We only have to knock the tall stuff down. The cut height is just over 4". Snow will cover the rest. The club next to us will be building one this fall. It will be an improved model as I found a few places I could improve the design.
/ atv flail mower #18
If you could offset the mower, although it might be harder to pull, wouldn't that keep from knocking down the grasses first and also keep debris out of the ATV engine/radiator? Just a thought.
/ atv flail mower #19
Do you have any ordering information? Is this sold in the US?
/ atv flail mower #20
I am interested. I have been looking for a while and can't seem to find any.
1998 Ferguson 46B Compactor / Roller (A62613)
1998 Ferguson 46B...
Wooden Wagon Wheel Bench (A61569)
Wooden Wagon Wheel...
Metal Bigfoot Lawn Art (A61569)
Metal Bigfoot Lawn...
2014 Ford F-550 (A55973)
2014 Ford F-550...
2012 PROCO 130BBL VAC TRAILER (A58214)
2012 PROCO 130BBL...
2005 International 5900i T/A Flammable Liquid Transport Truck (A60352)
2005 International...
