60 gallon air compressor
/ 60 gallon air compressor #1
mechanic
missouri
I need to ask you guys about the air compressors that are out there since I let mine go with the house I sold in MIssouri 2008. Mine was a campbell Hausfeld extreme duty it was a good one . Never any trouble of any kind. I want to buy another 60 gallon but I under stand some of these new air compressors have pumps made in China. I want to stay 100% USA made. I have looked at the new campbell hausfeld compressor and they look like they have cheap made pumps. I have been looking at the Ingersol rand compressor but you are talking $700. I need to know what you bought recently so I can compare. I was thinking about the Husky at home depot but again the pump looks a little cheap. Can you give me what you recently bought and what you experienced. Thanks, Also did you leave it on the pallet or bolt it to the floor. I ran mine from a pallet for many years and both compressor never had any trouble with breaks on welds or pump.
/ 60 gallon air compressor #2
$700 for an IR 60 gallon compressor seems like a very good price to me. back in April I purchased an IR 60g two stage from Northern Tool and it was close to $1,300 - but i think i got free shipping. I purchased one of those hard rubber mats from TSC put the compressor on that then anchored it to in the concrete.
/ 60 gallon air compressor #3
6.5 HP iron horse from TSC 60 gallon
V-Twin pump
Good for price paid $449+tax
11.9 CFM@90
Left on pallet...can pull out for oil change
/ 60 gallon air compressor #4
I bought the $400 Husky 60 gal. compressor from HD at least 10 years ago and it's still working just as good as the day I bought it. It will do something like 11 cfm at 90 psi and has so far done everything I need - including inflating my neighbor's tire on his 5 cuyd front end loader. However, my air use is expanding and I've built another shop, I'm debating between getting another one or getting a IR with 18cfm @ 90 psi rating at 2x the price. Die grinders use a lot of air and with 2 people in the shop the 11 cfm may not be enough. It should be possible to parallel the compressors then I'd get 22cfm instead of the 18 - - - :confused2:
/ 60 gallon air compressor #5
As I understand Campbell/Hausfeld is still made in the USA. Ohio I believe.
/ 60 gallon air compressor #6
I bought the 60 gal IR and that thing is quite and bullet proof. I love the quietness of the compressor.
/ 60 gallon air compressor #7
Quiet is very important... at least to me.
/ 60 gallon air compressor #8
Might want to check the fine print ----- I thought the same thing and bought one of thier cut off tools. As soon as I put the air to it I knew that I'd been had. (No power and a vibration -- POS)
I try to buy American and as Dennis I thought that C/H was built in the states, but after looking through the paperwork I find that it's a MIC.
(made in china)
I will look closer next time
-J.C.-
/ 60 gallon air compressor #9
Consider the 60 gallon compressor from Lowes. I am happy with mine and I use in in a medium duty home shop. The compressor is made by Coleman in the USA but the motor is made in Mexico.
I think in a global economy, it would be difficult to find anything made 100% on our soil.
/ 60 gallon air compressor #10
I have an 80 gal Husky I bought at HD a few years ago. Just looked all over it but can't find a single tag that says where its made. There is one welded on tag that says Certified by Campbell Hausfeld and manufactured in 2008. It is possible they make them for HD using the Husky name. It replaced a 20 plus year old 60 gallon compressor bought from Northern Hydraulic (Now Northern Tool). I don't know where that was made either.
/ 60 gallon air compressor #11
I bought a 5 HP IR and it's been outstanding. Mine is mounted to the concrete floor with a 3/8" thick rubber pad sandwiched between the base and concrete. Works great.
/ 60 gallon air compressor #12
Monster5601 I'm not sure that anyone makes electric motors in the good ol USA anymore, at least any under 10HP.
I worked for Westinghouse at a motor manufacturing plant for over 15 years and in the mid 80's they were moving all of their production to Mexico.
I think there were still a few small independent manufacturers making motors in the USA but I believe they have mover off shore as well.
/ 60 gallon air compressor #13
you need to look at HP and CFM output @ 90PSI also and not just tank size. never buy a single stage that pump's over 125 psi, more than that you want a 2 stage. never buy a large tank oilless compressor and stay away from them all together if it will be used for large air consumption air tool's.
Do you think that one man could handle taking an IR off the pallet and mount in to the floor by myself?
Do you think that one man could handle taking an IR off the pallet and mount it to the floor by myself?
/ 60 gallon air compressor #16
I had to take one up a flight of stairs...
The only way I could do it by myself was to separate it into 3 pieces... tank, motor, pump.
Now, if you only have to get it off the pallet, you should be able to walk it off to progressively thinner blocks... once on the floor, it's not hard to walk a little at a time.
/ 60 gallon air compressor #17
mechanic,
I don't think one person can move it. They are pretty heavy, and I moved mine with my tractor and two of us moved it into place.
/ 60 gallon air compressor #18
I bought a Craftsman 60 gallon oil-less several years ago and it still works fine but it is noisy as **ll. Scares the bejesus out of me everytime it kicks on when I forget to flip the switch off (it has a slow leak down that I have not bothered to look for). It doesnt walk around though and is on a two wheel cart for portability. It runs my air tools very well and even an elcheapo paint gun when I needed it. If it ever goes out, I will be looking for a twin cylinder type compressor next time with good cast iron sleeves.
/ 60 gallon air compressor #19
On December 9, 1998, I bought a 60 gallon Puma V-Twin. The dealer loaded it into my pickup, but when I got home I had to unload and move it into place by myself. I did have a pretty good 2-wheeled dolly. I don't remember what it weighed, but I know it was heavy and I left it on the pallet. I sold it 4 years later when I had to move back to town, and it was pretty good job for my and my brother with that 2-wheeled dolly and some ramps to get it up into the pickup of the guy who bought it.
/ 60 gallon air compressor #20
Bill, I'd agree that a 2-stage would be preferable, but my current 30 gallon "Industrial Air by Coleman Powermate" is a single stage vertical 2-cylinder that kicks on at 125 and off between 150-155 psi. It's used a great deal and sometimes run continuously for pretty long periods of time and has never given me trouble at all. Of course, it only turns 6 years old this month.
John Deere 2555 Tractor with Loader (A61166)
John Deere 2555...
UNUSED KJ 4PC WIRE MESH (A62131)
UNUSED KJ 4PC WIRE...
5ft. Wooden Native American Statue (A61569)
5ft. Wooden Native...
INOP/NON-RUNNING 2005 Freightliner M2 106 Day Cab Truck, VIN # 1FUBCXDL85HN88678 (A61165)
INOP/NON-RUNNING...
Yamaha Golf Cart (A64047)
Yamaha Golf Cart...
UNUSED JCT 72" HYD BRUSH CUTTER (A62131)
UNUSED JCT 72" HYD...
