AZ ranch
/ AZ ranch
I made 3 trips to the quarry this weekend (110 mile roundtrip). Spread one load at the top end of the drive, right in front of the trailer. Another load went down towards the other end. I'd say I'm about 50% done with covering my 1/4 mile drive. When I get finished, it will be time to start over again. :laughing:
/ AZ ranch
I got out just in time today. The clouds were rolling in and I made a run for it. By the time I got to the paved road it was coming down in buckets. The paved road was flooded in several areas. If I had waited about 30 minutes before heading out, I would be spending another day there, as there is no way the dirt roads were passable by then. :D
/ AZ ranch
Hi Bo,
24" is plenty from a frost perspective up at the Ranch. Our average frost depth is only about 6". All of the piers for our cabin and porch and shed are around 2 - 2-1/2 ft deep. They haven't moved in the 7 or 8 years they have been in place. My water lines are 1-1/2' to 2' deep, and have never frozen.
Your place is looking good. I wish I could move as fast as you are.
Randy
Sometimes I think things are moving SOO slowly, but then I stop and think that we just bought the land 5 months ago, so we're moving along okay.
That said, I got my plans back from the draftsman and sent them to a structural engineer. He responded by saying I need a soils test. So now I'm waiting on a soils engineer to do his thing. Patience, patience. ;)
/ AZ ranch #124
I have been reading Obed's thread on building his house and it is awesome. I am totally amazed at what I have learned on this forum in the few short weeks I have been on it. I'm going to do a little thread on my own so I can get some of this fantastic advice, and hopefully cut back on some of the mistakes I'm likely to make on my own.
Several months ago we started looking for a place to build a vacation/retirement cabin. A month ago we closed on 40 acres in Northern AZ just south of I-40, near Seligman. I'm 61 and not a contracter (actually an accountant), but I'm going to try and do as much as I can myself. If I finish it in less than 3 years I will be extremely happy.
Here is a picture of the view from one corner of the ranch.
BoFuller,:)
Just found this thread. Hope to enjoy it in the next few days.:D You have picked a beautiful spot to retire.:thumbsup:
hugs, Brandi
/ AZ ranch
BoFuller,:)
hugs, Brandi
Thanks, we sure love it. :thumbsup:
/ AZ ranch
I had a company bring in a load of gravel for a base for part of my drive. I was leading him down the backroads when he asked me about a shortcut. I told him it was too steep for his rig, but I guess he took that as a dare, as he turned off and tried it. Needless to say, he couldn't make it, and it was too dangerous to back down. After about 5 hours, we finally located a large Wheel Loader (Cat 966) that was able to pull him up.
/ AZ ranch
My neighbor brought over his grader and told me I could use it to make some ditches along my drive. Not only did it do a great job, but it was also way too much fun! :thumbsup:
/ AZ ranch #129
Bo-
Now thats some great neighbors!!
Just found your thread, great read! You're doing a great job documenting each step, along with great pics. I look forward to following it.
Also jealous on the dump truck....:thumbsup:
/ AZ ranch #130
Those are some amazingly clear pics. The sky looks like "picture perfect" weather....pun intended. What model is that camera?
Prolly not too many dialup folks will want to open them though.
/ AZ ranch
I am using a little Canon PowerShot SD960 IS
It does take good pictures, and video too.
I never thought about dial-up. Should I be saving them as smaller size pictures?
/ AZ ranch #132
Thanks, I will have to check out that model. I take pics in large high resolution as yours are. When I want to post on the net I resize or resample them but keep the original also. I have lightning fast internet but I have noticed many complaints on other threads about slow loading pics.
BTW, nice place you have there :thumbsup: I'm doing the same to raw land in PA.
/ AZ ranch
We purchased a 2500 gallon water tank and buried about 2 feet of it in the ground to prevent freezing.
/ AZ ranch #134
We did a similar thing up the road from you... Just to be sure, you might want to insulate your outlet pipe. It is likely to be more exposed, if you have a shut-off valve there...
No freezing so far, after 5 years.
/ AZ ranch
Thanks Randy. Yeah, the shutoff valve is in a box and is about 20 inches below the ground level. I have a couple bags of insulation I took up last time to stuff in there when it gets a little colder. I also ran a line to the trailer and put a box and valve at that end. Both will be insulated. Thanks! :thumbsup:
/ AZ ranch
We were going to fill our 2500 gallon tank by making 5 trips into town with our 500 gallon water trailer, but our fabulous neighbor brought over his truck with a 1000 gallon tank and a generator big enough to run the shared community well pump, so we used that instead! 4 mile round trip instead of 46 mile! :D
/ AZ ranch #137
Is that a Texas tag on that truck? Why the wood flooring in the bed?
Sorry, just curious.
Edit,
Oh, I see. Closer look I see that is a grain truck with a dump bed and not a dump truck.
/ AZ ranch
Edit,
It's my neighbor's truck. A dual axle Freightliner, and yes he still has a Texas plate on it.
/ AZ ranch
I didn't know there was a difference. If it dumps, isn't it a dump truck???? :confused:
/ AZ ranch #140
It is a small world. We have a place that we go to in the summers near there, up at 7500 feet, technically in New Mexico. Some tips that have helped me:
1. I have 3 approx 200 watt panels mounted flat on top of a storage box that provide us with enough electricity to run a portable evaporative cooler during the afternoons, plus t.v. and such. The grid-tie panels that I bought are cheaper, and the Outback 60 charge controller has MPPT voltage conversion to bring it down to 12v for my 4 sam's club golf cart batteries (series/parallel). Just put a a 10 amp fuse on each panel wire, and they all parallel into the controller, since they're all similar voltage. I use a 175 watt RV resettable inline circuit breaker going to the inverter from the batteries, and regular 15 amp breakers going to the trailer and water pump from the inverter.
2. I use a Xantrex prosine 2.0 (pure sine wave) inverter/charger which powers everything, including my wife's hair dryer, a toaster, microwave, and grundfos water pump. You can add another and they will synch to give 240v, so they are very economical, plus expandable. I put an extension cord male plug coming out of the Xantrex which allows me to plug into a small gas generator in case of snow/overcast/rain to charge up the batteries. We use the high draw items during the afternoon and the batteries are topped back up very quickly.
3. I use a 100watt panel with 2 sam's club batteries to power the 12v coach items, which includes the switching for the refrigerator control, water heater control, all the interior lights, and the furnace fan.
4. We use portable lp gas cylinders, the 30 pound size being a good compromise. I put pressure gauges on them, but lifting them gives me a better indication of when they're running low or not.
5. We also bought a 40' container for our machines. I highly recommend using solar chargers on all batteries....but you must use the type with controllers. Battery tender now makes a 5 watt panel with float charge controller, unlike those cheaper panels that don't know when to slow down, this will keep the battery at 13.2 volts after charging. Glue them to the top of the container, drill a tiny hole through the little vents in the upper corners, then cut the wires, resplice the connectors on the inside, and you will not be buying batteries very often.
6. I have the same water tank, about half submerged. We add bleach every year, and it has lasted a long time, but does smell like chlorine, which doesn't bother us.
7. I took out the toilet and black water tank immediately, then installed a tight clearance residential toilet (has thinner tank dimensions, so it doesn't stick out far from the back wall), then ran straight pvc pipe to the septic, with a Y for the output of the gray water tank to join it (downhill from the gray water level, to avoid them mixing in the graywater tank). This gives no smell, no residue in the black water tank, which is almost a certainty if you leave the outlet open all the time, due to the large area vs. small amount of water per use.
8. We try to not drive when it's wet, since the calichi mud is so gunky, as you've found out, I'm sure.
9. It's too long of a trip for me to get out there from Florida very often, so I envy you building your place. My solar setup allows any power tools to run, including air compressor, so I look forward to hearing how you handle your building.....I hope to do something similar myself, possibly with a pole-barn type foundation and built-up wood floor.
10. I have a motorgrader that I inherited, needs a tire fixed, will sell pretty cheap, Cat 12, I think, as well as a Fiat/Allis FL-5 track loader with a 4-way bucket that is a lot of fun.
11. If there is a market for tumbleweed, I can also claim my expenses as a deductible item!
12. I used to do a lot of gravel drive maintenance, and a box blade can really help for spreading dump loads.
UNUSED FUTURE FT-RP72 - 72" HYD ROCK CRUSHER (A52706)
UNUSED FUTURE...
2007 Ford F-150 Ext. Cab Pickup Truck (A59230)
2007 Ford F-150...
UNUSED RAYTREE RMLL60-60" HYD LAND LEVELER (A60432)
UNUSED RAYTREE...
2017 Freightliner M2 106 AWD Terex Hi-Ranger 5TC55 55ft. Insulated Material Handling Bucket Truck (A60460)
2017 Freightliner...
SKID STEER MOUNTING PLATE (A60430)
SKID STEER...
2014 Caterpillar 257D Compact Track Loader Skid Steer (A59228)
2014 Caterpillar...
