twisted FEL
/ twisted FEL #1
dqdave1
N. E. Ohio
tc- 29d
Anyone had to straighten their FEL. During all the snow in the NE last week I helped a friend move snow from some parking lots. I was moving along a curb and caught a storm drain with edge of bucket; needless to say , went from 8 mph to 0 in 0 seconds; I now have a bucket that is about 3 inches out of level. No visable bends. It must just be twisted. Any advise would be appreciated.
New Holland TC 29 with a 7308 quick attach loader with 68" bucket.
/ twisted FEL #2
If you know of someone with a frame straightening jig (good body shop) I would check with them.
I have done various unsafe things to straighten dump doors on hay rollers , arms on loaders, etc. But cannot really advise without seeing the loader.
/ twisted FEL
Thanks for the replies. I thought about the frame straightening, probably way to go and the safest. I did remove the loader and it is sitting detatched and it "wobbles" I can stand on right side of bucket and rock the frame assembly. When it is mounted; I released the right side quick attach lever and FEL frame on that side popped up about 11/2" and bucket was then flat (almost)
/ twisted FEL #5
Sounds like most of the problem might be in the frame for the loader instead of the loader arms and bucket ?
Could it's mounts have shifted or bent ?
Try parking the tractor on a smooth concrete surface,
measure the axle heights and adjust tire pressure till both rears match and both fronts match. Now start measuring from the floor up to various parts of the loader frame , arms,etc to figure what is bent where. You might have a couple of places bowed.
Best of luck to ya.
Ben
/ twisted FEL #6
That has got to be very frustrating I am sure. I know I would be very unhappy with myself doing this kind of damage. I am not familiar with that loader and would love to see some pictures. The 1st thing you need to look for is cracked and chipped paint to see if you actually bent something. I know are 1st instinct is to think we really did some damage but lets look for the simple things 1st. Tractors are pretty indestructible so I would rather look for alignment issues 1st. I have to ask what happened to the bucket. I would think your damage would be there rather than the frame or the loader. I find it hard to believe the loader cradle is bent. I would think the piston tube would fail 1st before anything bent. Blistered paint is the 1st thing to find. My thoughts without seeing anything is disassemble and reassemble the loader for realignment. Look at the piston on the impact side too you might have a failure there not allowing the full range of motion
__________________
Kubota B7800, Fel Forks, Landpride PHD, 6 Acre Horse Farm
/ twisted FEL #7
You should be able to straighten it by removing the lift cylinder from the high side (plug the hoses so no fluid can move). Then lift the low side cylinder while the high side of the frame is constrained. Under a big truck, low tree limb, etc. Go slow and measure often. If you can do it while on dead flat concrete, you can measure progress with a long level. You have to go past good so when it snaps back, it snaps to about level. NOTE: once racked always racked if often true. The question is just how much of the racking can you get out?
I hate to point it out, but you have demonstrated why plows are mounted with trip springs. FEL buckets are not. If you are going to continue plowing with your tractor, do it a favor and make up a QD plow mount with a plow blade that is spring mounted.
jb
/ twisted FEL
I have removed loader; I have found the midmount bracket on the "hit" side bent. I just bought a new bracket to replace the bent one. Bucket did not show any new damage. I have taken measurements on all loader mounting brackets and all are within 1/4' of each side. This is how I found bent mid mount. Replacement bracket matches to other side now. When at dealer to pick up bracket; he suggessted I remove bucket, then remove loader from tractor, and begin taking measurements at many different locations including diagonal measurements. He said he has seen many "sprung" loader frames on the new quick detach systems. He said it can be brought back into position easily at a good auto frame repair shop where they can do it correctly with heat etc.
I should point out that when it struck the drain in curb, it did "pop" the quick release on the side of impact at the bracket that I found bent, which allowed the right frame of the loader to be pushed up while the left side was held in place. This may be how the frame sprung; it may also be why I caused no visable bends or major cylinder damage.
As for plowing snow; I was helping "move" large piles that the plow trucks had created in parking areas. I thought I would be nice and clean along curb that had some buildup of ice.
I do appreciate all the replies, as this site has many experienced tractor operators that are willing to share their expertise and past knowledge.
/ twisted FEL #9
Start measuring stuff. The first measurement I'd look at would be from the main bucket pin at the bottom of the loader arm, to the main loader arm pivot pin at the top of the loader arm. Compare left side to right side, from the description of what happened, I'd almost put money on those measurements being different.
If they aren't, then you might have bent the sub frame. For that put the tractor (without loader) on a flat hard surface and measure up from the ground to the top of the sub frame near the loader control valve. Same for the other side. Is that height the same? Have to make sure the tires are pressurized the same front side to side and rear side to side.
Looking at a picture of that loader, the front lower arm(s) looks like it could be bent doing what you did with the loader down on the ground like that. Bummer.
Monte
/ twisted FEL #10
I have been following this thread and have seen some good advice. Were you able to get it square with the new midmount?
/ twisted FEL
Sorry; I was tied up over the weekend; I am waiting on a bracket that the quick connects mount to as it was bent also and thought since it was apart, I would change the bracket also. I will be mounting (remounting) the loader later this week. Will keep everyone posted.
/ twisted FEL #12
Slow down. Especially when you can't see potential obstacles. You wouldn't go 8 mph with a bushhog through a field of knee high grass with unknown obstacles in it, would you?
/ twisted FEL #13
I had thought the same thing, but I was assuming he already learned his lesson. I am sure he will be MUCH more careful next time.
/ twisted FEL #14
Wow talk about salting the wound, Some things just don't need to be said. We all live and learn. I wish I could never say "What was I thinking" to myself when I cause myself some aggravation
/ twisted FEL #16
redlevel said:
He asked for advice.:confused:
It's easy to ask, it's often difficult, embarassing or painful to actually get the advice. Especially when you did something that you knew was a real head slapper 0.001 seconds after it happened!
/ twisted FEL #18
RickB said:
Experience is what you gain immediately after you really need it.
LMAO There have never been truer words.
/ twisted FEL
Finally had a chance to address my loader issue. I replaced right side mid mount bracket which was slightly bent. Remounted loader and it still was about 3 inches high on the left side. Removed the loader and disassemblied all mounting points for inspection. Found nothing obvious. I reassemblied all mounting points and all are level. Removed bucket. Bucket has approx. 3/4 inch twist in it, but not sure it was from that day or over the 7 years of use. First time I ever removed the bucket from frame. Wear bar will wobble 3/4 " if I stand on bucket and rock it. Disassemblies the midmount arms from loader frame and they looked good. Side by side everything looked the same. I then disassemblied the cylinders and hydraulic lines from the loader frame. This leaves the two frame arms and a cross piece at front by where bucket installs. This is where the problem lies. With the frame setting on level concrete; the frame is twisted; nothing obvious; no cracked welds, no bends, etc. If you hold the midmount frame points against the floor the bucket side frame has a 11/2" difference, or one side is 1 1/2" off the ground. If I hold front of frame ( bucket end) arms flat on concrete, the midmount frame arms are 1" out. I hope someone on the forum has skill in straightening. I stopped messing with it. I did try to drive the tractor up each arm to see if it would bend back; no luck. I know it will take heat and pressure to staraighten it. Anyone know proper technique to do this. Friend suggested grinding welds off off one side of cross tube and freeing it from one frame arm; repositioning and rewelding. It is a 7308 new holland loader.
/ twisted FEL #20
Hi Dave - I am just wondering if you ever resolved your situation on the twisted FEL. Your post end with you asking for straightening advice. I have a similar issue with my Kubota B26. I bought it used from someone who used it for snow clearing and the the quick attached pins where frozen (a little rust) when I did my inspection. Once I got the pins moving the quick attach plates 'twisted'. I am fortunate in that at both full dump and full curl the plates align enough to switch implements. It does add a minute or two to the change out process which I would like to avoid if I can figure out how to straighten the racking.
I would appreciate any wisdom you can share.
2007 Ford F750 Dump (A62613)
2007 Ford F750...
2023 VOLVO L90H WHEEL LOADER (A65053)
2023 VOLVO L90H...
2022 JOHN DEERE 333G SKID STEER (A65053)
2022 JOHN DEERE...
more info coming soon! (A61569)
more info coming...
2022 SANY SY26U EXCAVATOR (A63276)
2022 SANY SY26U...
Lonestar Panel 24ft. Free Standing Panel with 7ft. Gate (A65640)
Lonestar Panel...
