No trailer brakes
/ No trailer brakes #1
dodge man
Super Star Member
West central Illinois
JD 2025R
It appears my trailer brakes aren't working. I'm almost positive its on the truck side. I have a Teknosa(sp?) Prodigy controller. The truck is a 2002 GMC. When I first hooked everything up it was fine. Then I noticed on rainy days, the controller said "short to battery, no trailer brakes". This happens if the trailer is hooked up or not. I posted about this problem a few months ago and there were several comments about cleaning the plug in at the back.
Tonight was another wet night, so I cleaned the plug in at the back, and also the connector where the wiring plugs into the trailer plug in. This didn't help. I then plugged it into the trailer, and still no go. I noticed when its saying no brakes, that if you hold down the manual lever on the Prodigy, the brake lights on my truck don't come on like they normally would. This happens if its hooked up to the trailer or not hooked up.
I checked the wiring under the dash and where it hooks into the Prodigy, and it looks O.K. I unplugged everthing and plugged it back in with no change.
Any ideas on where to look? My next step will be to start chasing wiring under the truck.
/ No trailer brakes #2
My first guess is its the trucks wiring. You can test the plug with a test light. Some will not test with a volt meter due to no load issue.
If you can find a buddy with a brake controller you can use you could also test it that way.
My guess is its the wiring or the controller. One other thing you can do is every brake controller I have owned disconnects the cruise control via the brake light signal when you slide the manual bar. Try driving with the cruise on and hit the manual lever. It should disconnect the cruise.
As far as chasing wires, start at the plug. Take it fully apart. I have seen many GM plugs full of rust and corrosion after that many years of service.
Hope this gives you a place to start.
Chris
/ No trailer brakes
The cruise doesn't work, and hasn't worked since I bought the truck. I probably need to take the plug apart, thats a good place to start. I sprayed some cleaner where the wires go into the plug in, but I didn't pull them and check them.
/ No trailer brakes #4
The back side of some aftermarket and some factory plugs can fill with corrosion...had this happen on a Reese 7 pin plug once...What a mess that made of the truck wiring..Fortunately, it was an easy fix.
/ No trailer brakes
Yesterday was dry and the controller said everthing was O.K. so I hooked up to my trailer. I didn't test drive it but I'm pretty sure everything was working. I just have to figure out where the moisture problem is.
/ No trailer brakes #6
On dodges there is a common spot the tow harness rubs through on the chassis, there are probably some spots like that on the chev too. Gets wet, shorts out.
New/Unused Wolverine 78in Quick Attach Smooth Bucket (A65583)
New/Unused...
1993 WhiteGMC WG Tri-Axle Dump Truck (A61573)
1993 WhiteGMC WG...
1995 Peterbilt 379 Tri-Axle Dump Truck (A61573)
1995 Peterbilt 379...
2007 Komatsu WA200-5 (A64047)
2007 Komatsu...
2015 Chevrolet Silverado 1500 4x4 Crew Cab Pickup Truck (A61573)
2015 Chevrolet...
2002 Bobcat 863 High Flow Compact Wheel Loader Skid Steer (A59228)
2002 Bobcat 863...
