Dozer Question
/ Dozer Question #1
Kyle241
Eastern Ontario
Kubota MX5100
I'm in the market for a small dozer for work on my property. I'm only at the initial stages of looking and have a dozer operator who will help me choose so that I don't buy a clunker. One question I have comes from a local dozer for sale. It's a Cat D4H and it's a 'high track' (sp?) which I only ever seen on large dozers (D7/8, etc.). What is the benefit/negatives to a high track?
Tks.
/ Dozer Question #2
The Hi-Trak eliminates the traditional "ham" final drive and replaces it with a more compact planetary drive. You can actually work on them without blocking the dozer. It's a Cat thing.
/ Dozer Question #3
Tks.
I don't see any advantage or disadvantage in the smaller dozers. Not sure cat still makes high tracks that small anymore, I don't think they do. You might be able to see better. The high track started on the larger dozers and does seem to make them easier to work on than older dozers. It also in mining application is suppose to be easier on the drive train. I think they just went over board and made everything a high track for a while.
Depending on what you want to do, I like Deere or Dresser in that size of machine. I owned a TD-8 for a few years, really nice machine, parts were a little easier on the wallet than Cat. Between the 3 though they are all good machines.
/ Dozer Question #5
Tks.
Seems to me that the high tracks were supposed to have some advantages in muddy swamp like conditions. Also that the high tracks were subject to higher wear rates than conventional tracks. In any event they no longer offer them on the smaller machines so there must be something negative about them.
I too have a need for a small dozer on my property and for 15 years had an old JD 450B. This year I found a real good buy on a low hour 2007 Dressta, (Dresser), TD7M LT, (long track frame).
I like Deere & Cat but found that I could buy a much newer lower hour machine in the Dressta for less money than Deere & Cat. Have only put about 10 hours on it since I have had it, but it works fantastic. Plus it is a simpler machine that I can fix a lot of things on whereas the Deere & Cat require more specialized tools and procedures that I am sure would be above my level of expertise.
/ Dozer Question #6
I have a small Case 450 and it's done everything I've asked. Plus parts for them are real easy to get. I would add the Case 450 and 550 to your list.
/ Dozer Question #7
D4H is a good machine. THe high track gave more visibility to the blade, kept the driver sprokets out of the mud and sand and rock, and made the transmision and drive train come out as a modular unit. On a concrete floor with a small forklift and a few tool I can have the transmission out on the ground in 4 to 5 hours. The tracks costs more as theres more of them but the idlers can be built up with weld.
/ Dozer Question #8
I was looking for a small Dozer and ended up buying a CAT D3... the only thing I don't like about it is that I have nothing to transport it...
On the plus side, every time someone asks to use it... I tell them it will cost at least $300 to move it and they loose interest...
I've been about to do a lot with it and I don't mind that it is bigger.
/ Dozer Question #9
From CAT's website:
Elevated Final Drive
*Isolates final drives from impact loads for extended power train life.
*Protects sprocket teeth, bushings and final drives from debris, abrasive materials and moisture.
*Provides long-lasting final drive performance and durability.
No doubt, CAT is a good machine. A cousin has been in the business for 40+ years. They don't buy anything except CAT dozers. In fact, most all of their equipment is CAT. I had opportunity, last fall, to run a new D4K. It was a very nice machine.
Now, having said that, my personal pick is Case. That's what I bought when I needed one.
/ Dozer Question
Thanks everyone for educating a newbie to dozers. The makes I am looking at are CAT, Case, Deere, Komatsu and Dresser (almost all :laughing:). Around here, Case is the most popular as there is a local dealer but there are the occasional CAT for sale at usually a higher price. I found a 2008 Dresser yesterday at a good price, likely too good and was going to call the seller today. Seems like they are cheaper than the rest and Komatsu's are hard to come by locally.
This CAT is a 1998 with 60% undercarriage and the seller is asking $29k CAD. Don't know when the undercarriage was redone. A little higher than I want to pay but I may keep it on my list to view.
Tks.
/ Dozer Question #11
I bought a Dresser TD7G this spring and just finished redoing the under carriage about a month ago. I am glad my track wasn't any longer like the Hi-track, both from an expense view point and the extra work viewpoint. It is a small point though. Cats are good machines. I looked for months for a D3C or decient JD450C I could afford. I ended up with the Dresser and am very happy with it. Easy to work on also.
/ Dozer Question #12
Dresser made a good machine carried on equally well by Dressta. Dad ran a TD8 For Bonds construction and put down 22,000 tons of stone inside of Cooper tire with one. Also several exits on the Natchez Trace with one. Ive the run the 7,8,9, 10. Also the 12 to the 25 series. The same in the line of the Dressta dozers.
/ Dozer Question #13
Just a little "food for thought". Any BUSINESS Transaction involves both BUYER and SELLER. If the BUYER has done all his research beforehand and made his decision on the item he wants to purchase, and maintains a positive frame of mind, the chances of a better and positive transaction will be the result. If you have someone to go with you that is more experienced in the operation of the equipment; that would be a plus. Most SELLERS will reduce the asking price, somewhat. Obtaining the necessary financing beforehand is also a plus. As an old adage says; "CASH talks--B------T walks. Good luck.:tractor:
/ Dozer Question #14
I have never really operated a small high trak dozer but my family farm once owned a D8N and we liked it. I am a particulary big fan of the D3B by caterpillar. How much do you have to spend? The D3B's go for 7 to 10 grand. But if you got more you should buy a komatsu dozer. We have one of those too. :0
