Kubota B7500
/ Kubota B7500 #1
Theridge
Member
Hey all
I am looking at buy a 2001 B7500 kubota with just over 500 hours. The owner has a york rake and a rear blade attachment that is going witht the tractor. Also has some sort of 3 point hitch for standard ball, trailor hook up. Oh and a Fel! He is asking $7000.00. I want to use at my cabin (approx. 30 acres mostly woods) to mow trails, prepare food plots (small), groom the driveway etc... Just wondering everyones thoughts. Good price? Fit for that kind of work? Also wondering everyone recommends for a pull behind mower. Want to buy a used one. Not sure best size and manufacturer.
/ Kubota B7500 #2
Not sure where you are located, but $7-9k would be a typical price here in NY.
$6-8k without a loader
Aaron Z
/ Kubota B7500
Forgot to mention, my land has some sloped areas and some flat. Anybody else care to chime in?
/ Kubota B7500 #5
If it has been maintained properly, that sounds like a real good price with FEL and the attachments.
/ Kubota B7500
Good to know that it is a good price!
/ Kubota B7500 #7
That is a very good price looking at prices on TractorHouse!
And BTW :welcome:Back!
/ Kubota B7500 #8
Everything Attachments supplies a handy link with info on most every Kubota (and others) like so: Kubota B7500 - Specifications - Attachments
Gives you an idea of the range of equipment you can use and how it suits your needs.
I've got the B7800 - a later model direct descendent of yours, and half of my place is wooded. The B series (and the smaller BX sizes) are great for working amongst the trees because of their relatively small footprint. It's the main reason I didn't buy aan L series - the physical size of the tractor.
With only 500 hrs I'd call yours a fine deal, and they sure are good tractors.
/ Kubota B7500
Great! and thanks for the links.:)
/ Kubota B7500 #10
You should be able to make the rear wheels wider by moving the hub on the axle. The wider you make it the more stable it will be on slopes.
/ Kubota B7500 #11
I bought a B7500 new in 2003 and could not ask for better service from a tractor. Alot of people will look at it and say "You call that a tractor" but when they see what it can do they change there mind. They are small framed but they are little studs for their size. I have cleared several acres of land with mine, kept my grass mowed, driveway maintained, brushhogged for myself and others, cleared fence rows, pushed some minor snow and never had a seconds problem with it. Don't get me wrong it is limited by it's size of course but it will fool you on what it can do.
I also moved my rear wheels out on the axle for wider stance and loaded the tires for weight and ballst with the fel. Oh yeah, I didn't mention that I have used a rear tiller on it for years also and worked great. This would be great for food plots... It is also an easy tractor to haul, I have hualed mine everywhere on a 5X14 single axle trailer that was made for 4-wheelers. I never even tied it down, load it, lock brakes and go.
/ Kubota B7500
Hey Hanksride, thanks for the great info. Just curious, what size and make of brush hog do you pull behind the tractor?
/ Kubota B7500 #13
I have only pulled a 4ft brush hog and not sure the make, it was a cheap Atwoods model.. The brush hog I have is sort of light and I kept bending the rear wheel on it from backing into things.. But the tractor never faltered with it.. I think a 5ft in good easy grass would be fine, but if you got into some heavy stuff it might be a little much for the tractor.
/ Kubota B7500 #14
We have a 5' one that we sometimes use behind our B7500 (as seen here) and it does well in light grass, but you have to go SLOOOOOW in medium to heavy grass.
Edit: If you do not have a loader, you will need quite a bit of weight in the front. Our loader is just heavy enough to keep a decent amount of traction on the front wheels, but when I get moving with the mower in the air, the front end tends to bounce up a little
Aaron Z
/ Kubota B7500 #15
That is an excellent price and a very similiar machine to my B7510 kubota, if it is like the 7510 there is a pin on the rear rim you can pull that pin out and pull your rear tires out another couple of inches then tighten them up. This will help with better stabilty on slopes but always be careful and keep your buckett low to the ground on that machine. You will get to feel it out once you run it but they can get tippy in certain situations. If you feel panic put the bucket to the ground. That machine here in Ontario, canada at the kubota dealer would be listed at 10 grand easily with those low hours.
/ Kubota B7500 #16
Not sure is the 7500 a 23 horse power? I think that is what my 7510 is a and I have a 4 foot rotary cutter, you can get away with a 5 footer in some cases but as said previous in heavy stuff you might not have the pto power you want.
However for normal grass cutting a 72 inch rear finishing mower should be fine.
/ Kubota B7500
Mowing food plots and keeping trails groomed. I can have the local framer blaze any new trails with his 90 hp John Deere. So it seems that 500 hours is considered a low hour machine...? :)
/ Kubota B7500 #18
500 hrs is not that bad could be better but could be a lot worse like some of these turkeys with 2000 hrs on there machines and still wanting top dollar for it :confused2:
/ Kubota B7500 #19
good price..........
/ Kubota B7500
Ok all, I did it, bought a used Kubota B7500! Now I will be looking for a brush hog and tiller. Just saw a 5' king cutter for sale. Will the B7500 handle this? :)
I will post pictures later.
2008 Sterling L7500 Series T/A Vactor 2115-J6 Combination Sewer Jetter Vacuum Truck (A66736)
2008 Sterling...
20ft 4-Door Shipping Container with Shelving (A64553)
20ft 4-Door...
2018 RAM 5500 FLATBED (A67714)
2018 RAM 5500...
2013 Ford F-550 Altec AT37G 37ft Bucket Truck (A61573)
2013 Ford F-550...
2017 Ford E-450 Super Duty Shuttle Bus (A66736)
2017 Ford E-450...
DEUTZ FAHR 4080E TRACTOR (A65057)
DEUTZ FAHR 4080E...
