jd 24T baler
/ jd 24T baler #1
4590
jd A
My slip clutch not engaging on my baler. It works for a while then dis engages. The pto is 540 and works great on the tractor. It will spin for a while, engage, work a bit, then disengage again.
What to do?
/ jd 24T baler #2
What to do?
Which slip clutch? Main drive slip clutch? Pickup slip clutch? Auger slip clutch?
If it's the main drive slip clutch, there should be a slip clutch and an overrunning clutch (sprag clutch) assembled in one unit. The problem could be in the overrunning clutch.
/ jd 24T baler
It is the main slip clutch on the pto shaft.
/ jd 24T baler #4
Springs are rusted and shot, clutch places are long gone and oild from the gearbox has seeped onto the surfaces. There is usually room for adjustment. Depends on how many times its been taxed by th eplunger stop.
Maybe time to clean it up and replace some parts.
/ jd 24T baler #5
The " main clutch " has two parts to it. One is the sprag clutch that allows the baler to free wheel when the pto stops. The other is a spring loaded clutch that is ment to take the shock of the plunger stroke, or slip if there is a sudden stop. PTO has to come off to work on either properly. If it is the sprag clutch, the front of the whole clutch unit comes off, and there are two sprags inside. Just check them over, if some thing is wrong it will be very obvious. If it is the friction clutch. Disassemble and clean up first. Readjust and try it out. Let us know how you make out.
/ jd 24T baler
Thanks Fellas, will take off and adjust this morning, let you know :thumbsup:
/ jd 24T baler
It is the sprag clutch springs. What can be used for replacement. Don't have a JD dealer with in 75 miles so It would be a couple days to get them.
/ jd 24T baler #8
/ jd 24T baler #9
You can buy adequate springs at any hardware store, Home Depot or Lowes, etc. They are about the same thing as a small valve spring. Head out to an auto junk yard. There are all kinds of springs in there: door springs, hood springs, valve springs. You don't need all 10, just enough compression to hold the clutch pack together.
I frequently call my JD dealer (D&G in Milford, Howell, Corunna, etc.) They will UPS them next day for just about nothing.
/ jd 24T baler
Thanks guys, I got some springs at the hardware store, working great and making bales.
/ jd 24T baler #11
Look in the baler manual for the procedure to properly adjust those springs. Your clutch should actually get just a little warm after baling for a while if the springs are adjusted properly. Too tight can cause a whole bunch of problems, expensive problems. Also suggest getting proper JD springs when you have time to deal with it and have them shipped to you.
/ jd 24T baler
Thanks Barry, I will get the correct springs for the sprag. It seems to be working fine am just about finished so will have time to get the right stuff.
New/Unused Landhonor Transfer Pump (A61166)
New/Unused...
2010 Massey Ferguson 2625 (A60462)
2010 Massey...
UNUSED KUBOTA BRUSH GUARD (A62130)
UNUSED KUBOTA...
2014 CATERPILLAR CB34B XW DOUBLE DRUM ROLLER (A62129)
2014 CATERPILLAR...
Land Pride Auger (A61166)
Land Pride Auger...
2012 Caterpillar 924K Articulated Wheel Loader (A61567)
2012 Caterpillar...
