Pulled the trigger on the 5083E
/ Pulled the trigger on the 5083E #1
JD3520Turbo
Mount Vernon, MO
2013 5083E, JD 4210 Compact
Well, after much deliberation, they finally delivered the 5083E to the house and I said farewell to the 3520.
Got the Michelin Radials and the Alpine stereo put in on Saturday, so I am ready to mow some CRP. The tires are far and away better than the bare bones FS that they put on these. Makes the tractor ride and drive so much better.
First observations are that it is way front heavy with an 85 inch bucket and a 553 loader. Needs some rear weight for sure. Transmission seems good. A/C works really nice. haven't had a chance to work it yet, but that should change tomorrow. Taking it to the farm to break it in. Going to mow with a JD HX15 cutter. Dealer said it should swing it, so we will see.
Coming from a compact tractor, this tractor seems huge and very hard to see the bucket. There is going to be a learning curve on this for sure.
Will send some pics when I get them.
/ Pulled the trigger on the 5083E #2
That's a nice big tractor. I think you will some how get use to it and like it and, I don't think it will ever be hard on the eyes....one heck of a rig.:thumbsup:
/ Pulled the trigger on the 5083E #3
You can mow with the 15' but I'd spec a 10' for a better fit. Depending on grass thickness, you'll just have to slow down and remember your mowing 15' at a time, so at 1/3 speed your still doing more work than 3-4 overlapping passes with a 5 or 6 footer.
/ Pulled the trigger on the 5083E #4
enjoy your new tractor.
/ Pulled the trigger on the 5083E #5
I am also considering either the 5083e or the 5093e for a 15' batwing so let me know how yours handles the mower.
/ Pulled the trigger on the 5083E #6
Congrats on your new machine! Lookin' forward to seeing your pics! :thumbsup:
AKfish
Well, I just got home from two days of mowing with the HX-15 cutter. It did fantastic. Had no issues really at all. Yesterday was the hottest day of the year and I ran it for 12 hours and 8 today. It never missed a beat. Used over 30 gallons of fuel. I didn't shut it off at all yesterday. I roaded it about 20 miles pulling the cutter. I only had to downshift on two hills. My neck is sore from looking behind me. Mowed about 55 to 60 acres.
The Michelins performed great on the road and in the field.
I ran that cutter on Epto and normal pto. It worked good either way. I had some areas that were tougher than others. I was impressed with the way it handled that batwing. It is very heavy.
The only issue was that the a/c got warmer when I reved the engine up. When I idled it down to 1200 rpm it would freeze you. But when I ran it at 2500 rpm it would get warmer. So I called the dealer and they said that there was a bulletin about the heater hoses being crossed and the flow control valve only working one direction and that hot coolant could be getting into the heater core and offsetting the a/c. So they are going to check it out for me.
I know this is not their premium model by any means, but I was very impressed with how well it performed. I like the feel of it and the way it drives.
The dealer said it would handle a 15footer, and I after 20 hours, I would agree, it can handle it. I was mowing weeds 14feet tall, and it went right through it.
If i were going to buy a cutter, I wouldn't hesitate to get a 15.
Sorry I am rambling, I am super tired. Pictures soon, I promise.
/ Pulled the trigger on the 5083E #8
Sounds like you have a good setup, way faster than using the 3720:)
Here are some pics. The michelins are much wider on the tread area compared to the stock tires. they are actually a true 16.9 inches wide unlike the others.
The one picture is of my son in the bucket to show how huge it is. Coming from a 3520, this is a huge jump.
/ Pulled the trigger on the 5083E #10
Great lookin' package you put together! Thanks for the pics!
I really went back and forth between the E and the M... Wanted that bigger engine and Hp! Finally went for the hydraulics and extra tranny gears!
Tires are mighty fine lookin' too! Went down that "track" too - but the extra $1,600 backed me up. Like the swept back angle of the bars - probably less road noise and smoother riding - I'd bet.
AKfish
Yea, they ride really nice. They have a very square shoulder on them which gives them much more lug on the ground than bias and other brands of radials. Also, they have a more flexible sidewall to do less soil damage.
I would have loved to had an M series, but I was stretching my budget with the Cab E series.
/ Pulled the trigger on the 5083E #12
Nice lookin setup! Your gonna have to change your name now. :)
I was thinking about that. I guess I should have picked a better name than that. :)
/ Pulled the trigger on the 5083E #14
Congrats on your new tractor. I'm glad to know that it handles the 15ft mower. That is my next purchase for the ranch.....a lot faster to clip pastures. I kicked around the "E" vs "M" for quite a while. I wasn't sure the lighter weight and lesser horse power tractor would handle a large baler and mower. I might have bought more tractor than I needed, lol.
Did you order the air ride seat?
/ Pulled the trigger on the 5083E #15
Nice looking tractor but I think you need a heavier trailer??
I didn't order the airride seat, but after 20 hours of use in two days, I wish I would have. my back was killing me and I could hardly walk. It still hurts and it has been a week. I would like to put the seat back further and I think that would help. I just might end up with a air ride seat before it is said and done. Problem is that they are 600 bucks. ouch.
The trailer is an old cattle trailer that got rolled. It has two 7,000lb axles under it and 3 inch square tubing under it for strength. It is definately enough weight on it that is for sure. I pulled 65 miles each way, and it handled it good.
The fenders have been lowered a good bit, so it looks worse than it really is. When I haul cars on it, I need them lower to get the doors open. I wouldn't want to have the tractor any heavier for this trailer, so I probably won't be adding any weight to the rear end, even though it needs it with a loader.
The 8.1 liter v-8 pulled it no problem. was suprised how well it did.
/ Pulled the trigger on the 5083E #17
That is one sweet tractor. I drove a 6410 a couple weeks ago with a deal that picked up 8 bale packages and would stack them on a 30' trailer. I gotta say, it was almost scary to drive that tractor, with the hay bales sticking out atleast 14 feet in front of the tractor, it really made it hard to load them. But i gotta say, it sure was one fun tractor, i cant imagine how fun it would be to use the bucket and move some dirt. :p:D
2007 JCB 520 LOADALL TELESCOPIC RT FORKLIFT (A62129)
2007 JCB 520...
Wacker Neuson RD12 (A57148)
Wacker Neuson RD12...
20 Yard Roll Off Dumpster (A61165)
20 Yard Roll Off...
2017 JEEP PATRIOT (A62130)
2017 JEEP PATRIOT...
2021 Tesla 3 Sedan (A61569)
2021 Tesla 3 Sedan...
2025 Spirit Electric Scooter (A61569)
2025 Spirit...
