Sickle Bar Mf model 41 sickle mowing angles???
/ Mf model 41 sickle mowing angles??? #1
Jayfish
753 bobcat
How far below horizontal does a Massey ferguson model 41 sickle mower mow. I read it will mow 15-70 def below horizontal. Is that correct. Anyone out there have first hand experience with one. I want to use it to mow pond and lake dams. Please let me know.
Thanks all!
/ Mf model 41 sickle mowing angles??? #2
Thanks all!
70 below and 90 vertical is typical. Ken Sweet
/ Mf model 41 sickle mowing angles??? #3
Thanks all!
The manual says 7 deg above level to 7 deg below level. I have the MF31 mower which only works in the horizontal position.
Good luck.
Hm again lol. Lot of variation. Does anyone actually have one that they use and own so I can a better idea?
/ Mf model 41 sickle mowing angles??? #5
I've had a couple #41's over the years. (Bought to re-sell) Used 'em just to check 'em out before selling. I don't know what the maximum up/down cutting angles are, but I do know they'll work at something close to a 45degree angle. (I used 'em to mow pond banks)
Decent mower, but parts are kinda hard to come by. Vermeer made them for Massey.
/ Mf model 41 sickle mowing angles??? #6
Good luck.
Oops, made a mistake. The +/- 7 deg refers to the angle of attack of the mower bar measured around a line parallel to that bar. It's not the angle you're interested in for mowing ditches. In fact, there's no information in the MF41 mower manual about mowing ditches. So maybe you can adjust that angle as Ken Sweet suggests.
/ Mf model 41 sickle mowing angles??? #7
I dont know the def blow levvel but it can be ajusted with the chain it just slow in heavy hay about 4.5 miles per hours is max
WARREN POWER SYSTEM LIGHT PLANT (INOPERABLE) (A68842)
WARREN POWER...
2027 . 500k BTU Wellhead  Heaters (A67714)
2027 . 500k BTU...
2019 ALLMAND LIGHT PLANT (A67714)
2019 ALLMAND LIGHT...
Cub Cadet LT 1042 Riding Mower (A65579)
Cub Cadet LT 1042...
2017 CATERPILLAR 308E2 CR EXCAVATOR (A65056)
2017 CATERPILLAR...
WELDING TABLE WITH VISE (A68842)
WELDING TABLE WITH...
