BX1500 hydrostatic tranny prob
/ BX1500 hydrostatic tranny prob #1
UWAdventurer
The wife was cutting the lawn on her BX1500 yesterday and is slowed considerably and stopped going in reverse. Sometimes it will barely go in reverse, sometimes will speed back up. No warning or signs of problems before. Ii was researching and I am going to remove the screen and clean it, hydrostat fluid has been changed 2 years ago. Are there any adjustments that can be done? Tranny is full of fluid.
Help anyone? Thanks.
/ BX1500 hydrostatic tranny prob #2
hope you find the problem.
go to amsoil trans /hyd fluid ,it will run a little cooler and helped my gr2110c hyd.
No, I was looking at the manuals I got with the tractor, but it didn't really tell me much. Can you enlighten me? I don't have a repair manual.
Thanks.
/ BX1500 hydrostatic tranny prob #5
I'm not familiar with your machine.:eek:
But with the engine off activate the pedals looking to see if anything unusual is happening, any loose parts hanging around or something jammed up in the linkage.:)
/ BX1500 hydrostatic tranny prob #6
Tossing random stuff at the wall... My BX24 lost most of its forward "throttle" and suddenly all of it. It was a pebble balanced on top of the fwd/rev pedal linkage just under the floor-board rubber flap. It was just managing to randomly catch a bolt head above the linkage and limit the fwd pedal travel.
Z.
I will check for the linkage when I get a chance.
I know there is a round screen somewhere to pull out and clean. Does anyone know where that is? I found some info on it somewhere this morning, but I can't find it now.
Thanks everyone.
/ BX1500 hydrostatic tranny prob #8
I have a BX1500 too and have developed a tranny problem. My tranny has a tough time engaging when trying to go backwards if on a hill or if there is a lot of resistance. It also will do it when going forward but it's much worse when going backwards. My fluid was changed 200 hours ago and I'm going to change the filter but I think that's wishful thinking. Mine has been like this for a few weeks but I haven't gotten around to fixing it yet. Report back if you figure it out.
/ BX1500 hydrostatic tranny prob #9
I have a parts diagram of the BX1500 that I use for reference in PDF format send me a PM with a e-mail address cause you cant send a file that big through TBN.
I am stopping at the Kubota dealer this evening to talk with them.
Thnaks. all.
Well, the BX1500 is in the shop and so far they can't find the problem. They said they will have to open the tranny to look at it. The pressure is lower on the forward relief valve than the reverse relief valve. The charge pressure is good. No shaving to speak of in the filter or screen. No brass flakes, etc. No whining. Dealer is stumped. Looks like more money to determine the problem.
Ideas anyone? Thanks.
/ BX1500 hydrostatic tranny prob #13
When my BX1500 trans went out it checked out fine from the outside. Kub figured it was the cradle bearing and I replaced the trans on that assumption. I havnt gone into the old trans yet.
larry
/ BX1500 hydrostatic tranny prob #14
larry
When you refer to the trans, do you mean the HST?
/ BX1500 hydrostatic tranny prob #15
Yes.
larry
/ BX1500 hydrostatic tranny prob #16
Any update?
/ BX1500 hydrostatic tranny prob #17
Not sure how they would have checked the tranny out without opening it up? Did they shake it and see if parts rattled!
If/when you do open it all you need is a metric hex adapter. Put some sort of non-maring clamp on the housing and remove the bolts. Then, plce it flat side down and slowly release the clamp. The piston springs will open the housing up. If you do it flat side down the pistons all stay in the assembly. If you don't, they all spill out and the pistons and assemblies are matched sets which creates a problem. If you take a look at the parts explosion for the HST you'll see what I'm referring to.
Just got an update. The forward relief valve is bad. The dealer says around a $1000 repair. Good news was the rest of the hydrostat looked good, no problems.
The dealer called Kubota and the cause of the valve going bad according to Kubota is the two cylinder engine vibration. Kubota said they have seen "a handful" of bad relief valves and they have all been on the BX1500.
Debating now on whether to fix it and keep it or trade it for a BX1860.
Thoughts everyone? Who has a BX1860 that can give me some pros and cons on it?
/ BX1500 hydrostatic tranny prob #19
Good info. Ill have to remember that when I open my old one. They check the tranny hydraulically by measuring various pressures from the outside. Mine was OK there -- it just didnt work.
Glad they found it. That high labor cost is why I just had my HST changed out for just a few hundred $ more.
larry
/ BX1500 hydrostatic tranny prob #20
Is that the total repair bill? If so, I'd get it fixed and keep it for sure. Also, based on my review of the WSM, it looks like you don't have to pull the HST out to replace the forward high pressure relief valve, am I correct??
JLG 1230ES COMPACT ELECTRIC VERTICAL MAST LIFT (A59823)
JLG 1230ES COMPACT...
Giyi GR87 (A60463)
Giyi GR87 (A60463)
1408 (A57192)
1408 (A57192)
2021 MULTIQUIP WHISPER PORTABLE AC GENERATOR (A59823)
2021 MULTIQUIP...
Cat CB24B (A60462)
Cat CB24B (A60462)
2018 CATERPILLAR 320GC EXCAVATOR (A60429)
2018 CATERPILLAR...
