Trailer with small diesel driving multiple things and a PTO
/ Trailer with small diesel driving multiple things and a PTO
I need some advice. I need to control engine speed somehow, I found an 8N governor. Pasted below is the link, this particular one may have problems..assume I use one in good working condition. Could I adapt this to work somehow or is there a better option? Though this thread title mentions diesel power, I will be using the inline 6 cylinder gas engine.
Questions I cant find the answers for online.
1. Will this thing do what I need it to?
2. How is the gear attached, pressed on?
3. What gear does this mesh with on the engine, crank, cam, timing?
4. How many are teeth on the governor and other unknown gear?
5. Estimated travel of rod that goes to the carburetor?
If any of you know a better way please point me in the right direction.
8N Ford Tractor Governor Used w tactometer connection | eBay
/ Trailer with small diesel driving multiple things and a PTO #52
What about an aftermarket cruise control as a governor?
You could set it up the run your desired shaft RPM in different gears for different torque load needs, or at another RPM, should the need arise.
/ Trailer with small diesel driving multiple things and a PTO #53
I like that idea. The governer then would be tied more closely with the actual need (shaft speed).
/ Trailer with small diesel driving multiple things and a PTO #54
I vote for a diesel powered generator and electric machinery. The line shaft has been around for ever but not sure that's the best route in this day and age. The electric generator offers you plenty of flexibility and endless configurations.
Now if you are doing this for a conversation piece well...
Excellent idea! So simple but perfect for this use. I will do some research on what speed drop is required before accelerating
I am due an upgrade anyway of these things Im planning to install. If I just bought what I needed without building this ...the welder/generator and pressure washer would be gas powered. The hydraulic pump is something new to me and would need to be gas powered. The air compressor would be electric.
I havent done the math but the prices for those items (each with its own engine or motor and wheels, frame etc) would likely exceed the build price for what I have in mind. I would only have to maintain one engine, which was in production for decades so parts are readily availible. I can have a large tank for my pressure washer and not have to be tied to a garden hose. And it would make a good conversatin piece :laughing:
/ Trailer with small diesel driving multiple things and a PTO #57
I used to run a step van for my construction business but I eventually realized that 9 times out of 10 I only needed one or two of the hundred tools on any given day.. sounds like a fun project tho..
/ Trailer with small diesel driving multiple things and a PTO #58
The Batman utility belt will only go so far. Sometimes you gotta bring the whole durned cave.
/ Trailer with small diesel driving multiple things and a PTO #59
Thank you for your service for us. On the governor you need to look at old construction equipment, a lot of them used Chevy, Ford, or I-H engines. Some of the old trucks used in city delivery had air brakes and had compressors mounted on the engine. I have seen guys use old A/C compressor mounts to mount an air compressor and used an electric clutch to turn it on. On the hydraulic pump there are engine belt driven units, Dewee is one that I remember but there are others. I have thought of doing some thing along the same line. Be safe as you can.
del10820
/ Trailer with small diesel driving multiple things and a PTO #60
Wait, wouldnt the truck engine have had a governer?:confused:
500BBL WHEELED...
2017 Ford F-550 Signalier ATR 45ft Bucket Truck (A61568)
2017 Ford F-550...
2017 Bobcat E55 (A60462)
2017 Bobcat E55...
2006 GMC C5500 4X2 BUCKET TRUCK (A59906)
2006 GMC C5500 4X2...
CFG Industrial H12R (A60463)
CFG Industrial...
2015 JOHN DEERE 35G EXCAVATOR (A52707)
2015 JOHN DEERE...
