Dump trailer brake is locking up
/ Dump trailer brake is locking up #1
andrewj
South Carolina
JD 5105
Hi folks - I have a nice PJ dump trailer I bought from a friend who just never used it that much. He lent it out to some folks and got it back in worse shape. One of the brakes locks up every time you apply hte brakes. Not sure where to start diagnosing this. Can anyone steer me in the right direction? Thanks.
/ Dump trailer brake is locking up #2
is this an electric brake machine?
have you pulled that wheel to see if that brake is adjusted too tight?
is it dragging any when not engaged?
some people chamfer the leading edge of the shoe to keep it from agressively locking when energized.
post back.
soundguy
/ Dump trailer brake is locking up #3
Either the brake controller is set to high and only one brake is working, or someone adjusted on side to tight. Hard to say, is the other side working at all?? Maybe just need to take apart and cleaned, since it has setup like you described.
When I hook up my GN after it sets up, they seem to be real sticky at first until the brake pads cleans the light film of rust off the brake drums. There are alot of knowledgable people on here that can help.
/ Dump trailer brake is locking up #4
Yup, sometimes you just have to take it apart to see what is happening. Sound advice from the previous posters, not much to add.
/ Dump trailer brake is locking up #5
ditto what the other posters said.
controller may be set high, one brake locking and the other has a bad magnet or loose wire / poor connections..
jack up both sides and have a helper pushing the panic button as you spin them by hand when diagnosing.
soundguy
/ Dump trailer brake is locking up #6
Based on a used trailer, and how you say others were rough on it, I would start by putting it on jackstands.
I have Dexter axles on all three of my trailers(5th wheel, flatbed, and utility). The manual says to repack the bearing yearly or 12,000 miles(whichever comes first), the brakes adjusted every 3000 miles, or less depending on use.
To do the bearings, you have to pull the hub/drum anyways. Inspect it all.
http://i.b5z.net/i/u/1080235/f/Instruction_Sheets/059-831-00A.pdf
http://i.b5z.net/i/u/1080235/f/Brake_Resources/Electric_Brakes_Troubleshooter_8-09.pdf
/ Dump trailer brake is locking up #7
If the simple stuff checks out 9 times out of 10 I run into this its a bent spindle/axle. Happens more often than you think. Good strike on a curb will do it every time if loaded.
Let me guess, right front????
Chris
/ Dump trailer brake is locking up #8
Check for a leaking seal too. Grease getting on the linings can make them lock up.
2022 EZ-GO ELITE...
(6) 150 TON MOVERS (A64280)
(6) 150 TON MOVERS...
2015 Cat D6T LGP Dozer (A62679)
2015 Cat D6T LGP...
2017 Nissan Altima 4 door (A63689)
2017 Nissan Altima...
UNUSED WOLVERINE QUICK COUPLER 1 (A64281)
UNUSED WOLVERINE...
2015 International WorkStar 7500 T/A Dump Truck (A61573)
2015 International...
