Hey you Geometry whizkids...
/ Hey you Geometry whizkids... #1
Haywire
Central Kentucky
Tractorless :(
Can you solve for A? This is a roofing question. --Ian
attachment.php
/ Hey you Geometry whizkids... #2
12.69"
/ Hey you Geometry whizkids... #3
Not too hard.
/ Hey you Geometry whizkids... #10
You all get F's.
You're suppose to show your work.
A = 6' / Tan(80) = 1.058'
1.058' * 12"/1' = 12.7"
/ Hey you Geometry whizkids... #12
When I was in school the solutions shown here were considered to be trigonometry rather than geometry.
/ Hey you Geometry whizkids... #13
The answers given for the problem as stated are correct. However this was offered as a roofing question and 10 degrees seems a little unusual to me, it works out to a 2.116 / 12 roof pitch. Is this angle/pitch correct?
/ Hey you Geometry whizkids... #14
Not a hard trig problem, you got lots of folks with the right answer. But, it does seem like a low pitch roof, and most roofing I've done, I pretty well eyeball this stuff. Maybe use a framing square?
/ Hey you Geometry whizkids... #15
My house and barn metal roofs have 4/12 pitch. We have significant snowfall in the winter.
It was eyeballed instead of calculated. Snow isn't a significant factor here. I'm building a small chicken coop next to my wood shed and want the roof pitches to match approximately. I'm not much of a carpenter, geometry class was 25 years ago and I never took trig. :laughing:
Ian
/ Hey you Geometry whizkids... #18
The length of B is approximately 6.0925596713144699114053061099508 feet.
Or about 6' and 3/32 inches. << EDIT...previously incorrectly said 3/16
LOT LOCATIONS (A59914)
275 Gallon Cage Tanks, Koser Safe, with 2" outlet (A62679)
275 Gallon Cage...
Buckhorn Poly Bulk Feed Box (A66408)
Buckhorn Poly Bulk...
John Deere 2640 Tractor (A62613)
John Deere 2640...
2011 Ford E-350 Passenger Van (A64556)
2011 Ford E-350...
Fencing Wire (A62613)
