Rotary Cutter pto shaft cover chains??
/ pto shaft cover chains?? #1
rongrzywacz
PA - Lycoming co.
ford 2N
Just bought a used king kutter rotary mower. There is a plastic cover on the PTO Shaft with a couple of small chains on it. Are the chains supposed to be connected when running it? Or does the cover spin with the shaft.
I didn't see any reference to these chains on the manual that i downloaded.
Thanks for any info
/ pto shaft cover chains?? #2
Yes, they are used to keep the plastic cover from spinning, there is a pretty long thread on it somewhere.
/ pto shaft cover chains?? #3
Thanks for any info
Secure the chains to some stationary part, such as the toplink. Just be sure that they are not pulled too tight as the TPH is raised and lowered.
Since it sounds like you may be new to the PTO in general, be aware of two things:
1) The PTO shaft, as you already have figured out, is extensible.
1a) If the shaft is too short (i.e., there is insufficient overlap), the two sections can separate under load and the end connected to the tractor will swing around and beat the crap out of everything within it's reach, often breaking internal PTO parts in the process. There is almost no way that this situation ends without significant expense.
1b) If the shaft is too long (i.e, there is too much overlap), the compressed length may be too long when the TPH is in certain positions (generally at the highest raised position). If this occurs, PTO housing and bearing damage is almost a certainty, since the TPH will be putting a huge axial (end) load on the PTO shaft carrier bearing. In other words, you'll be be in effect trying to push the PTO shaft into the back of the tractor transmission housing -- with enormous force due to the geometry involved. If you are lucky, you will break the housing/gearset on the attached implement, which is the "cheaper" end. If you are not lucky, you are going to have write a huge check to your tractor dealer.
The summary of part 1a and 1b is that the shaft length must be optimized for the application -- not too short, and not too long. Either extreme can get really expensive, really quickly. Note that there are several "how-to's" on Youtube for correctly determining PTO shaft length.
2) The PTO on a tractor and the attached shaft/equipment should be treated with utmost respect and caution. Many, many serious tractor-related injuries are a direct result of contact with the PTO shaft and attached equipment. Exposed rotating PTO elements can grab loose shirts, gloves, and so forth; the result being dismemberment or death. For this reason, keep all safety equipment (like the PTO shaft shield you asked about) in place, and keep children/pets well away from operating equipment.
Wrooster
/ pto shaft cover chains?? #4
Interesting...I've noticed the chains, but have never hooked them up.
/ pto shaft cover chains?? #6
Ok so my cover chains broke the plastic loop on the cover where they attach. Is this common? What do you guys do if/when this happens?
/ pto shaft cover chains?? #8
Wrooster
Very nice summary of this really important topic!:thumbsup:
/ pto shaft cover chains?? #9
Chilly great info. I for one think they are a good safety measure.. Although mine sometimes arent chained stationary. But they do spin freely ..For me this shaft cover is money well invested..I saw a chipper commercial video the other day and the chains werent hooked. they were spinning around just looking for something to grab onto. I wonder if the small plastic ring on the shafts are purposly made cheap so that they would shear off also if the chain should come loose or not be hooked.
Example. If the sleeve became stick to the shaft. and the chains loop didnt bend? Something has to give..(the chain atachment spot seems so fragile)
/ pto shaft cover chains?? #10
Now that is the answer I've been looking for. I wondered why they were so chintzy, and you're exactly right. They're meant to break before the spinning chain sucks you into the shaft.
Sean
/ pto shaft cover chains?? #11
Look for someone that took theirs off. Or run it without.
/ pto shaft cover chains?? #12
Hasn't happened yet, but would probably punch a couple of holes in the belled portion of the shield to make an attachment point - or use a washer reinforced pop rivet to attach a metal clip for the chain connection point ...
Nick
/ pto shaft cover chains?? #14
Chilly807,
Well that's sure a thought!! All my previous experiences with pto's were of bare shafts rotating furiously and we "Knew" to stay away from 'em!
I'm new to shaft covers over PTO's - and on all of my pto driven equipment I've seen those plastic grease nipples...I just thought they were meant as reminders that there was an actual grease nipple hidden underneath that needed to be greased. Is that not the case??
If you do/should/ or need to - grease the plastic nipples - ...what do you use?? or recommend?? Surely it shouldn't need actual thick u-joint grease?? I never once thought about providing any type of lubrication to those plastic//fake nipples...but you've surely got me pondering that fact right now!
Any of your past experiences with this issue are appreciated. Thanks, Greg
/ pto shaft cover chains?? #16
Chilly807
You're certainly right. I learn sumptin' new everyday. I don't know how I missed seeing that in my equipment manuals, but I must have. Thanks for clearing up my misconception! Greg
New/Unused Wolverine 84in Dozer Blade/Snow Pusher (A65583)
New/Unused...
New/Unused Wolverine 72in Tiller (A65583)
New/Unused...
New 31X13.5-15 NHS tire on John Deere 8-lug grain drill/air seeder rim, Coal Valley, IL (A65640)
New 31X13.5-15 NHS...
New Holland 492 Haybine (A66408)
New Holland 492...
New/Unused Mini Skid Steer Mounting Plate (A65583)
New/Unused Mini...
UNUSED INDUSTRIAS AMERICA HYD POST PULLER (A60430)
UNUSED INDUSTRIAS...
