Welder suggestions
/ Welder suggestions #1
tooln
North Central WI
Kioti DK45SE-HST
I'm looking to buy a welder for home. I'll be doing nothing heavy with it. Up to 1/4" would be the max. I've used a 120 volt Miller for TIG welding in the past and it worked slick. I've been asking around for suggestions on a MIG 120 volt unit. Most people tell me don't even bother with a 120 volt for MIG as it will be to small for anything but sheet metal. Does anyone have any suggestions? Does anyone use a 120 volt for MIG if so what size and make. Does it work for you? I finally found me a good usable ezee flow drop spreader and I'm going to cut it down to 6' wide for my food plots. Thanks
/ Welder suggestions #2
I'm one of the ones that would say to stay away from the 110V models. For body work they can't be beat so they do have their place but I wouldn't get under a 180A model. There's going to come a time when you want to weld something heavier and the small machine just isn't going to cut it. My 2 cents worth.....Mike
/ Welder suggestions #3
Northern Industrial 125 Flux Core Welder | Wirefeed Welders | Northern Tool + Equipment
I have this, I really have found it to be easy to set up and use. I make tow behind tractor toys for my daughter. The frames are 1/8'' angle iron. The welder is perfect for this and if property preped I am sure I could do 1/4'' I went with the welder I would use most, and compared it to what was in my wallet. When I did this model was tops for me. It came with the 10lb spool attachment so i havent had to swap out a spool yet.
I shopped for about 2mts before I bought this one. I looked at all the name brands, recondidtioned etc. I am very very happy with this model.
/ Welder suggestions #4
Miller autoset 211
115v and 220v
Portability of a small machine with performance of a bigger unit!
Also available as an option is an aluminum spool gun
No I don't work for or sell Blue but do think this would fit the bill
/ Welder suggestions #5
you might get by using fluxcore .i would get one with at least 140 amp .i have used lincoln and miller i would recommend them.220 is better.hobarts were on sale the other day at tractor supply.
/ Welder suggestions #6
ericher69 said:
Miller autoset 211
115v and 220v
Agreed. I have a 211 and it is great. It's big enough for what I need and will still run on 110 if that's all I have to work with somewhere. I got a pretty good deal on eBay for the welder, spool gun, and a little tackle box full of consumables.
/ Welder suggestions #7
Miller autoset 211
115v and 220v
I have one and weld sheet to heavy stuff around the farm and it does the job! Have a tomb stone also and use it on breakdowns in the field with a generator!
/ Welder suggestions #8
I'll have to agree with the Miller 211.
The option of 220v or 110v is very apealing to farm/ranch work. A great companion for the Miller 375 Plasma Cutter that is also a dual voltage unit.
However I still keep the o'l arc welder to do the heavy repairs...
Looks Like I'll end up spending more than I really wanted but it will work for me. I'm leaning between a Millermaticョ 211 Auto-Set with MVP or a Hobart Handlerョ 210MVP, with Multi-Voltage Plug. Over the weekend I'll shop around on-line & once the Holiday is over I'll go to my local supplier and see what kind of deal I can get.
/ Welder suggestions #10
Lincoln is running a special on the 140c for $600.
/ Welder suggestions #11
I have a Miller Passport which is pretty much the same as the Miller 211 but adds portability. It has an inverter power supply and gets more performance out of 110v than any other Miller as I recall. Very nice welder especially if you intend to use it in different locations. I forget the weight but it feels like a fully loaded roll-aboard so probably forty pounds. That includes the internal paintball CO2 cartridge. The only downside is cost. I got mine as a demo model which helped.
I don't quite understand the role for the 211 as it is too big and heavy to throw in the truck and move easily. If you use it in a shop then you either have 220v or you don't so why do you need dual voltage?
I'm looking at the dual voltage as I currently do not have 220 in my garage. I will some day. I also have a 120 generator that I take to my hunting land. I have had times had to disassemble something to bring back with me to have welded. 74 lbs is not to heavy to through in the truck.
/ Welder suggestions #13
I don't doubt the quality of the 211 at all but would be concerned that it is really not designed for field work and also that using it with a generator and fluxcore means you won't be getting much more out of it than you'd get with barebones 110v fluxcore machine. Why not pick up a used boxstore 110v fluxcore feeder for your current and portable needs now and then add either the 211 or 210 equivalent down the road as a dedicated shop welder. 75lbs may be manageable but the 211 is not engineered or built to withstand banging around in the back of a pickup. Alternatively how about a small inverter stick machine like the Thermal Arc or Miller 150 which are functionally just as powerful if not superior to any wirefeeder in the field with a smallish generator. Even HF has a decent inverter 110v stick unit that sells for about $150 if I recall.
/ Welder suggestions #14
Hadn't found a steel job I couldn't do with my tombstone or my 130 amp Ford alternator hooked to a Briggs......
/ Welder suggestions #15
I agree that the 211 isn't the be-all/end-all welder, but for $1300 I got a unit that runs on 110-230 volts, is portable enough for occasional jobs not around the shop, will run solid wire, flux core wire, and aluminum wire, and has a regular gun and a spool gun.
I plan on getting some more equipment this summer so I can run stick, tig, and plasma, but for now I can get just about anything done well enough with the 211 and an angle grinder.
If I planned on portable use more often, then a suitcase sized machine might have been my choice, but I'll be in my own driveway and garage 99% of the time and in that environment I prefer a traditional looking machine on a cart. As for durability and protection in transit, a moving blanket in the back of the jeep will keep the welder just a safe as the EPS packing material that Miller had in the box, and I will certainly be more gentle on it than the guys in the UPS hub were throwing it in and out of trucks and on and off conveyors.
As with most other things we discuss here it's a compromise of price, features, versatility, quality, and price. (yeah, I know I said it twice)
Sorry for the run-on sentences, this darn sinus infection is taking its toll on me.
/ Welder suggestions #16
Most of the people you hear degrading the capabilities of the 110v Mig really underestimate the value of multiple passes and weld bevels: in other words, you can weld some pretty major stuff with them, if that's the only machine you've got. Beyond that, it's hard to argue with the convenience of them: take 'em anywhere, plug 'em in anywhere, even run them on small generators if you want.. I've got several bigger machines now, but I welded a heck of a lot of different equipment with that little Lincoln before I upgraded. If you can afford a bigger one, and KNOW you're only going to be in a shop, I'd definitely get something bigger, but the 110 machines aren't just a toy like some try to frame them as..
/ Welder suggestions #17
Another vote for the Miller 211. If you can figure out some way to get 220 to it, so much the better. I love mine.
/ Welder suggestions #18
I was confused about the weight. I had the Miller 212 confused with the 211 in terms of size. 174lbs is not a great portable machine but I agree that for occasional use a 74lb machine is not a big deal.
/ Welder suggestions #19
My suggestion is to by a 110v mig welder with variable amp and wire speed that can run both gas and gasless at least 125 amp. Then by a used 220 volt stick welder, usually can pick them up all day long from $75 to $175 for the stuff over 1/4". if you have enough money then go for a used a/c-d/c stick welder. D/C stick is a little nicer looking weld.
When I built my Cad Digger Back hoe I would tack with mig and them weld thick with stick.
I did body work for 30 years and built many projects that way. I self tought myself how to stick weld by reading and practice.
Look under arkydog here to see pics of the backhoe I built. I guess It is the best testimony as to what to buy. My 110v welder is a lincoln sp125 and my 220v is a lincoln 225 a/c-d/c. Don't buy a cheep 110. I used to use miller at work and loved them but I also used lincoln, both the same only different. Also I know for a fact that the older sears and craftsman 220v welders were made by lincoln, very reliable and copper wound.
rob
/ Welder suggestions #20
I agree 210 volt is a must regarding a mig.
I wont recomend a model as I have had the same welders for years my newest one is 10 years old. That said, dont buy a cheap welder. Over 20 years ago I started off with a used lincon tombstone welder. It was used regularty at first then a dozen times a week until about 1998 when I bought a hobart 175 which at that time was identical in parts and construction as the miller of equal size. It even came with a miller gun and internal parts have miller name on them. About 3 years ago My Lincon finally went south and I bought a hobart LX, It has been a fine welder for the amount of use it recieves.
All I am saying is buy good equiptment and it will last. I havent looked at new welders in so long I diddnt know the 211 existed last time I saw one it was a 210 but after looking at that model I would be hard pressed not buying it if my hobart went down.
Oh and some folks dont concider hobart quality cause it aint blue (lol) but mine has never needed more than tips wire and a couple new liners one of which was split in the middle from use, no wonder the wire wouldnt run smooth. All are reasonable fixes. My toumbston ran flawlessly for years until a resistance problem finall did it in and it would get really hot and trip off.
