Loader L2500DT loader
/ L2500DT loader #1
carlav1410
Mt Airy NC
Kubota L2500DT 4X4
Hello all Again,
I Have got a L2500DT and have a chance to buy a loader LA450A for 1k that need lift cylinders and lower mounting bracket.
Also tried to find lift capacity for it but all i can find the La450 model not the LA450A.
Can someone tell me what the lift capacity is and is it worth 1k to buy?
Thanks to all for your Previous help
/ L2500DT loader #2
Most likely, it would lift 800-1,000lbs. Loaders usually run $3,000- $4,000. So $1,000 seems like a good deal....assuming you can find the missing parts.
/ L2500DT loader #3
i agree- lift would be around 900 lbs -thinking thats what book said. about twice the model number-1000 i is a really good deal if it isn't damaged-wondering why someone took it apart- these things aren't usually parted out.
/ L2500DT loader #4
LA450 capacity is around 1000 lb (450kg x 2.2 lb/kg = 990 lb). Which "lower mounting bracket" is missing? This loader has bottom cross frame that's pretty important. There's a thread here that has a couple pictures of one. The cross-frame has sockets for attaching and detaching the loader. It's maybe $500 or more new - if available. If that's what's missing, I'd pass. There's still too much needed for a complete loader.
/ L2500DT loader
Thanks to all
I did price and WOW will cost me almost 3K to fix it up (parts replacement)
Now I need to make up my mind????
Thanks Carl
2004 GMC 5500, Duramax Diesel Truck Vin# 1GDE5E1234F520387 (A62679)
2004 GMC 5500...
1994 CHEVROLET GMT-400 EXTENDED CAB TRUCK (A65054)
1994 CHEVROLET...
Ford 8N Tractor (A66408)
Ford 8N Tractor...
Bandit Wood Chipper (A62613)
Bandit Wood...
CHANDLER 500 BBL FRAC TANK (A65643)
CHANDLER 500 BBL...
NEW ATS-SP100 100 Ton Capacity Shop Press  (A62679)
NEW ATS-SP100 100...
