chainsaw problem
/ chainsaw problem #1
stonington
century 28hp
I have a problem with a 72cc Husky that I read several similar posts on this website............won't start when hot. I'll try the suggestions given and report back. Thanks
/ chainsaw problem #3
My first Husky needed a "heat kit". The fuel would vapor lock when it was hot. The kit isolated the carb from the block and kept it cooler.
/ chainsaw problem #4
Hello & WELCOME to TractorByNet.com! :)
I have moved your thread to the Chainsaws Forum. You'll get a better response there. ;)
/ chainsaw problem #5
Is the carb heat flap turned to winter (open) in the air filter housing needs to be closed.
If so it will boil the fuel in the carb in warm weather found that out a week or so ago on my 346.
Scared the crap out of me when she died I could smell it was leaning out man I thought I sneezed it but it just "ran out" of fuel its ok now. good luck
/ chainsaw problem #6
What saw was this on?
Unverferth Field Cultivator (A64127)
Unverferth Field...
New 5/16" G80 Double Chain Sling (A62679)
New 5/16" G80...
Stertil Koni 18000lbs 4-Post Auto Lift (A61572)
Stertil Koni...
International 806 Wheatland Tractor (A66285)
International 806...
2016 CATERPILLAR TL1055D TELESCOPIC FORKLIFT (A64279)
2016 CATERPILLAR...
Oxy-acetylene Torch and Regulator Rig (A63689)
Oxy-acetylene...
