Acres cut per hour
/ Acres cut per hour #21
12-15 inches tall is simply too tall for a finish mower if there is any thickness to it at all. If you want to do a crappy job, then use a finish mower. With that height you are better off with a bush hog type mower. I use a 12' Befco finish mower on my hay fields in the spring to trim them back about 2 or 3 inches, and 4 mph is very optimistic if you need to do a good job. If quality does not mater, balls to the wall and let stuff clog and break. Finish mowers are meant to cut lawns, ie cut off 2 or 3 inches not 12-15. Bush hog made a bat wing that had counter rotating blades on each spindle to mulch stuff up. Kind of rare to find, but it would do the job you want in one pass, but it takes better than 100 HP to run it right.
/ Acres cut per hour #22
builder
I haven't ever had one but it seems as if the woods 990 might be a good match for your needs. It is a finish mower but has free swinging blades like a hog. They are pricey though
Woods Equipment Company - RM990 series 90?
good luck
the wind
I've run one of those with 75 PTO HP for over 5 years with zero issues. The gearbox is rated for 75 hp. I set my PTO slip clutch to 40 hp and have only seen it slip once or twice. I've mowed anywhere from 12" or so to weekly 3" mowing that looks like a fairway. Without a doubt, the best mower for a bush hog/finish mower hybrid.
/ Acres cut per hour #23
i agree, 18" tall grass is rotary cutter territory
then finish mow it after it's cut down to a reasonable length.
8' mower: 3 to 4 acres an hour
15' mower, 7 to 8 acres an hour
3mph for rotary cutting with a 70hp 8' is awful slow. I cut at 5mph with a 15' mower with 70 hp. 6mph when I had an 8' mower. (it would go faster, but it beat me up too bad going faster). (although, your grass may be thicker than it is here, but even in really thick thick wet grass I only gear down to about 4mph with the 15' rotary cutter and it plows right thru that.
I think there's a lot of subjectivity to conditions here. When I hog, I'm going 3MPH. Some of my customers wait until weeds are 6-7' high and 1' thick. If I go faster I get windrows & stragglers. I don't like going over work twice. 3rd gear low range seems to be the sweet spot. 4th gear low leaves more than I like.
I think just the fact that you're able to use a 15' batwing with a 70HP tractor proves your cutting is lighter than mine. If I ran a 15' bat through the crap I have to cut, it would look bad. Now if I'm cutting 12-18" pasture grass, I can move faster and use 15' mower.
Can you get 12" tall grass to look like a lawn if you use a bush hog, not a finish mower?
/ Acres cut per hour #25
Thanks FWJ. Anyone think 4MPH is a reasonable speed mowing 12-18" tall pasture grass with a 8' finish mower behind my M-7040?
I usually only do bush hogging. When I bush hog, I go ~3MPH with an 8' bush hog through 5' tall weeds, but it leaves some sticking up here & there.
According to my calculations. I should be able to cut 3.8 acres/hour at 4MPH w/ 8' finish mower. I would reduce that to 3 acres per hour to account for turns. So I should be able to mow 20 acres of light pasture in under 8 hours with a 8' finish mower if I run at 4MPH.
Sound plauseable?
I pretty much got the mowing contract, now I gotta find a big finish mower. Flail or finish is the next step.
A few comments:
1) Calculations will only give you a VERY rough idea. Cut it once and you'll know the truth of the matter.
2) Don't know what sort of finish mower you plan to use but let me mention:
a) Finish mowers used in 12 to 18" high pasture grass, if it is heavy, are not the right tool. The slightest amount of grease on a belt and you'll burn up a belt, etc.
b) suggest mow the 20 acres first with your hog and then use the finish mower when the grass is much shorter. After that it will look better every time.
c) By the way, a bush hog with sharp blades will do a surprisingly good grass cutting job if the customer expectations are not too glorious.
3) Depends a lot on what the customer wants ! If the customer is expecting lawn-quality finish mowing you are going to have to mow more often, etc. The fact that they are asking for "finish mowing" may imply higher expectations.
4) Once you have this place cleaned up and cutting becomes routine, I think you can do a good bit more than 4mph.
5) You can certainly mow 20 acres in 8hrs with just about anything 8 feet wide. The question is more what will it look like, will the customer be pleased, and how often do you have to do it ?
6) By the way, I'm a little puzzled: You mention an 8ft bush hog ? 8ft hogs are not common. Also 8' finish mowers are usually gang mowers or multiple units of some sort.
7) What kind of land is this ? Hilly, flat, rocky, heavy growth in an area with lots of rainfall ?
/ Acres cut per hour #26
Builder,
I was curious what your cut height plans are? If you are trying to get results similar to a finished lawn then it will need cutting more frequently. No way can you cut 18" grass down to 3 or 4 inches without making it look like stubble. So for the initial cut I would use a brushhog then use a finish mower thereafter cutting no more than 1/2 of it height at a time. On my own lawns I try to maintain about 4" mowing height and cut it when it averages 6 to 7 inches. I know you are familiar with all of this but you need to make sure the property owner is on the same page.
/ Acres cut per hour #27
That is a great mower, but it won't handle my M7040's power output. The 990 is maxed-out at 50HP. I'm 70 engine and 61 PTO.
I'm gonna try either my MX-8 with really sharpened blades or I have access to a 15' finish batwing.
Pardon my nerve to say so, but I think you are under a misconception of sorts. There isn't anything wrong with operating an RM990 mower that needs less horsepower to run than your 7040. It's always good to roughly match the size and hp requirements of the implements to the tractor but not like it's a hard/fast requirement. Just don't floor your 7040 all the time and you aren't putting out 61 PTO hp anyhow. The only "danger" or concern might be that you have the hp to potentially do damage to the 990. If you don't try to overload the mower in very heavy deep grass, etc. and then force the issue with more horsepower, I don't see a problem. Another thing to note is that the RM990 is 7.5ft cut, not 8ft. As someone else mentioned the flail type blades on the 990 make it much more durable in rough cutting. Note also that the gearbox on the 990 is rated at 75hp. so I interpret their "25 to 50" hp range of tractor as a nominal recommendation. Just my opinion. [Now if you were going to turn the machine loose with hired hands that you barely know ... whole different ballgame.] By the way, I like Landpride a bit better than Woods for finish mowers. Landpride makes 8 and 10 ft versions in both medium and heavy duty flavors and with flail type blades... and they will handle far more hp too.
/ Acres cut per hour #28
Your about right here with the 15 ft cut. We just took in trade a 15 foot TD-1500 bush hog with fifty horse on it and I'd say you are right for what I've seen with these in my area. I played on five acres and with a lot of trimming I was back in less then an hour.
/ Acres cut per hour #29
I would give the MX8 a try. I mowed out by my mom's flower beds with my MX6 on my Kubota L 5040 and was quite please with the cut. Really couldn't tell the differnce from the Grasshopper ZTR (dull blades) except for a very small windrow that dissapeared after the first little rainshower. The MX 6 leaves it looking like a lawn so try the MX8 a round or two. The grass was about foot tall fescue. I then mowed a rough field with 4 and 5 foot tall weeds and again was pleased with the appearance of the field with the MX 6. As to speed of the cut, much I think would depend on the shape of the field. A long narrow field will cut much faster than a square one with all the turns at each corner.
/ Acres cut per hour #30
Builder
At the farm we have a newer John Deere Batwing brush rough cut mower we ussually pull it with a 225hp but you can pull it with alot less. It has 1000pto set up and has a double set of blades on it were a regular brush mower has one set. It is suppose to be for chopping stalks at about 7-9mph. But have found it leaves the waterways like a lawn even if we only hit them once in late summer. We use to have a 15 foot flail mower but to didnt do as good as this new mower.
Point being look for a good batwing with a double set of blades or see if the mower you have can add this options. I will try to get photo next time we have it out which will be awhile as got a 6 inch rain last night and some areas got over 10 inches
/ Acres cut per hour #31
That's the EXACT formula.Gotta love the English measurement system. An acre is 1 rod (16.5 feet) by 1/2 mile or 1/2 rod (8.25 feet) by 1 mile or 43,560 sq. ft. And of course there are four rods in a chain (66') which are the width of prairie road allowances (except they are 1.5 chains in some places). .:confused2:
They converted to a decimal system in 1971.
NO wonder!:laughing:
No misconception. I know exactly what you mean. Someone suggested a woods RM990. My dealer's policy on equipment is that too much input would present problems if a warranty situation came up. I'm not looking at a new RM990 anyway. Landpride is the way I'm going if new, but I doubt I will.
At the present, I have access to a 15' woods finish batwing, which might be too big for the pasture to turn around without turf damage from R-1's.
A few comments:
Perhaps a little backround. This is not my first customer. I have several larger parcels I already cut, but only one is a "finish" cut of 9 acres. I do this with my BX2200 because it's too tight and tree laden for a bigger tractor. The above described 20+ acres is all finish grass.
See John Deere MX-8 below. Around here 8' mowers are very common. Finish mowers are usually 7' or 7.5'.
open, but rolling with average mid-atlantic rainfall.
Builder,
Yep, got it. Since the customer just got rid of their current cutter, the grass is now about 12" high. It'll be 18" by the time I get to it. My plan is to go in with MX-8 and SHARP baldes and tell them clippings will be present after this cut. Then I want to come back in a week later and finish mow it. I'm just trying to decide between ~8' fixed deck or a 15' finish bat I have access to. Either unit would have to be used. Not dumping big dollar into a finish mower for one 20-25 acre customer.
They are picky. The helicopter on the landing pad, the farm manager in nice clothes and the 100K cars led me to believe this. So I do need a nice cut and I can tell previous cuts were well done.
/ Acres cut per hour #35
Oh, you should have said it was my place..., I'll buy you the mower, just put it on my account. Get two. :laughing:
/ Acres cut per hour #36
Builder,
Sounds like a plan, my concern would be tracking it up with the heavy tractor and ag tires. Sounds like a good customer to cultivate too, from your description I'd bet that any real work is farmed out. Might be another full service customer in the making. Good luck with it.
FWIW, an x748 with the 60" 7 iron deck @ 6mph could cut this in about 7 hrs at 80% efficientcy. This assumes cutting on a regular basis, not the initial cut.
Builder,
Yeah I even contemplated cutting it with my BX2200 with 60" deck. it does a real nice job, but 20+ acres with a 60" deck would be an azz-beatin' by the time you're done. I was going to suggest mowing about 4 passes on either sides of the fence, then doing a rougher bush hog-with-sharp-blades-finish-cut on the inside, but they don't seem like the type to listen to suggestions. :laughing:
100% agree on the "customer to cultivate". Sick wealth. I thought I was doing pretty good.......:laughing:
/ Acres cut per hour #38
I have a BX2200 too. I'd think once you have the taller grass beaten into submission with bigger machines the BX2200 makes a nice touch up and between-full-mowings machine. My BX2200 has a great PTO driven 3 bag bagger but hopefully no body is going to get into bagging 20 acres !
Thinking about your customer, I would bet that if you make a good showing of being out there doing something frequently (and frankly making it look nice no matter what you do it with) they will become a fan club of yours. That tends to happen.
By the way, if the grass was very high to start with (anything over 8 inches or so) my newer 7ft Bush Hog (model 297) does a cleaner, nicer job than my Landpride 6 ft (model 2572) finish mower.
/ Acres cut per hour #39
that's what I would do. and charge for both cuttings. On the plus side, you'll find everything "interesting" with the rotary cutter and not the finish mower.
. Not dumping big dollar into a finish mower for one 20-25 acre customer. They are picky. The helicopter on the landing pad, the farm manager in nice clothes and the 100K cars led me to believe this. So I do need a nice cut and I can tell previous cuts were well done.
Sheeeet. make it worth your while. if they want to pay for a new mower (priced accordingly) I am HAPPY to do just the one customer. 20 acres once a week finish mowed and priced "well" would easily pay for a big mower by the end of the season. Everyone else is profit.
No, I'M paying for the mower. They pay for the mowing.
I agree with your view on it, but I'm walking in with 1/2 the mowing season over. Also, grass tends to slow down and turn brown in July/Aug so cuts may get much less frequent.
Just curious: What can you guys command in price for say 20 acres of nicely clipped pasture, 5,000 feet of split rail fence and maybe 100 assorted trees, stone barn ruins, etc.? My bid's already in, but just curious. I charge ~$60/acre to bush hog. What do you pay a weedeater operator?
STIHL FS80R POLE SAW (A64276)
STIHL FS80R POLE...
2025 66in Swict Bucket Skid Steer Attachment (A64553)
2025 66in Swict...
2019 CASE CX57C EXCAVATOR (A65053)
2019 CASE CX57C...
2014 Ram 1500 4x4 Crew Cab Pickup Truck (A64556)
2014 Ram 1500 4x4...
2006 Cadillac Superior 6-Door Limousine, Ultra-Low 20396 Miles (A63689)
2006 Cadillac...
1978 Fruehaue Chipper Trailer (A62613)
1978 Fruehaue...
