Kubotasaurus, a home built micro tractor
/ Kubotasaurus, a home built micro tractor
Are you serious dude, that thing is awesome. I just noticed the rear differential. That's a pretty big pumpkin. What did it come off of, and how did you mod it to work?
lol, it is off a 1990's ford transit van! I dont think it will break! :thumbsup:
What i did was cut the axle tubes down to length with a grinder, removed the half shafts, cut the halfshafts shorter and welded them back together (they are 1 1/4" dia, with a good weld prep on them too) so plenty of strength in them for this garden tractor! I then made some steel bushes for the shafts to run on, with brass bushes and a grease nipple, and welded a sleeve on the halfshaft (to stop it comming out) before welding the bushes onto the end of the axle tubes. Quite simple, but effective. I dont think wear will be a problem on this thing! and if it ever did wear i can always re-bush :thumbsup:
The diff is packed with grease, and there is a grease nipple on top to add more as and when required.
Very nice, I can't wait to see more.
Thanks for all the possetive comments guys! I too cant wait to see more! I simply love small usefull things like this! tonight I am going to start on the rear lift arms (the top ones) with their hydraulic ram and bearings, once that is in place i can fix the seat (as the position of the seat mounts will be very dependant on the ram/lift arms. Then i need to look at foot plates and a pedal and linkages to operate the spool valve for farward and reverse. And i think i will make my own rear linkage as any ive seen are too big for this thing, please bare in mind it is only about the size of a cub-caddet!. :tractor:
/ Kubotasaurus, a home built micro tractor #24
thanks for sharing, now we need a video of it running :)
well, that will be coming soon, i hope to get the seat on and make it more "drivable" before i make a video! (not wanting all you lot laughing at me falling off the back!)
/ Kubotasaurus, a home built micro tractor #26
Can you explain what a hi-low hyd pump is? Is it a two stage pump? What is the displacement and pressure? Are you using motor spools? Any detents on the valve? How do you control fwd and rev speed?
Hi, the pump is a hi flow low pressure pump that changes flow when the pressure goes above 50 bar (although it is adjustable) to increase the pressure upto 200 bar, with much less flow (this stops the engine from stalling) very similar to what is on most log splitters, this pump is matched to my 5.5 hp engine, with around 26 litres/min on low pressure (where it spends most of its time)
I am using a 3/8" conventional spool as it was the best price possible (free) should i be using anything different? it seems to work well with this application. FWD and REV will be on a pedal as said previously, the speed is pretty much constant, at a walking pace. I could always have a throttle from my engine if i ever needed to speed up or slow it down, but this pace will be suitable for most things, thanks for the intrest, chaffe.
Just had a thought, JJ if you are suggesting my 3/8" spool maybe a restriction? it could be, the specs on the pump are around 290rpm, and it does about half that, but the engine still loads up even if the hydraulic motor is in free air, so this could prehaps point to the valve block being a restriction, prehaps i can use two spools to drive the motor and use it as 2 speeds?!
/ Kubotasaurus, a home built micro tractor #29
There are times that you might want to go real slow, and you can do that with a regular valve, but you have to hold the lever. If your valve had three position detent, you could put it in fwd or rev detent and vary the engine rpm. If you want to use something like the valve below, you can vary the speed from 0 rpm to max rpm. Any excess fluid not used by this valve is sent back to tank. If you put a spring on this valve, you could have foot control for speed, and remove your foot and you have hyd brakes.
https://www.surpluscenter.com/item.asp?item=9-064-38&catname=hydraulic
I use one of these to vary the speed on my hyd PTO.
I am curious about the torque to the hyd motor, as the two stage pump only puts out about 650 psi in the high mode, and max GPM. If the tractor needs more go torque, the GPM's decreases, and the pressure goes to about 2500 psi.
What happens with this type of drive, is that you go from fast speed, little torque, and when the load/resistance increases, the pump shifts automatically to the lower speed, high torque mode.
Your system will work with a log splitter, but you really need a log splitter valve with reverse detent.
If what you have works for you, fine. These are just some thoughts I had
The main points are as follows; 5.5hp honda powering a matched hi-lo hydraulic pump, two gallon hydraulic resevoir, bank of four spool valves (one for forward and reverse, on a pedal, one for rear lift and the other two for extra services) A hi-torque hydraulic motor drives the rear axle via a heavy duty chain. .
I was thinking of using the sprung to centre spool on a pedal, that way i can vary the speed and direction on one pedal :thumbsup:
The spool i am using will give me hydraulic brakes and also dumps back to tank the excess i am not using, and is sprung to centre, prehaps I already have the exact same thing you suggest? I do not have any detented spools.
The good thing about the hi-lo pump is that it automaticaly "drops" downd a gear when the load increases on the transmission, quite ingenious if I may say so (and just lucky!) i hope this clarifies what i am trying to achieve, and thanks for the intrest again, chaffe
2024 CATERPILLAR 255 SKID STEER (A52709)
2024 CATERPILLAR...
Paladin 12in Digging Tooth Bucket Excavator Attachment (A60352)
Paladin 12in...
1986 MURRAY WEST COAST STYLE RGN (A60736)
1986 MURRAY WEST...
2019 International WorkStar 7300 4x4 Altec AA55 56ft. Insulated Bucket Truck (A60460)
2019 International...
1988 FRUEHAUF TRAILER OPERATION FUEL TRAILER (A60736)
1988 FRUEHAUF...
John Deere XUV825E (A61307)
John Deere XUV825E...
