Kubotasaurus, a home built micro tractor
/ Kubotasaurus, a home built micro tractor #1
chaffe
in the garage
Kubotasaurus
Firstly I would like to say Hi all, Im new here. Ive been watching in the background for a while now, but i have just joined so i can share with you my latest project. I am currently halfway through my build of a "micro" tractor, It is loosly based on the dimensions of a Kubota B5000, albeit scaled down to approx 2/3 the size!, I have also purchased the correct colour of orange and dark grey and some decals to complete its authentisity!
The main points are as follows; 5.5hp honda powering a matched hi-lo hydraulic pump, two gallon hydraulic resevoir, bank of four spool valves (one for forward and reverse, on a pedal, one for rear lift and the other two for extra services) A hi-torque hydraulic motor drives the rear axle via a heavy duty chain. The rear axle is a narrowed (26" wide) ford transit van axle. this is as far as i have got with the build so far! Ill post some pics later showing my progress thus far. Last night i test drove it back and fourth to see how fast and controllable it is, all is well.
Next on the agenda is to complete the steering (welding on the front axle pivot) and also add all the links from my steering box (off an old volvo) the seat is a brand new pressed steel item off of ebay, this too needs mounted along with a bonnet and the completion of the rear linkage. The main aim is to get it running and painted, then worry about the rear linkage, I also have a 27" wide mower deck to adapt for the rear, it will need its own engine.
/ Kubotasaurus, a home built micro tractor #2
Welcome! Sounds like a fun project - yes pictures are a requirement here:)
What do you intend too use if for? Loader?
Cheers,
mike
Cheers,
mike
Mowing the garden, ploughing the snow ai the winter and prehaps a loaader too!
/ Kubotasaurus, a home built micro tractor #4
Great work. Loving the tractor. :thumbsup:
Cheers,
mike
What if someone started a thread and said they rode their tractor naked today? Would pictures be a requirement then too? :laughing:
And No before you ask I didn't ride a tractor naked. :laughing:
Sorry about going off topic. I just couldn't resist asking this question.
Chad
Chad
cheers, ill get better quality pics up when i do some more work on her.:tractor:
Here is the pic that i base my scaled down dimensions on, the aim is to produce a robust micro tractor, that is reasonably light and small (as i have no need for anything big and heavy, after all its main purpose will be grass cutting!) The two extra hydraulic services will be very usefull for either a front loader (handy with the hydraulic drive, easy to shuttle forward and backward) or for the likes of a three point mounted log splitter, tipping trailer etc.
/ Kubotasaurus, a home built micro tractor #7
great work i love it like my project. definitely needs a loader especially as you have the parts from the backhoe
thanks!, ive made the front axle quite strong just incase! :thumbsup:
bit more done tonight;
Got the steering fitted up tonight, going to have to make a few changes, The frame on which the steering box is mounted will nedd triangulated (i had assumed this anyway) also the main frame will need relieved around the steering arm, on top of the chasis. Then i should be happy with the steering.
Got the steering working and started painting it, here is some pics if anyone is still interested?
making the bonnet today, hopefully get it on and painted over the weekend.
/ Kubotasaurus, a home built micro tractor #12
That thing is looking sharp! :thumbsup: Nice work and excellent craftsmanship! :thumbsup:
/ Kubotasaurus, a home built micro tractor #13
Wow. It's really coming along. Looks fantastic. :thumbsup:
Chad
thanks for the kind words guys! was begining to think no one was watching!
bonnet is made, and more has been painted, not much to show just now, but ive just got to make the seat mount and she will be ready for a trial "proper" drive! then the fun bit of lift linkages and loaders can begin!
And I made this :thumbsup:
/ Kubotasaurus, a home built micro tractor #15
How wide is your mini bota? What loader capacities are you striving for?
It is about 26" wide, not looking to lift much, more to use as asnow plough/bucket for moving gravel and sand maybe 50 kg payload in the bucket. The main use will be grass cutting, but it will be usefull for the veg plot and garden maintainance im sure!
Towed a 1.5 ton car out of my garage today and nothing broke :thumbsup:
wheelspin was the only problem, and that is with my fat arse on the back!
/ Kubotasaurus, a home built micro tractor #20
Are you serious dude, that thing is awesome. I just noticed the rear differential. That's a pretty big pumpkin. What did it come off of, and how did you mod it to work?
2023 Top Air ATV 200 Gallon Pull Type Sprayer with 30ft Booms (A61307)
2023 Top Air ATV...
2010 Honda CR-V SUV (A55853)
2010 Honda CR-V...
UNKNOWN  SPOOL TRAILER (A58216)
UNKNOWN SPOOL...
2012 TROXELL 130 BBL STEEL (A58214)
2012 TROXELL 130...
Ratchet Straps (A59230)
Ratchet Straps...
TOOTHED BUCKET ATTACHMENT FOR MINI EXCAVATOR (A58214)
TOOTHED BUCKET...
