Loading Turf tires
/ Loading Turf tires #1
Scotty Dive
Ct
Yanmar 2020D
I remember reading in the operation manual not to ballast turf tires. Is that really true? Does that mean loading the tires or adding ballast to the 3pt?
And if so....why isn't it a good idea?
/ Loading Turf tires #2
I don't know what the logic behind not ballasting turf tires would be. You are definitely safe to put a ballast box on the three point. Tractor tires are designed to carry the tractor with a load on the hitch.
I have ballasted turf tires before. I haven't operated them for the 30 years or more that my R1 tires have been ballasted. I don't see how there could be any issues. The general point of turf tires is to run on soft or delicate surfaces, like....turf. Heavy machines will cause ruts in the soil, so maybe the logic is to minimize rutting by keeping the machine as light as possible. You can fill a turf tire with much more ballast than an R1 tire of the same height.
/ Loading Turf tires #3
For years I had rear ballast plus loaded turfs,that extra bite of traction means lot when it comes to mower or fel use..more so on slopes.
I have slopes so its important to me. Is there any reason to partially fill a tire or should it be filled to normal capacity?
/ Loading Turf tires #5
Had my rear tire fill about 3/4...just remember when you check air pressure stem at top,than quick burst of air before taking reading. ;)
Finally got my tires and rims....just installed. I haven't tried them out to see how well they do on uneven terrain but ran them over the lawn while it was soft and wet. It was also raining - no problems, no ripping it up.
BEFORE:
AFTER]Yanmar 2020D - Public pictures by divedivediver - Photobucket[/url]
/ Loading Turf tires #7
Those sure look nice! Did you ballast them? What did you use, and how much? Let us know how you compare them for loader work, pulling ability, and so forth.
/ Loading Turf tires #8
My mouth sort of drools. Can you tell any difference with your ground speed in gears. My understanding the turfs are just a little bit smaller diameter. Just wanting first hand info whether you can tell any difference.
/ Loading Turf tires #9
Looks very, very nice. I'll have to add those to my wish list. :thumbsup:
So far I cannot tell any difference on ground speed - but I am probably not the guy to ask since I do not mow or use the tractor at consistent speeds. I did have them ballasted with 31 gallons each of rim guard. each tire/rim weighs in at 460#. I have to add that I was pretty concerned about how hard it would be to install a loaded tire onto the tractor. Even with the tires flat on the ground I could lift them vertical and roll them into place...with a little finnagling - I got each of the rears on in about 5-10 mins. Very easy for a guy who weighs in at 170 lbs.
They are a little shorter then my rice tires. I measured a before an after for ground clearance and it dropped about 1 inch. I was glad that it wasn't more as I use this tractor over rockly uneven terrain.
Also - these are 13.6 X 16 (rear) and 25 8.50 X 14 (fronts).
Next step is buying some chains for added traction in the sloppy parts of my property and for the snow....Any suggestyions on where to get chains? 2 link or 4?
/ Loading Turf tires #11
Others on TBN have recommended tirechain.com and they do appear to have a few style choices for your size.
How much did the new tires increase your width?
/ Loading Turf tires #12
I bought chains for my turf tires from tirechains.com. Love them. They made a huge difference when working in muddy conditions.
I can't remember what the original width was....I know I had the Ag's turned outward....may 52 or 54 inches? I believe Matt from Hoye said the new tires would give me a 58" stance. A quick measurement shows 59" inches - probably due to tire deflection. I do know that Matt said he could adjust the offset since the wheels are made to order. I know this because I have a narrow stall that I park the tractor and could not go over 60 inches wide... So it worked perfectly for me....wider tractor that still fits inbetween two posts although its very tight.
Thanks....I will check that tire chain link
Forgot to ask....did you use 2 or 4 link chains?
/ Loading Turf tires #15
I planned to get 2-link chains originally but eventually went with 4-link truck chains with cams. 2-link wasn't available with cams. I read in one of the general forums that if the cams are tightened down enough on something that moves slow like a tractor, you don't really need the bungee or spring adjusters.
Will you still fit between your two posts with chains on?
2022 EZ-GO ELITE...
2006 Generac SD0150 187kVA T/A Towable Diesel Generator (A61572)
2006 Generac...
213087 (A64276)
213087 (A64276)
Connect CH65 Hydraulic Breaker Excavator Attachment (A64194)
Connect CH65...
2017 Ford Expedition SUV (A64557)
2017 Ford...
2022 EZ-GO ELITE...
