cutting angle in bandsaw?
/ cutting angle in bandsaw? #1
2manyrocks
Super Member
How do you guys cut angle in your bandsaw? It seems to cut more square if I lay both sides down in the vice, but it wants to jump out of the vice unless I push down on it with a stick.
What's a better way?
/ cutting angle in bandsaw? #2
Thats how I cut angle iron. Book says to position the material where the least amount of teeth are in contact. What kind of vice do you have, cam lock, or screw?
/ cutting angle in bandsaw? #3
I do it the same way as 2manyrocks.
Never had it want to "jump out"
/ cutting angle in bandsaw? #4
Same way here and never had any issues:thumbsup:
/ cutting angle in bandsaw? #5
I thought you wanted more teeth in contact, which is why you cut both sides at once instead of cutting the one side up,(and about 2 teeth) then way more on the flat after you have torn the teeth off by too little numberon the single side????
Maybe you are correct, but with the minimum teeth rule just not mentioned??
David from jax
It is a screw type vice like you see on about every Taiwan/Chinese bandsaw.
I read the Ellis link, but didn't see an example of a jig to hold angle in place.
/ cutting angle in bandsaw? #8
at work we have a bandsaw, and when I cut angle, to keep it from slipping out, I use a small piece of rectangle stock scrap against the open side of the angle, laid across the bottom. gives the vice something to grab on on that 'thin' side.
I do the same in a drill press vice table..
soundguy
/ cutting angle in bandsaw? #9
Thats how i cut it with my Jet band saw and ive never had it try to jump out. I use adjustable roller guide on the floor to support the long end. Ive never had an issue.
/ cutting angle in bandsaw? #10
I tore up an almost $45.00 blade cutting a piece of pipe with my saw, all because the cam lock vice let the pipe move. That's when I bought the screw vice!
The blade wants to grab the angle at the top and then pull it upward and out of the grip of the vise.
Do I put the rectangle in the vice like this? (This photo was made from the backside of the saw with the motor being on the left. The other one was made from the front. )
/ cutting angle in bandsaw? #12
I ant got any pictures but at the fab shop I worked at we did it on its side
blade travels in this direction<-------------
I>>>>>>>>>>I---------< screw
stacking them and winding in the screw and doing multiple cuts at once.
production work.
power hack saw the same way
so when I do one its like this I>I---------- works fine for me
tom
/ cutting angle in bandsaw? #13
/ cutting angle in bandsaw? #14
I don't want to get into the rectangle discussion, but I did notice in the picture that the movable jaw on the saw appears to not be lying flat on the table. Tighten that up, as well as the non-moveable one and see if that helps. Also reduce the weight on the blade by adjusting the tensioner, which makes it cut a little slower also. I typically hold the saw up as I slowly feed it into the angle, until I have at least a quarter inch depth of cut going.
David from jax
/ cutting angle in bandsaw? #15
Problem with that way is the under surface of the angle on the side to which the blade is travelling is at an angle that makes the "hook" of the blade teeth tend to catch. Same type of thing on sawing angle with the open side down on a vertical saw freehand table. The piece is very stable, but the blade wants to catch after it crosses the peak. In that case, cutting the 1st flange flat and then rotating the second flange down to the table as the blade gets to it works well. In the band- hack saw tho the metal stays in the same position thruout. Considering that downforce is constant there may be no really good solution. If the angle were oriented upright the cutting area would change hugely as you reached the bottom flange and downforce could use an increase. Probably would work OK in that position tho at whatever downforce was right for the upright flange and just add a little manually when it gets to the bottom one.
larry
/ cutting angle in bandsaw? #16
I think Soundguy meant to lay the angle upright and use a rectangle inside it that is larger than the bottom flange to give a good seating of the upright flange against the vise. The bottom flange wont be directly clamped -- only indirectly [because its attached to the upright flange].
larry
sandman was absolutely right that one leg of the vice was too loose. I tightened it up and reduced the spring tension a bit.
I think I understand now. thanks much for all the help.
/ cutting angle in bandsaw? #18
Actually not quite what Ellis said, so how about I just post what they did say...
You should never have more than 24 teeth in the work or less than three. Six to 12 is optimum.
That is straight from Ellis....
David from jax
Judges? :laughing:
/ cutting angle in bandsaw? #19
larry
yep. i know it's not ideal.. but it works for me.. :)
soundguy
/ cutting angle in bandsaw? #20
Angle should be in the vise like this L The upright leg against the stationary side of the vise (toward the motor) The other leg flat on the table. It can't spin or tilt that way. The down pressure should be set correctly and should pretty much stay the same regardless of what's being cut. For instance, the correct down pressure on an Ellis 2000 is 8 pounds. You will likely need to restrict the speed with the hydraulics while cutting the thin vertical leg, but that will not affect the pressure on the horizontal leg.
NEW 2025 Trailer by Premiere 18'+2' Tandem Axle (A62679)
NEW 2025 Trailer...
KBH Cotton Spear (A64126)
KBH Cotton Spear...
1997 TSE UTILITY WIRE REEL TENSIONER (A62613)
1997 TSE UTILITY...
Bulk Lot - Atlas Copco Pump End Components (3) Pallets - Selling as One Lot (A63689)
Bulk Lot - Atlas...
2008 Isuzu NPR Box Truck, VIN # 4KLB4B1U48J801742 (A65563)
2008 Isuzu NPR Box...
2018 Mahindra Mpact XTV1000S (A64127)
2018 Mahindra...
