BX25 vs B2626 with backhoe
/ BX25 vs B2626 with backhoe #1
Scooby074
Super Member
Nova Scotia
BX 25, ZD 326
Been thinking about a BX.. Started a thread discussing it here http://www.tractorbynet.com/forums/kubota-buying-pricing/194897-what-can-bx25-do-bushog.htmlbut the more i read the more i wonder about a b2620. I guess this thread would be best to discuss what benefits if any for a B2620 (or a B2320) over a BX25 as it was determined in the other thread that a BX should be able to do what i want?
First, you should know the condensed version of what its going to do:
This machine is going to spend 90% of its life mowing lawns. Area to be mowed will be approx 2-3 acres, some with a pretty good slope.
Other jobs planned are removing a lawn and landscaping some heavy clay soil to redirect water away from the house. Part of this will be removing about 6" of clay topsoil as the grade is too high. This will be over an area of approx 20'x60' or so
THere will be ongoing maintenance on approx 500' of gravel drive. Including crowning.
Also several ditches need maintaining and various french drains need o be installed.
One last job is bush-hogging an established road and reclaiming some fields. Typically 1-2.5" dia alders.
Can a BX do this or am i wasting my time? How are the taller B's for mowing, especially on slopes?
The more i read, the more i think. Im second guessing myself big time. I already made one mistake, last year i bought a x540.. Great mower but i cant do the other ground engaging stuff that i hope the B or BX will do.
I think its more the ground clearance thing weighing on my mind, mostly for the bush hogging.
Low clearance like the BX = great for mowing.. higher clearance like the B= great for Bush hogging but not so good for mowing on slopes:confused:
A couple other questions i just thought of.
How hard is it to remove the MMM on a BX vs a B? Is it a simple pto plug in or are belts involved? Is the deck drive over?
Can you "lock" the MMM up on either machine and operate the rear 3pt independently?
Oh and what about the dreaded Industrial vs turfs? Will turfs hold up for bush-hogging? Will industrials tear the lawn? The HDAP's on my 540 will pack with clay when the grass is wet and leave me stuck till i get the truck even with the x540's differential lock. It sucks sitting there with both tires spinning, but unable to get traction. One more reason i want to upgrade to a machine with 4wd.
/ BX25 vs B2626 with backhoe #3
How hard is it to remove the MMM on a BX vs a B? Is it a simple pto plug in or are belts involved? Is the deck drive over? *****
Drive over deck on B , not BX . Just a shaft twist on both and a
pull-out lock pin on both sides.
Can you "lock" the MMM up on either machine and operate the rear 3pt independently? *********
YES !
Oh and what about the dreaded Industrial vs turfs? Will turfs hold up for bush-hogging? Will industrials tear the lawn? *******
There's not too much grip with turfs on mud or inclines , and
they puncture easier too .
A few answers above. The BX is way lower for Centre of
gravity. How steep side-on are we talkin' ?
I'm all lawns,but I often spin on an incline ; diff locks are not much use either , even on a BX , tbh .
There are several slopes I avoid until the ground is well dry.
You can't slash 1" to 2.5" wood with a BX and it's HP. You need a hire a guy with a proper tractor ( L/M stuff)
for that diameter of wood. That's real brush , not overgrown grass stuff !
/ BX25 vs B2626 with backhoe #4
I know you have mower but if 90% of what you do is mowing then that's what you should have for that job as a tractor will just not mow as well as a mower
Maybe think about renting for other jobs
Joel
/ BX25 vs B2626 with backhoe #5
bp fick has a very good thread comparing the BX and B. JOHNTHOMAS also has a lot of information. I have owned 2 BXs, but never a B.
/ BX25 vs B2626 with backhoe #6
I think your questions have been answered in your previous thread and this one. You have even answered it for yourself. It's time to decide because I don't think your going to get any other answers other than the ones you've already rec'd. Maybe someone can use some different words but still same answer. GROUND CLEARANCE is biggest difference between BX and B and higher off the ground is or feels less stable. I purchase R/I4's on B's other than current B2320 has Ags (R1s) for garden work. I usually purchase turfs for BXs. I like the R/I4s and have never had a problem with them. Another decision that only you can make but I'd hesitate taking turfs into the woods or really rough areas.
/ BX25 vs B2626 with backhoe #7
Is keeping the mower a possibility? I have a mower (ztr) and the B series and I think that is the way to go if possible . I started with a BX and I loved it but realized I just wanted a bigger tractor so I did it. When I first got my BX24 my wife assumed I was going to mow with it.
I really hate creating multiple threads on the same issue. This one was basically to discuss the differences in the two machines. Im really second guessing myself here... I dont want to make the same mistake again... Its not that im unhappy with the x540 (im not, i love it) its just that i want something that will do everything i need. The loss im taking on the 540 is going to sting enough.,.. dont want to do this again.
Today i went to the dealer and looked at a B2620. Its a MUCH larger machine than i thought it was relative to the BX. I Think it will be too top heavy for my slopes.. maybe im a just a chicken?:laughing: Plus its taller.. not good for under low hanging branches. dealer offered me a demo of a used bx2320? but it had no mower. I passed for now
Got some bad news while at the dealer. He had 2 Bx's with <200 hours. Those were the machines i was originally planning to buy... But they sold. Now im not sure what will happen... New machine or hold off for a decent used? Cost wise it was about 2k difference from the used (sold) machines to new.
Dealer was pushing RFM. Whats the general consensus on them? Im thinking Mid mount for a bit of weight down low and for ease of use around the house (no tailswing)
Dealer also said that hes had several people with BX's wanting to buy turfs this year. Said the Industrals were too hard on the wet ground? Thats another decision i need to consider.
Unfortunately the Deere will have to go to finance the BX (or whatever machine).
Honestly after seeing it in person, i think the B would be overkill most of the time. About the only time id like it is Bush hogging.
Dealer wasn't endorsing a bush hog either. Said the BX had too little power according to the Landpride manual (20PTO recommended). Not sure what to make of that. I know guys here have them..But hes been selling tractors for 30 years so its not his first rodeo.
He did say it'd pull a 4ft boxblade fine. That was good to hear.
On a comparison note, What about the Massey GC24 or 26 TLB? They sell massey as well but he was really pushing the kubota. I thought the massey had stronger loader and backhoe (according to the brochures), but he didnt seem to agree....Theres also almost 2k between the kubota and the massey gc24.I was thinking the GC26 might be a better fit considering the occasional running of a Bush hog?
/ BX25 vs B2626 with backhoe #9
They do leave ruts on wet ground...:(
/ BX25 vs B2626 with backhoe #11
Here is a 2 page thread, quite readable, about the compare/contrast between a B and BX from my own real world experience. Spend 10 minutes and read through it, and I think you'll be glad you did.
http://www.tractorbynet.com/forums/.../185147-bx1860-vx-b2320-contrast-compare.html
Truly, they are virtually the same tractor. I know that is almost heresy to say out loud, but honestly? That's my honest perspective. The major, most important difference, beyond the nice features the 20 series B give you (better dash, 3 speed ranges, seat, etc) is the ground clearance. Did I mention ground clearance? :laughing: The B is available with rear wheel spacer kit which would make the stability issue somewhat mute, in 90% of the cases. Also surprisingly, the weight differences between the BX and 20 series B are pretty darn small.
If you do rough stuff in the woods or work a market garden, the B is the far better choice. If not, the BX is in many ways the better choice. That's as fair as I can be. Both are great tractors. You just have to be clear in your mind about what it is the tractor will be doing.
/ BX25 vs B2626 with backhoe #12
I would definitely recommend turf tires especially if you are going to mow with it. You can also use chains for snow ice or heavy duty ground engagement work. I had them on my BX and chains fit no problem with the Brotek wheel spacers. They also made the machine much more stable. FWIW, My B which also has spacers is much bigger height wise than the BX but feels more stable. I used to really cringe when using the 3pt spreader or loader and now it doesnt seem to affect the tractor.
/ BX25 vs B2626 with backhoe #13
BX side by side with B.
BX2660 vs B3200 BX25 vs B2320
Ok, you have the perfect solution :D buy them all.. only wish i could :D
Looking at your land, id say its quite similar to the layout of my own , even the slopes. Do you have any issues with the BX (or the B) mowing across the top slope, by the raised garage with the open door? This picture
How about in front of your house where it appears to be a bit steeper?
I have an angle gauge around here somewheres... if i can find it ill give some better information re: slope.
BP: (and everyone) Thanks. Ill give your comparison a read .
Has anyone directly compared a BX to a GC?
/ BX25 vs B2626 with backhoe #15
I have used BXs for mowing except for a B7800 with 6'RFM I used for front yard which is flater, not flat but flater.
I currently have the F3080 4wd for all of my mowing. It's the most stable mower Kubota and maybe anyone makes.
The best BX for mowing was a BX1500 (smaller and closer to the ground) and then all the other BXs.
The Bs that I have owned and own do not feel as stable to me and they aren't, in my opinion as any BX. I once traded for an L3240HST and it was a short term machine, very scary on hill side sitting so high off of the ground.
Get a BX2660, MMM and under carriage plates or leave the MMM on all of the time which is what I did. If you want a BH then get the BX25 with MMM and take FEL and BH off when mowing.
Johnthomas, when you mow the upper area, do you go vertically or horizontally?
I know vertically is ideal (and safer) but even if i go vert, id still have to turn at the bottom of the hill (property doesnt go to a "flat" for turning). Currently i mow horizontal, with my butt hanging over the uphill fender :D
/ BX25 vs B2626 with backhoe #17
I have a BX with a 60" MMM. I'm pretty happy with it. The main reason I bought it was was for mowing hills at my house. A lot of what I mow is a cross slope, and I filled the rear tires, which I thinks helps. The steep hill, I mow up and down, not cross wise. I have backed up and down this hill when mowing, this might be an option for you. I keep the nose up hill when doing this. You just want to make sure you have it in low range and 4 wheel drive when doing this.
/ BX25 vs B2626 with backhoe #18
Actually the upper area near tractor building is almost flat on the front (open) side. With my F I mow vertical, horizontal and then diagional all of it except for one spot that is really, really steep and I go up it and coast back down. Right in front of my house is the steepest other than the one corner spot near my far tree line. I mowed the front of houset up and down with BX2660 but some times mowed it cross the slope with the BX1500. I would never mow any of it cross ways with a B.
Here are some pictures around my house but slopes/angles are hard to see/judge in pictures.
Well, after about 3 years of BX ownership, I can answer my own thread. I should have went with the B!
/ BX25 vs B2626 with backhoe #20
I think that no one is surprised by that.
It really comes down to two things....tool for the job and what you can deal with....I think we all understand the tool for the job, but what you can deal with is a little different.
I have been on my BX for a few hours.....and when I get off the machine it is really all I can do....neighbor was over and said it is a good thing you bought a small tractor...I doubt you could get off a larger machine....I could but it would not be fun.
