GC2400 mower noise
/ GC2400 mower noise #1
Bever309
Cobleskill ny
Massey Ferguson 1742
I have been hearing what sounds like a gear meshing or a chatter coming from the mower deck on my GC2400. Has anyone else had this type of noise? It seems louder at the lower RPMs. :confused:
/ GC2400 mower noise #2
Mine makes noise on initial star-up (engaging PTO), but then is pretty smooth. You might want to check for loose blades or bad bearings....
/ GC2400 mower noise #3
Have you checked the fluid level, grease the spindles?
Yes I checked the fluid and greased the spindles, they all seem fine. It sounds like it is coming from the shaft itself.
/ GC2400 mower noise #5
Try running the pto w/o the shaft connected to the pto to make sure it is the deck making noise, and not the pto itself.
/ GC2400 mower noise #6
What I usually do with mine is too pull the pto shaft apart that goes too the mower's gear box from the tractors mid pto and actually grease the splinned shaft.Sometimes they'll also rattle a bit if the stub shaft [pto shaft]that come's out of the tractor is dry.Its always best to apply a bit of grease to that shaft as well as the quik connect end of the pto shaft as well.They need a bit of grease on the splines to stay quiet. Larry
2011 Ford F-150 Pickup Truck (A64194)
2011 Ford F-150...
2020 ISUZU NRR 4X2 S/A 22FT BOX TRUCK (A59912)
2020 ISUZU NRR 4X2...
2022 EZ-GO ELITE...
1989 STE 307 SS 4 Comp Non Insulated T/A Chemical Tanker Trailer (A64194)
1989 STE 307 SS 4...
2010 Mertz Manufacturing 50003-02 T/A Fracturing Pump Trailer (A64194)
2010 Mertz...
2015 GMC 3500 HD 4x4 Crew Cab Pickup Truck (A64194)
2015 GMC 3500 HD...
