Finally Building my Backhoe
/ Finally Building my Backhoe #161
Take a look at the second photo when Iplayfarmer first began this thread. He calls it an angle and I called it a toe. I should have looked it up and used the same terminology, sorry. As for what it's for: I can't speak for Iplayfarmer, but in my case, it makes room for mounting the cylinder operating the boom. As I was putting the mockup together I could see a problem getting the boom, dipper and bucket folded up for transport. Adding that angled piece solved most of that, I hope.
Got it. Thanks for the explaination.
Now you have me curious to check the backhoes at work to see how Case addressed it.
/ Finally Building my Backhoe #162
Here is what i've got done so far (I'm not using plans, just building by the seat of my pants. I took some measurements from a Kubota Bx25):
/ Finally Building my Backhoe #163
Guess I don't have to wait until tomorrow. Got to love the internet.
/ Finally Building my Backhoe #164
You're welcome. Right now I'm having fits trying to calculate the specs for the cylinders. Getting the right combination of stoke and starting length is stretching my meager capabilities in geometry and math.:confused2:
/ Finally Building my Backhoe #165
Thanks rcurrie. I can see you know your way around a welder. That has the look of a very sturdy machine! You called this a subframe. Are you ready to tell us what this going to get married to?
/ Finally Building my Backhoe #167
Before the use of ductile iron for the booms, the 580C addressed it a little differently.
/ Finally Building my Backhoe #168
I will be making a subframe for a Kubota Bx 2350. Hopefully when this is done it should hook up similar to a Bx24 setup. My welding skills aren't that good but I figure thats why grinders were invented.
I admit, figuring out the cylinder geometry is hard. I found that drawing circles helps. Figure a location for the cylinder base and draw a circle with center on the base pin center and radius equal to the retracted length of the cylinder. Draw another circle with a radius equal to the extended cylinder length.
Now draw a third circle centered on the articulation joint to some point along the outer circle where you think you want the cylinder rod end pin.
Where the third circle intersects the inner circle is the limit of travel of the articulated joint. If the intersection of the third circle and the inner circle is not where you want it, start moving proposed locations of the pins until it works out.
I drew these pictures in sketchup, but you could do the same thing in any program or on a piece of paper. In my example the articulation travel is about 65 degrees.
By moving the base pin or the rod end pin relative to the articulation joint, you can change that articulation angle. It's a lot of trial and error, but by doing on screen or paper first you can go through a lot more trials in a short amount of time.
/ Finally Building my Backhoe #170
Iplayfarmer:
Thanks for those instructions. I will have to do it on paper as I have yet to get SketchUp working on here. Is there a formula I can use to calculate what length cylinder with what stroke I should be using? That, in large part is where my confusion lies.
Iplayfarmer:
I don't know of any. As a starting point, it seems to me that most cylinders have a stroke that it about 40% of the retracted length. I.e. a 10 inch cylinder has about a 4 inch stroke making for a 14 inch extended length. This is a rough figure.
Someone else hopefully knows of some kind of a calculator. Maybe they'll chime in.
/ Finally Building my Backhoe #172
Absolutely!! I keep two of them handy, one of them with an aggressive wire wheel to polish up what the chipping hammer misses.:D
/ Finally Building my Backhoe #173
You could try using search as I'm pretty sure I saw a thread on it somewhere on one of the forums, or a simple thing I've seen is to weld a couple chains from the end of the stick to the inside of the bucket just behind the teeth . The chains should be long enough so that they are almost tight when the bucket is fully open.
That's an interesting idea. I have not seen it done that way, but it
would work.
I saw pix years ago of an articulating plate that fits inside the bkt, but
stayed put when the bkt rotated. That would only work with bkts of
a certain shape, however.
To avoid clogged bkts, I don't use anything less than 12" wide. Also, if
you drill a few holes in the bottom of the bkt, the suction will be broken
easily, which helps.
/ Finally Building my Backhoe #174
would work.
I'm pretty sure chains is the way I'll go. I had thought of a couple pieces of angle doing much the same as the plate you mentioned but the chains sound so much simpler. The holes in the bucket bottom might work if it was just muck we're talking about but this is Lake Agassiz / Red river bottom clay. I vow with my hand over my heart, there is nothing gooier!! Another thing I plan to do is taper the bucket a bit. The open part will be just a bit wider than the rear or bottom so that side cling should be less. Now if only we would have some dryer years all this would be moot!
/ Finally Building my Backhoe #175
I did a little work on the boom today. I've started a thread that I'm calling "It's time; either get started or.... Thanks again for all the great advice you've been giving me and I look forward to lots more to come!:D
/ Finally Building my Backhoe #176
Post us a link. Thanks.
/ Finally Building my Backhoe #177
Posting links is one of the many things I don't know how to do.:ashamed: Another example of too few functioning brain cells!:(
/ Finally Building my Backhoe #179
Just go the URL address window in your browser, select all of the link, copy it, paste it, done.
2002 Sterling L7500 Series VacCon V390LHA Combination Sewer Jetter Vacuum Truck (A64556)
2002 Sterling...
2017 Ford F-250 Knapheide Service Truck (A64556)
2017 Ford F-250...
1970s John Deere 350B Dozer — Only 2,525 Hours — Single Private Owner 40 Years — Light Use, Ready to Work
1970s John Deere...
2022 Power Screen Phoenix 3300 Tri-Axle Trommel Screener (A64194)
2022 Power Screen...
6' STACKING RAKE (A64276)
6' STACKING RAKE...
2017 Ford F-150 Ext. Cab Pickup Truck (A61572)
2017 Ford F-150...
