BH bucket scraper
/ BH bucket scraper #1
davcog
West Gardiner, Maine
Kubota BX 23
Have a BX 23 and want to add a small finish scraper blade to the BH bucket. Saw a pic somewhere of one that used short chains and turnbuckles to attach it. Bucket teeth slipped into a V shaped pocket. Anyone know where to find the pics or any measurements for this sort of implement?...:confused:
/ BH bucket scraper #2
I believe the company is Hall's. I had one made for my backhoe. My welder welded some pockets on a used cutting edge. The pockets slide over the teeth and I drilled holes in bucket for chain to be bolted to. I unbolt it when I don't need it. plowking
/ BH bucket scraper #3
I made one for a little woods BH I had. Sorry it was a long time ago, (no pics.) but I just took whatever I had around that was wide enough, I think that it was a pc. of 8" channnel, placed under the bucket so that it was at about the same angle as the bucket bottom and teeth, and cut sections out of a pc. of pipe to go over each tooth and welded them to the channel to enclose each tooth. I had already welded a grab hook on the upper back of the bucket so I ran a chain welded on the back of the channel to it. I made a little set up that I don't think that I can explain here, but it allowed me to first hook the chain into the hook, then slide a link of the chain over a little tab with a small hole in it on the back of the channel and then put a regular spring lynch pin thru that hole holding the chain in place with no other tightening needed (turnbuckles or binders) It was very easy to slip on and off. With a little practice positioning the tractor and using the outriggers you could grade odd shaped areas nicely. (outriggers to angle the scraper by tilting the tractor) If I remember, I put a small angle iron on the bottom of the channel to act as the cutting edge. If I had the knowhow I'd draw a sketch and post it for you, it's all I can do to post a picture!
/ BH bucket scraper #4
I never thought about doing that. Just tonight I was leveling off a little patch and I just rolled the bucket up and used the bottom. What would you use for length, I'm thinking a 3-4' length?
/ BH bucket scraper
I've this step covered:laughing: The rest is pretty easy to visualize. Also brother with the "right stuff" and a welder has fabricated some handy gadgets around his home and buisness.
/ BH bucket scraper #6
I only made it at most 24" wide. With the short reach of a tractor BH that's all you need plus it will allow more detailed "carving". Now if I were making a rake for grubbing out roots/weeds or raking rocks out, 3-4 ft. might be in order if the hoe has the power for something that wide.
Mini Excavator Rake Attachment (A61572)
Mini Excavator...
ROTO-FINGER PEA - BEAN SHELLER (A63291)
ROTO-FINGER PEA -...
Caterpillar 988B Wheel Loader Parts and Service Manuals (A63117)
Caterpillar 988B...
2016 Ford Escape (A61574)
2016 Ford Escape...
2021 Takeuchi TL6R High Flow Compact Track Loader Skid Steer (A61572)
2021 Takeuchi TL6R...
Oxy-acetylene Torch and Regulator Rig (A63689)
Oxy-acetylene...
