B2920 HST Creaking Sound
/ B2920 HST Creaking Sound #1
e171fish
Member
The transmission on my new B2920 is starting to worry me a little bit. It's making a loud creaking type noise when going up slight inclines or working with the box blade. It's in low range, 4wd, with the BB and FEL attached at around 2700 rpm. It's not being worked hard at all.
I'm familiar with HST whine from my BX2360. This doesn't appear to be the typical HST whine.
I have an audio file but I guess it can't be uploaded to the forum.
Any guesses? Normal?
On a positive note I just installed a Tuff Top Canopy and the Kubota Quick Attach. Pretty happy with the results.
/ B2920 HST Creaking Sound #2
Tighten the wheels and hubs
/ B2920 HST Creaking Sound #4
another vote for wheels making the noise.
James K0UA
/ B2920 HST Creaking Sound #5
If the creaking sound is still there after tightening your wheels and hubs, try removing your FEL and go up the same incline and see if you still hear it. I've had a weird creak sound in the past and it ended up coming from the left side of the FEL where it mates up with the tractor.
/ B2920 HST Creaking Sound #6
If it is creaking metal noise...
1, Lug nuts
2. If it has the same adjustable axle the 7510 /7610 has tighten up on the inside of the axle.
I thought I had broken gears- on my 7510- Panic stricken..
I posted here and the folks saved my bacon !!!!
Good Luck.
RD
I'll check the wheels tomorrow and post a youtube video if its not resolved.
Thanks
/ B2920 HST Creaking Sound #10
Yeah, that is some kind of contact. You've not been able to locate it? Sometimes those things can be difficult because the sound gets transmitted through other things, as a distraction.
/ B2920 HST Creaking Sound #11
Wow;
That is a strange noise and seems to cycle with a fixed engine RPM.
Is your mid PTO linkage tight? It almost sounds like something else running
in the background.
The video was a great medium for troubleshooting. There are some very
smart folks here. Someone will know !
Cheers,
RD
/ B2920 HST Creaking Sound #12
You may have already done this, but perhaps take a stick of 2x4 and go around the tractor, with the hood up, and see if you can deaden the sound. See if by pushing that stick against things, it stops the resonance harmonic. Just an old mechanic's way for finding strange noises. The stick allows you to "touch" things that are hot, like the muffler, intake, exhaust manifold, etc. Just don't stick it in the fan. :D
Do the same thing around cables, trans housing, rods, cables, etc. underneath the machine.
/ B2920 HST Creaking Sound #13
Thought you where blowing things out of proportion whe I started to read the post but when I watched and listened to the video I think you gotta have that looked at right away - Almost sounds like it is coming from a cylinder but that couldn't possibly:confused2: be could it????
Just to clarify...the audio is from the tractor when it's actually being driven. The photo in the video is just a still image I inserted. The tractor does not make any unusual noise when not moving.
From the first post "It's making a loud creaking type noise when going up slight inclines or working with the box blade. It's in low range, 4wd, with the BB and FEL attached at around 2700 rpm. It's not being worked hard at all."
Sorry if I wasn't clear.
/ B2920 HST Creaking Sound #15
Not that it matters with respect to the noise but isn't 2700 rpm a little high for running this tractor? I run mine in the 1200-1500 rpm range for most tasks.
/ B2920 HST Creaking Sound #18
/ B2920 HST Creaking Sound #19
This reminds me of a terrible noise I had in an 84 Bronco that everyone was sure was in the transfer case. Turned out to be a loose heat shield on the catalytic converter. Not that this helps the OP, but....
Now that you mention it, 3 years ago, my daughter's Chevy Tracker did the same thing. As a temp fix, I put a large worm clamp around it to shut it up.:thumbsup:
Thanks for all of the tips. I'm still trying to discover the cause and have contacted my dealer.
I removed all of the implements one by one, down to the bare tractor, and the noise still persists. It doesn't occur when going down a slope with the HST pedal applied.
Here's another video that may better illustrate the problem and when it occurs.
YouTube - ‪B2920Noise‬‏
5ft Pull-Behind Rotary Tiller Tractor Attachment (A59228)
5ft Pull-Behind...
2012 UTILITY REEFER TRAILER (A58018)
2012 UTILITY...
2014 PETERBILT 388 CAR HAULER (A59904)
2014 PETERBILT 388...
2022 Ram 2500 (A55973)
2004 EAGER BEAVER 50GSL/3 DETACH TRAILER (A52707)
2004 EAGER BEAVER...
2016 GMC Seirra Denali 1500 4x4 Crew Cab Pickup Truck (A60352)
2016 GMC Seirra...
