Is gear reduction motor necessary.
/ Is gear reduction motor necessary. #1
arrow
Super Member
Wakefield, RI
Mahindra 3016
Cannot get parts for a mid eigthy Kawasaki engined 3.5 hp rototiller. Needs a new carb which is no longer available. I do have a spare 5 hp Honda GC160. It is not a 6 to1 gear reduction motor and wanted to know if this is an essential ingredient for a rototiller?
/ Is gear reduction motor necessary. #2
Most tillers rely on a system of pulleys designed to transmit the right amount of torque and speed. Unless you have a rare tiller that was somehow designed to require a gear reduction engine, I would think you could use about any engine that will fit on the tiller.
/ Is gear reduction motor necessary. #3
Don't do it! Without major modification, everything will run six times faster. You'll need roller-skates to keep up.
Mike
Mike
It is a gear reduction motor on there now so I guess I am out of luck. Thank you 2 many and Mike
/ Is gear reduction motor necessary. #5
Did the tiller originally come with a gear reduction motor? Would like to see a photo if you get the chance.
/ Is gear reduction motor necessary. #6
I think Briggs & Stratton made some gear reduction motors years ago. Not sure if they are still available today or not.
/ Is gear reduction motor necessary. #7
I'm fairly sure gear reduction engines are available. Look at northerntool.com or search for Jack's small engine repair.
Mike
2016 Ford F-250 Knapheide Service Truck (A64194)
2016 Ford F-250...
2005 MACK CV713 MIXER TRUCK (A65643)
2005 MACK CV713...
ATS 60 Gallon 2 Stage Air Compressor (A62679)
ATS 60 Gallon 2...
KUBOTA SVL97-2 (A65643)
KUBOTA SVL97-2...
2024 Wolverine X2 1000 R-Spec (A62679)
2024 Wolverine X2...
Heavy Duty Steel Baskets (A65579)
Heavy Duty Steel...
