Is gear reduction motor necessary.
   / Is gear reduction motor necessary. #1
arrow
Super Member
Wakefield, RI
Mahindra 3016
Cannot get parts for a mid eigthy Kawasaki engined 3.5 hp rototiller. Needs a new carb which is no longer available. I do have a spare 5 hp Honda GC160. It is not a 6 to1 gear reduction motor and wanted to know if this is an essential ingredient for a rototiller?
   / Is gear reduction motor necessary. #2
Most tillers rely on a system of pulleys designed to transmit the right amount of torque and speed. Unless you have a rare tiller that was somehow designed to require a gear reduction engine, I would think you could use about any engine that will fit on the tiller.
   / Is gear reduction motor necessary. #3
Don't do it! Without major modification, everything will run six times faster. You'll need roller-skates to keep up.
Mike
Mike
It is a gear reduction motor on there now so I guess I am out of luck. Thank you 2 many and Mike
   / Is gear reduction motor necessary. #5
Did the tiller originally come with a gear reduction motor? Would like to see a photo if you get the chance.
   / Is gear reduction motor necessary. #6
I think Briggs & Stratton made some gear reduction motors years ago. Not sure if they are still available today or not.
   / Is gear reduction motor necessary. #7
I'm fairly sure gear reduction engines are available. Look at northerntool.com or search for Jack's small engine repair.
Mike
2017 FREIGHTLINER M2 106 (A58214)
2017 FREIGHTLINER...
John Deere Gator (A53317)
John Deere Gator...
SKID STEER ATTACHMENT AUGER (A58214)
SKID STEER...
2010 GMC Sierra 1500 4x4 Crew Cab Pickup Truck (A55973)
2010 GMC Sierra...
2008 Ford F-250 4x4 Ext. Cab Pickup Truck (A56859)
2008 Ford F-250...
1999 International 9200 Day Cab Truck, VIN # 2HSFMAHR0XC036739 (A57453)
1999 International...
