Oil & Fuel when I get this thing turned upright
/ when I get this thing turned upright #1
knucklehead1
Kubota B 7100 TG 1860
Got too close to the edge today..always knew it would happen. Does anyone know what I should do before I attempt to start it again?
/ when I get this thing turned upright #2
Check all fluids is the only thing which comes to mind right off the bat.
I'm assuming that you weren't hurt at all. Well, except maybe your pride.:eek:
/ when I get this thing turned upright #3
#1 Get it upright #2 Pull the glow plugs, if you have them; if not pull the injectors and spin the engine over several times to clear any fuel/lube oil from the intake stream and cylinders.#3 Check the oil for adequate level, put all the stuff you removed back and fire 'er up
/ when I get this thing turned upright #4
Glad you survived:thumbsup: This something I personally haven't had to deal with, but probably make sure no oil or other fluids got in the cylinders, don't want to bend rods:mad: make sure radiator is ok and check the battery for loss also. Good luck with it.
/ when I get this thing turned upright #5
All of the above are good! But first a clean set of shorts are in order!!:laughing:
glad your OK!!:thumbsup::thumbsup:
PS! Just saw your a new member! Welcome!!
/ when I get this thing turned upright #6
Then look into ROPS and a seat belt ! Lucky you didn't meet St Peter !
/ when I get this thing turned upright #7
Glade to hear you're OK:thumbsup: I must ask though! it looks like more than one roll over to have wound up down there:cool: if so? you might want to be looking at some other issue's Like bent lift arms, bent steering wheel,,the exhaust pipe, etc,etc, what Implement did you have on the tractor?
/ when I get this thing turned upright #8
Wow, that's a heck of a first post by a new member, glad you survived the accident to post! Like already suggested, do look at getting a ROPS installed.
/ when I get this thing turned upright #9
"when I get this thing turned upright"
Go buy a lottery ticket!!!:D
/ when I get this thing turned upright #10
Welcome to TBN and I am glad you didnt get hurt in the rollover. Kubota has a reduced price ROPS program and add a seat belt along with it. Please consider looking into the program here is the link Kubota ROPS Program
/ when I get this thing turned upright #11
Am I the only one that thinks that is a toy tractor and not a real one? Maybe 1/12th scale.
/ when I get this thing turned upright #12
^ what he said!!
/ when I get this thing turned upright #13
Gotta be the 'real thing' .
It is on the internet after all.
Or maybe post this in the 'safety forum'.............
Titled............where NOT to throw toys in the flower garden for 'Mother's Day' ?
/ when I get this thing turned upright #15
I thought all these tractors were our "TOYS".
David from jax
/ when I get this thing turned upright #16
That looks like a real nasty tumble - glad you're OK. It took some gutts to 'fess up & post the picture so others can learn. We all admire that. Thanks,
-Jim
/ when I get this thing turned upright #17
Nope :cool: because even the Toys have ROPS:p
/ when I get this thing turned upright #18
Going back and looking at the pic for a while, I'm beginning to think TGF may be right and we've been had.
/ when I get this thing turned upright #19
Yea, I to looked real close again and don't I don't think its real. Plus the OP hasn't reported back.
/ when I get this thing turned upright #20
I dunno...comparing it to the size of the leaves on the bush makes it look real (remember, some of those really old Kubotas (like the L175, which is what I think it is) were pretty small..
