Oil & Fuel when I get this thing turned upright
   / when I get this thing turned upright #1
knucklehead1
Kubota B 7100 TG 1860
Got too close to the edge today..always knew it would happen. Does anyone know what I should do before I attempt to start it again?
   / when I get this thing turned upright #2
Check all fluids is the only thing which comes to mind right off the bat.
I'm assuming that you weren't hurt at all. Well, except maybe your pride.:eek:
   / when I get this thing turned upright #3
#1 Get it upright #2 Pull the glow plugs, if you have them; if not pull the injectors and spin the engine over several times to clear any fuel/lube oil from the intake stream and cylinders.#3 Check the oil for adequate level, put all the stuff you removed back and fire 'er up
   / when I get this thing turned upright #4
Glad you survived:thumbsup: This something I personally haven't had to deal with, but probably make sure no oil or other fluids got in the cylinders, don't want to bend rods:mad: make sure radiator is ok and check the battery for loss also. Good luck with it.
   / when I get this thing turned upright #5
All of the above are good! But first a clean set of shorts are in order!!:laughing:
glad your OK!!:thumbsup::thumbsup:
PS! Just saw your a new member! Welcome!!
   / when I get this thing turned upright #6
Then look into ROPS and a seat belt ! Lucky you didn't meet St Peter !
   / when I get this thing turned upright #7
Glade to hear you're OK:thumbsup: I must ask though! it looks like more than one roll over to have wound up down there:cool: if so? you might want to be looking at some other issue's Like bent lift arms, bent steering wheel,,the exhaust pipe, etc,etc, what Implement did you have on the tractor?
   / when I get this thing turned upright #8
Wow, that's a heck of a first post by a new member, glad you survived the accident to post! Like already suggested, do look at getting a ROPS installed.
   / when I get this thing turned upright #9
"when I get this thing turned upright"
Go buy a lottery ticket!!!:D
   / when I get this thing turned upright #10
Welcome to TBN and I am glad you didnt get hurt in the rollover. Kubota has a reduced price ROPS program and add a seat belt along with it. Please consider looking into the program here is the link Kubota ROPS Program
   / when I get this thing turned upright #11
Am I the only one that thinks that is a toy tractor and not a real one? Maybe 1/12th scale.
   / when I get this thing turned upright #12
^ what he said!!
   / when I get this thing turned upright #13
Gotta be the 'real thing' .
It is on the internet after all.
Or maybe post this in the 'safety forum'.............
Titled............where NOT to throw toys in the flower garden for 'Mother's Day' ?
   / when I get this thing turned upright #15
I thought all these tractors were our "TOYS".
David from jax
   / when I get this thing turned upright #16
That looks like a real nasty tumble - glad you're OK. It took some gutts to 'fess up & post the picture so others can learn. We all admire that. Thanks,
-Jim
   / when I get this thing turned upright #17
Nope :cool: because even the Toys have ROPS:p
   / when I get this thing turned upright #18
Going back and looking at the pic for a while, I'm beginning to think TGF may be right and we've been had.
   / when I get this thing turned upright #19
Yea, I to looked real close again and don't I don't think its real. Plus the OP hasn't reported back.
   / when I get this thing turned upright #20
I dunno...comparing it to the size of the leaves on the bush makes it look real (remember, some of those really old Kubotas (like the L175, which is what I think it is) were pretty small..
2010 Toyota 7FDKU40 7,350lb. Straight Mast Diesel Forklift (A60460)
2010 Toyota...
2019 Freightliner M2 106 AWD Altec DM47BTR Insulated Digger Derrick Truck (A60460)
2019 Freightliner...
2021 HYUNDAI HX220L EXCAVATOR (A60429)
2021 HYUNDAI...
2016 Freightliner M2 106 Ambulance (A59230)
2016 Freightliner...
2015 AMERITRAIL MANIFOLD TRAILER (A58214)
2015 AMERITRAIL...
1990 International F-4900 Tri Axle Dump Truck (A59230)
1990 International...
