m5040, m6040, or m7040
/ m5040, m6040, or m7040 #1
hrcarver
Gold Member
NC
jd 6120, 7200, 7700 - ford 2910, 3000, 7610, 7740 - IH 140(2), Super A - kubota m6040
Looking for a tractor in the 20-22k range(used).
It needs to weigh in very near 7k (4wd, loader, and loaded tires, I guesstimated a 4500-5000 lb tractor?) to fit on my 12k trailer with a 2500lb drill)
Needs to pull a 9 shank tiller (some people call them chisel plows, but it isnt as heavy or deep as a "real" chisel plow)
Needs to carry a 3pt 605nt drill weighing 2500+ lbs
So my questions are...
What do these things weigh loaded and loadered?:laughing:
Will a 5040 pull a 9 shank tiller? I know that my old ford 3000 (4000lb 40hp 2wd) will not. I have to remove the two outside shanks.
Is 70 hp really useful on a 5000 lb tractor?
TTT, any opinions welcome
/ m5040, m6040, or m7040 #3
Weights and such should be available on the web site. I honestly don't know what any ground engagement tool any of these will pull. Our Ford NAA will easily pull a 2 bottom plow on one of our farms and only spin the tires on another.
To me 70 HP can be very helpful depending on your chores. We use two ten foot rotary cutters that would not do well with less and actually work right with 85 HP.
Sorry I couldn't be more help.
/ m5040, m6040, or m7040 #4
The 7040 is about the same size as my TN75da. My guess is you'd want the 7040, but it might be over the gross weight you want, thats with the 2500lb drill plus tractor.
/ m5040, m6040, or m7040 #5
our M7040 comes in right around 8k pounds with loader, loaded rear R-1's and cast iron wheel weights on the rear.
We pull a 3 bottom plow in rocky NY soil and drag a 2k pound mulch layer for raised bed planting.
tractor handles the above equipment fine, sorry no experience with a mounted drill.
Thank you all, but that's what I wanted to know!
Tractor weights are listed online, but a tractor weight aint the same as a tractor weight.;)
What do you reckon the cast weights weigh?
/ m5040, m6040, or m7040 #7
The rear wheel weights from Kubota weigh in at 330lbs per set and you can use up to three sets.
In liquid that would equal out to about 1500lbs in use.
You say you need to pull nine shanks, how deep?
Normally for chisel plows we look for about 10 horsepower per shank for three point hook up or 15 horsepower for trailer chisel plows but they go in about 12 inches.
On a bo-tiller (what we call them). Probably around 8 or 9" deep.
Shallower than a real chisel plow, much shallower than a sub-soiler.
Pic is worth a thousand words...
/ m5040, m6040, or m7040 #9
Now I know what you are talking about, we have one of those we pull with a Ford 600, but it is a bit smaller, you are right, they take a lot of power, but not on the order of a regular chisel plow.
We also have a 10' Great Plains NT drill we pull with a 80 HP tractor. The NT really takes the power, but a 5' like you have really shouldn't be a problem for a 60 HP tractor to pull, but a little heavy on the three point; need to check the specs.
/ m5040, m6040, or m7040 #10
80hp will pull that pretty good,unless you load it down.
I'm sure 80 would walk it, 40 will pull 7 shanks(just barely). What about 60?
/ m5040, m6040, or m7040 #12
Just my opinion, but I don't see a problem with the cultivator, but am a little concerned about the weight of the planter on the TPH. We have a 2100 lb cutter and it took our Case CX80 to handle it.
I am sure your dealer can be more definitive, I usually confer with mine as I am certainly not an expert.
All the m kubotas and the 5xxx jds rated at 3300 lbs at 24" off the back. I have been borrowing a friends 5210jd when I need to trailer it. It will carry it pretty comfortably with the loader attached. My other tractors large enough to carry the drill are too heavy for me to transport:(.
/ m5040, m6040, or m7040 #14
We use the loader and add field stone as necessary to ballast when using heavy 3pt mounted equipment. I've thought of getting front end weights so that I can remove the loader but for now stone is plentiful and free!
/ m5040, m6040, or m7040 #15
Then you should be OK with the proper ballast and since you will be hauling rather than driving. We drive the four and six miles between farms and a heavy load on a TPH can be a little disconcerting.
Our Case handled the weight OK, but it was a bigger tractor and we always kept the FEL on.
2023 CATERPILLAR 303.5CR EXCAVATOR (A65053)
2023 CATERPILLAR...
Dexter trailer axles (A61567)
Dexter trailer...
JOHN DEERE 606C - 6R30" CORN HEAD (A64277)
JOHN DEERE 606C -...
6ft. 3pt. Blade (A65640)
6ft. 3pt. Blade...
Skid Steer Blank Plate (A65640)
Skid Steer Blank...
New/Unused ATS Plasma Cutter (A65583)
New/Unused ATS...
