m5040, m6040, or m7040
   / m5040, m6040, or m7040
I'm sure 80 would walk it, 40 will pull 7 shanks(just barely). What about 60?
   / m5040, m6040, or m7040 #12
Just my opinion, but I don't see a problem with the cultivator, but am a little concerned about the weight of the planter on the TPH. We have a 2100 lb cutter and it took our Case CX80 to handle it.
I am sure your dealer can be more definitive, I usually confer with mine as I am certainly not an expert.
All the m kubotas and the 5xxx jds rated at 3300 lbs at 24" off the back. I have been borrowing a friends 5210jd when I need to trailer it. It will carry it pretty comfortably with the loader attached. My other tractors large enough to carry the drill are too heavy for me to transport:(.
   / m5040, m6040, or m7040 #14
We use the loader and add field stone as necessary to ballast when using heavy 3pt mounted equipment. I've thought of getting front end weights so that I can remove the loader but for now stone is plentiful and free!
   / m5040, m6040, or m7040 #15
Then you should be OK with the proper ballast and since you will be hauling rather than driving. We drive the four and six miles between farms and a heavy load on a TPH can be a little disconcerting.
Our Case handled the weight OK, but it was a bigger tractor and we always kept the FEL on.
2000 INTERNATIONAL 4700 (A52472)
2000 INTERNATIONAL...
2017 Chevrolet Express Van, VIN # 1GB0GRFF9H1305955 (A51572)
2017 Chevrolet...
TOYOTA 42-6FGCU25 LP SIT DOWN FORKLIFT (A52472)
TOYOTA 42-6FGCU25...
(1) 14ft Tarter Gate (A51573)
(1) 14ft Tarter...
2016 Hurricane Blo-Vac X3 Stand-On Blower (A50324)
2016 Hurricane...
2021 INTERNATIONAL LT625 (A52472)
2021 INTERNATIONAL...
