Hydrostatic ATV
/ Hydrostatic ATV #41
It looks like I might have to go with a two pump configuration, for the hydraulic system. What is a typical set up, for running two pumps off one motor.
Depending on the motor you could run one pump off each end of the crank. If that doesn't work you could work out a serpentine type belt that runs both or run them both with a double pulley.
/ Hydrostatic ATV #42
this is my first post so please try and bear with me
I think that this might bee what you are looking for it is made by howe and howe tech they are on the web so you can check them out.
/ Hydrostatic ATV
yes I have seen this machine, and it is very cool. The difference for me is, that I use a power wheelchair and can't transfer out of it. So I need to be able to back my chair into it and drive from there.
/ Hydrostatic ATV
kdlklm,.. I was surfing along and came across this post, I knew right away, we had talked over on hyd/pnu , Ive never shared and ideas with you, But have enjoyed reading this post, If you remember, I have three friends in wheel chairs, so, Iam Very intrested in building a prototype, and seeing these guys try it out! Iam leaning twards a zero turn chassie, It offers excellent mobility, and reasonably cheap to build, But Iam also looking at the 4x4, articulated, model that you posted a pic of, IMO, I would build it using (1) hydrostatic pump,..With 4 wheel motors, If you use a wheel motor with a (case drain) , you can run multipul motors, in series, and your speed will not change, The oil goes threw 1 motor,. then to the next, and so on, Very simple, You might need a flow valve or two, but I know It works and works good, as I have a small road grader set up this way, Than I would piggy back a small hyd pump for steering and hyd lift/attachments, Theres a real sharp guy over on hyd/pnumatics, kevinj, He might be able to help with the Pump/motor specs, :thumbsup: I love these kind of projects, and will help what i can, Eric
right now, I am contemplating whether the track system is going to be a more affordable way to go. I need to find a track system that is close to 80 inches on the ground. Find out if the track system will offset the cost of having all the more hydraulics that the four-wheel-drive articulating machine would have. If you're able to help me find a track system that meets my needs, I'm willing to share whatever I come up with.
/ Hydrostatic ATV #45
Go with the tracks! I think it will be simpler and just plain cool. A few TBN members have done small tracked vehicles. Most build their own tracks a link at a time. I think there must be some way to use old snowmobile tracks somehow and same some time and effort. I'd imagine that if a guy could get two old beater snowmobiles you could scavenge enough drive parts and track to build a tracked vehicle like you've described.
/ Hydrostatic ATV
that is definitely an option, but I want the tracks to be very reliable. Because I don't want to be out by myself and have the track fall off. And then I'm screwed. Because I can't get out of the machine if I happen to be in fairly rough terrain. How often does a skid steer blow a track.
/ Hydrostatic ATV #47
The key in this situation is going to be regularly scheduled maintenance. The snowmobile track may not be the most durable. The best option will likely be a homemade track like what workinprogress made or like what David Devuono is making.
Homemade tracks will be a lot of work. It's a tough decision what will be a better balance of practicality, functionality, and durability.
/ Hydrostatic ATV #48
Rather than tracks, what about using a wheeled skid-steer like an Argo? You still have the option of adding tracks, and if they fall off you are not stuck.
If the length is going to be around 80 you could increase manoeuvrability by mounting the center two (of four on each side) lower to give less drag when turning; if your machine rocks forward or backward then the front or rear wheels will contact for stability (front and rears are almost off the ground when on a flat surface). You could also make all the wheels the same height and then add tracks around the center pair.
I guess you could just buy an old Argo, cut the dash and front end out and modify the controls to work from the sides. Might be an easy way to get started anyway.
/ Hydrostatic ATV
I really like the track idea, but it comes down to what the track system is going to cost. I really don't want to build my own.
/ Hydrostatic ATV #50
New tracks can get real pricey real fast.
/ Hydrostatic ATV
Yes, I have noticed that. They will probably be the biggest investment into the machine. But I can't really find anything that meets my specifications, without going into the skid steer track systems. They are way overkill, most of them weigh 1500 pounds a side, and are about $15,000.
The ATV tracks are too short, and are a more affordable price tag. But I need something in between.
/ Hydrostatic ATV #52
Are the ATV tracks affordable enough to buy two and link them together?
/ Hydrostatic ATV
I don't think I'd want to do that, a system for a ATV is around $3000. That consists of four tracks. A little bit too expensive to muck around with.
/ Hydrostatic ATV #54
What kind of off road terrain do you think you want to travel on? What will the ballence be between, gravel drives, grass, mudd, water, swamps steep incline/decline going to be? Are you going on a daily adventure? Or can you pretty much guess, what the challenges are going to be, Another thing Iam pluging into the design of the machine is functionality, where are you going to access this (ride) at? Ultimatly an attached garage would be the way to go, so access, manuverably, and, ease of load/unload, are important considerations, Also Simplicity+Durability = Reliability, Weight is also an important consideration, and relitive to mobility, If you are spending most of your time in a chair, I would think that how well this machine rides would be high on the list of design factors, LOTS of ways to design a machine, that will do what you want to do, some right some wrong, If you can shed a little more light on daily use, or terrain challenges, that you want overcome, It would help Designg the drive line, Good Luck Eric
/ Hydrostatic ATV
The terrain I would be driving on, would very from dirt, gravel, grass pastures. The land around my place is relatively flat, but I have a lot of friends that do ATV trips, and I would like to be a part of that. The consistency of the ride would definitely be a factor, because I spent my whole day in my chair. The track design should be pretty smooth. I live in acreage development area with lots of ATV trails, so I would probably spend a lot of time on those.
/ Hydrostatic ATV #56
JFTR, that is exactly how the Ripchair is designed:
RipChair
And all this can be yours for the modest sum of $18,500...
JayC
/ Hydrostatic ATV
RipChair
JayC
the unfortunate part about the Rip chair is that it is designed for someone with a low level disability compared to me. I'm not able to wheel a manual wheelchair, so I'm limited to an electric one. Which makes me in the chair about 600 pounds. Almost everything all-terrain out there is designed for low level disabilities.
/ Hydrostatic ATV #58
I have about 400 dollars and 80 hours into my tracks. They weight approx 200 lbs each. I have designed for approx 1 PSI so I can go on snow. If you don't need to drive on deep snow, go with a single piece of rubber 6 inches wide, use a single row of at least three wheels on each side. Make up U shaped plates to locate the track on the wheels bolted through the rubber to some form of grouser. Smaller the grouser, the easier for the machine to turn (drag a track)
/ Hydrostatic ATV
they look good, do you have any photos of them without the tracks on. So I can see a little more detail on how they're built.
/ Hydrostatic ATV #60
Vision 250/50R15 77D Golf Cart Tires (A61166)
Vision 250/50R15...
2015 Freightliner M2 106 Terex Hi-Ranger TL55 55ft. Insulated Material Handling Bucket Truck (A60460)
2015 Freightliner...
UNUSED JCT 72" HYD TILLER (A62131)
UNUSED JCT 72" HYD...
2018 RoGator 1100C (A63118)
2018 RoGator 1100C...
30 Yard Roll Off Dumpster (A61165)
30 Yard Roll Off...
2025 Wacker Neuson EZ50 Zero Tail Excavator Extremely Low Hours (A63118)
2025 Wacker Neuson...
