What to Make?? What are they??
   / What to Make?? What are they?? #1
crash325
Elite Member
Tucson AZ
New Holland TC-45
I thought these were "bottom" plows. But it seems that molt board and bottom plows are almost the same. Could they be called "Sub Soiler's?)
I think I want to make attachments to hold them on the side of my back hoe. Then use them to stir up the garden area. Maybe that is a waste of time.
like to hear from some of you folks on what you would do and what you call them.
"Be Yourself, Everyone Else Is - Taken!"
   / What to Make?? What are they?? #2
Probably sweeps for a hiller/bedder. They do cultivator duty between rows or in tire tracks. (slice root from weeds under soil surface, loosen earth packed by tires)
Nick
   / What to Make?? What are they?? #3
Many would call those "Cultivator Shovels" attached to a shank.
They have seen widespread use in cultivating farm lands. They will come in many different shapes and sizes and have different names.:
   / What to Make?? What are they?? #4
Yep. They are designed to run shallow enough to scrape and breakup the soil and weeds above. They aren't beefy enough to run deep.
Thank you, your replies are appreciated. :thumbsup:
Could the be called "sub soilers" as well or that a whole different thing??
Hate to just see them not able to do something. But will put them close to end of my list of "Must Does".
Thanks Again :thumbsup::thumbsup:
> "Don't
> worry about the world coming to an end today.
> It's already tomorrow in Australia !"
   / What to Make?? What are they?? #6
Did they come off a David Bradley? I think I had some similar to that when I had a couple of old David Bradley walk behind tractors.
   / What to Make?? What are they?? #7
Do a Google on Cultivator shovels and shanks. :)
You will find many different combinations which serve different purposes. It is a very versatile agricultural implement.:)
   / What to Make?? What are they?? #9
Cultivator, not subsoiler!!!
   / What to Make?? What are they?? #10
Those are sweeps. Sub-soilers are big honking "L" shaped monsters that require massive amounts of horsepower to stir up the soil and prevent compaction.
   / What to Make?? What are they?? #11
If you're day dreaming you can wipe out alot of crop. Don't ask me how I know this.
SAMSUNG STEAM VRT WASHER & SAMSUNG MOISTURE SENSOR (A60432)
SAMSUNG STEAM VRT...
1604 (A57192)
1604 (A57192)
Pat's QH and hydraulic top-link.
Pat's QH and...
2024 CATERPILLAR 305 CR EXCAVATOR (A52709)
2024 CATERPILLAR...
EZ-GO Electric Golf Cart (A60462)
EZ-GO Electric...
2013 FORD F-350 FLATBED (A58214)
2013 FORD F-350...
