JD scv fitting size
/ JD scv fitting size #1
YesDeere
Merland
Just got a four row planter for use on my fathers place. Plan on pulling it with his 4720. I'm two hours away from his house and he's not home to look.
Question is. What size fitting do I need to raise this planter. Is has an IH 1/2" on it now. Thanks in advance
Oh. Heres a pic. I know it's not green but I got a good deal. Old Allis chalmers
/ JD scv fitting size #3
If you're needing the male coupler tip here's the spec's
Part Number: AR94522
Part Price: 10.75 USD
Description: HYDR.QUICK COUPLER PLUG, PLUG, MALE
Specification
Weight 0.24 LBS 0.11 Kg
Thread Size 0.750 IN
Thread Type ORB
Length 1.929 IN
Hex Size 1.000 IN
Vender Series 4000
Operating Pressure (KPA) (Maximum) 2,999.999 PSI
Thanks for the reply. I had one off of my log splitter that fits the 4720. But it is a different thread on the hydraulic line of the planter. Headed to tsc or jd
/ JD scv fitting size #5
Specification
Thread Type ORB
Length 1.929 IN
Hex Size 1.000 IN
Vender Series 4000
I doubt as old as that planter is it would have ORB hose ends. Check your hose end threads first.
The hose on the planter is 1/2" npt
/ JD scv fitting size #7
Is that fitting the same as the Parker Series 60 H3-63-T8 ?
That is what fits my Deere 4300
Got it on and working
