M7040 Disk and cutter size???
/ M7040 Disk and cutter size??? #1
rvon
Thinking about buyin a new 7040 and was wondering if it will handle a 10' IH 37 disk with 18" blades? It will be pulled in hard clay soil that has been plowed. Also do you guys thing it will not strugle with a 8' lift type cutter. In heavy brush and grass as tall as the tractor. I don't want to work it to death and wish I would have bought a 85 or 95.
/ M7040 Disk and cutter size??? #2
do you have tractor requirement specs for the disc? cat 1 or2? I'd say there are 2 biggies for a 7040, the implement weight and HP requirement. remember, 3 pt. specs on a tractor are from 24" out, the disc will project a lot more. assume you're considering 4wd.
sorry can't really specifically answer your question, but do know the 85/9540 HD 12 sp. trans. is rated @ 7k+ on the 3 pt. whereas the 7040 is i think slightly under 3k. if you're considering an implement that big you may look @ the 85/95 model to grow with future needs in the field.
there's a section in the owners manual of each model that gives limits for various implements: plow, b'hog, disc, etc. am sure your dealer would let you review when looking @ a given model.
/ M7040 Disk and cutter size??? #3
I would think that to go to the 8540 or 9540 and they would be to much! The 7040 should handle every thing you have said that you will have to do.
/ M7040 Disk and cutter size??? #4
Builder pulls a MX8 with his M7040 as well as some other stuff including a nice flail mower.
We have a Woods DS1260, so we went with the M8540, so I don't really know the capabilities of the 7040. The people who own them seem to be satisfied.
/ M7040 Disk and cutter size??? #5
i dont know if a 7040 will pull a 10ft disk or not.an personally i wouldnt pull a lift type shredder of that size with any tractor.8ft an bigger id go with the pull type.
I don't know about the disk either. The reasons I am wanting a lift type cutter where I can drive on and off my trailer easier and mow food plots in tight areas.
/ M7040 Disk and cutter size??? #7
I'm currently pulling a 13' John Deere BW disc with my M7040.
In rocky NY loam it pulls fine even at its most aggressive setting. I believe the discs on it are 18" units. I've pulled it thru unworked pasture land to break it up for reseeding, 7040 pulled it fine in 3rd low range (I think it would have done it in 4th but it would have been a rough ride).
I also use a 3-16 trailer plow and can pull it in 3rd low on unbroken ground.
4th low plows fine on previously tilled land.
We use a 6' rotary cutter with no problem. I'm not sure about a 3pt larger one. I'd probably look to a trailer style for bigger diameters with a 7040.
/ M7040 Disk and cutter size??? #8
We have a 3-point Woods 121 10' rotary cutter we have used for years with our 80 HP CX80 and had no trouble with transporting or use.
We now use a Woods DS1260 pull type as we needed a heavier duty cutter and the weight difference between the two is significant and our CXase would not lift it.
I really don't think an 8' on a M7040 would be a problem.
I use a pretty heavy duty LP RCR2672 on my L5030.
/ M7040 Disk and cutter size??? #9
I would think the 7040 will have plenty of HP to use either implement. The question is whether or not the 7040 has enough weight on the front end to keep it from getting light. The 7040 has enough HP to use a 10-ft pull type rotary cutter as long as the material is not TOO thick or overgrown. :thumbsup:
/ M7040 Disk and cutter size??? #10
The M7040 should handle your requirements without a problem. Be sure to get filled R1 tires and/or cast rims.
I only have an 8' tandem disc and a 6' mower but the M7040 handles them like they aren't there.
The front can get pretty light when the rears dig in so a FEL or front weights are advised.
/ M7040 Disk and cutter size??? #11
I run mine with the loader on and if need be I can always stop and add rocks for additional ballast. No shortage of them around here!
I have considered getting a front weight set for some of the field work to save wear on the loader and improve visability.
The 7040 will be 4wd with cast wheels, filled tires and mayb a couple wheel weights if needed. It will have a loader but wont be on it most of the time because of the length it adds to the tractor.
/ M7040 Disk and cutter size??? #13
With the QA for the bucket it is easy to drop the bucket and not be too concerned about the added length. Not sure if a weight set will fit on the front with a FEL however. Sounds like you have things figured out anyway.
A set of forks for the QA will likely find many uses.
/ M7040 Disk and cutter size??? #14
My 7040 has the cast wheels, loaded R1's, and bolt on wheel weights. The rear is ballasted well but the front gets light unless the loader is on, when using some of our larger mounted equipment.
I typically have to add more rear weight to lift anywhere near the loaders upper load limit. (usually just mount the 6' tiller to the 3pt)
/ M7040 Disk and cutter size??? #15
From all I've seen the front weight set will not fit with the FEL mounted.
/ M7040 Disk and cutter size??? #16
I haven't tried it, but when we bought our M8540, we were told the weights would not work with the FEL. I may have my son fab something up to add a little weight if needed. We use a pull type cutter, so the weight has not been an issue so far.
2022 East Manufacturing 48ft. T/A Walking Floor Trailer (A64556)
2022 East...
2015 Chevrolet Tahoe SUV. (A64557)
2015 Chevrolet...
(1) 235/80R16 TIRE W/ (8) LUG WHEEL (A64280)
(1) 235/80R16 TIRE...
2018 Toyota Camry Sedan (A64557)
2018 Toyota Camry...
2025 IREV Electric Scooter (A64194)
2025 IREV Electric...
2016 Chevrolet Silverado 3500 Auto Crane Service Crane Truck (A64194)
2016 Chevrolet...
