My (hopefully not ill advised) foray to the dark side...
   / My (hopefully not ill advised) foray to the dark side... #1
284 International
International Harvester 284
(This post may be misplaced, but since I have put spent so much time on the Yanmar board, it feels like home. I apologize if this is too chatty post, and will delete it if asked.)
I made a journey to the dark side, and have gotten bit.
Since the school I work for is on spring break, I've had the week off. Since it's been rainy here, and I'm too much of a wimp to work outside in the rain, I dithered around inside, watching movies, surfing the web, and reading the paper. I happened onto a deal too tempting to pass up looking at, a Kubota B6000 4wd, with a loader, that had been sitting for "several years," but was otherwise described as in good shape, though dirty, running well, with new tires up front etc etc.
The price seemed right enough to not let pass, just on principle, really, so I told the older woman that I'd take it out of her horse barn. That involved about an hour's worth of crawling around in horse muck, trying to winch it out with a come-along around a 90 degree corner, with 2 flat tires and the loader down.
Eventually I got it to where I could reach it with a set of jumper cables, and used the starter motor to hobble it out enough to reach it with a chain. Then I drug it out, and, long story short, the little guy fired up with only a bit of fiddling! Here's my little trophy, after I got it home and rolled off the trailer, but before a bath:
About 20 years of straw, mice nests, horse urine and who knows what else had covered EVERYTHING with an 1/8 inch coat of grime. It smelled really, really bad. After a few minutes carefully pressure washing things, it.....STILL smelled really bad. But there wasn't as much grime on it, so that was nice. I went to fill up the tires, and discovered that the (otherwise brand new) front tire on the right side had a finger sized hole through it. The tire shop nearby was closed, so I got to change the tractor tire and patch it with a boot and inner tube....using my tire irons from my dirt bike's tool pouch. Ugh.
The worst part about that was I happened to put the tire on backwards. I said that was too bad, I'm not changing it for awhile!:laughing: Oops.
This thing is TINY. I had thought my 1401D was little. Then I got this thing. It's almost the size of a toy, literally. It makes the 1401D look massive and beastly. It's pretty funny. I'm pretty cramped on my 1401D, and it is hard to mount and dismount. The B6000 is easier to board, actually, since I can nearly stand up straddling the thing, and no more cramped except on the foot throttle.
It's a lot smaller in all dimensions, but the overall length is maybe the biggest difference. It's perhaps an entire foot shorter: In this picture the loader buckets are level with one another.
(Sharp eyes will catch the reversed front tire, and missing wheel weight.)
The machine has wheel weights on all 4 tires. I weighed the one I took off on my scale, and it's 42 lbs. I haven't pulled the rear one off yet, but it's got to weigh 3 times that, I would guess. It's none too much: Even with the weights, and tires filled with horse urine and some water, with the bucket lifted the rear is pretty light without an implement.
It came with a cute, 36 inch rollover Gannon-brand box scraper. I'd never used one before, but it's pretty nifty. I like the way the rippers can be used to loosen soil without scooping it or dragging it around.
The B6000 is kind of an oddball. It has a reverse rotating PTO, small diameter, many splined PTO. (I think this one used to have the reverser mounted, but it's missing now, though it's got the spline adapter to take the shaft to a 6 spline, conventional PTO shaft) Perplexingly to me, this one has an electric fuel pump, but an old-school oil bath air filter. It seems a bizarre combination of simplicity and complexity.
Based on this tractor alone, for the life of me I can't figure out why Kubota came to dominate the compact market. The oil dipstick is literally impossible for me to reach. I cannot do it without a pair of long needle nosed pliers, for instance. It's not a bad machine. The little 2 cylinder engine is a gem. It's smooth, quiet, and torquey. The glowplugs in conjunction with a compression release is better than my Yanmars with their non-operational Thermostarts and compression release. But the radiator cap is nearly inaccessible, and you can't see down into the radiator to check the fluid. The hood has to come off. Things like that, and the oil dipstick, seem foolishly engineered. These items will NOT be checked daily, since they are so difficult to access.
Now, the bad part, and where I got suckered for my money: There's something wrong with the right front knuckle. It is connected and doesn't grind. It will pull. But it has a lot of play and wobble in camber, much more than the other side. I need to do some research and investigate what the internals of the knuckle look like. I wish she had been honest with me about the issue. I couldn't see it when limping it out because of the flat and unseated beads on the tire. I kind of feel cheated, but I hope I can tune this little machine up a bit, and turn it over without taking too big a hit. Here's a final shot of my 1401D and this B6000.
   / My (hopefully not ill advised) foray to the dark side... #2
i guess it depends on what was paid and what its really worth in a reasonable condition when up for sale,also what it is going to cost to get it there.maybe just dont over-capitalise on it and it should make a good return.
Neat1500, you're right, of course. I don't know how hard or expensive it will be to fix that knuckle. I'm positive the seller knew about it, and didn't tell me. Buyer beware, used equipment, etc, I know, I just am bothered by it. It's a cute little tractor, but it was misrepresented, and I shouldn't have had good faith. Oh well. Live and learn. I'm not complaining (yet) I just wish this had been disclosed.
   / My (hopefully not ill advised) foray to the dark side... #4
Just like my YM14s problems.i was told it was a great running unit,when i recieved it(bought site unseen from interstate)no regulator,burnt and worn thru wiring,mowing deck not operational,seat shredded,dead as dead battery,rotted tyres....should i go on:( so dont feel so bad.
Sounds as if you had it worse than me...I'm sorry.
   / My (hopefully not ill advised) foray to the dark side... #7
This old lady may not have know about the knucke. It could have been her deceased husbands tractor or something.
No, it was her tractor for mucking out horse stalls. She was the horse person; her husband, apparently, wasn't. It was her tractor that she used, I was told, until she couldn't climb on and off the horses and tractor. I suppose she may not have known about it anyway, but some of the comments she made when I was talking about dragging it onto the trailer with my come-along ("I wouldn't want the wheels to break off...") or slowly backing out, dragging it with the pickup ("I hope that front rim doesn't get wrecked.") make me think otherwise. Oh well. Done is done. I wasn't suspicious at the time, it just seemed odd. It's only with hindsight and doing my due diligence on inspection that it seems that way. It's too late to cry about it, I just need to get it fixed.
It appears these tractors have a kingpin at the top and bottom of the knuckle, in a bushing. I hope the top bushing is worn, giving it the slop. It should be the cheapest and easiest fix, relatively speaking. If the kingpin is broken, or, worse, the housing cracked, I may have an extended thread in the Kubota forum about my repairs!
   / My (hopefully not ill advised) foray to the dark side... #9
Oh yea she knew. She was saying that so that when and if you called her she could say that she warned you about it when you were pulling it so hard.
Clemson, that was pretty much my conclusion after I got home and saw it all. She was concerned about ruining the front tire and stuff, etc. I still would have taken it, probably, I'm just bothered that I was, I feel, misled, even deceived. I always tell my students that "people are people, everywhere, they always have been and always will be." I guess I should take my own advice, and not just assume a grandma would tell me everything she knew about a damaged machine. :(
   / My (hopefully not ill advised) foray to the dark side... #11
Now that is a small tractor the 4wd, loader and wheel weights makes it worthy in my book!
Heck its got to need something from the looks of it and I bet it put out for all it was worth for a little guy!
So hopefully you can make some money and make some garden nut happy that thing is almost cute nah handy is better description! :thumbsup:
Car Doc, you pretty much said my exact thoughts. This is as cute a little tractor as I've ever seen, I really like the way it sits. It seems to be all tire and engine. Never mind that they're tiny, it's a tough little machine. If it ever stops raining long enough to do any work today, I'm going to pull the knuckle apart and see what's going on inside.
It really is cute, though. It will fit through a reasonably large doorway, or virtually any gate. It probably won't do the work of the 1401D, but it will beat the dickens out of a wheelbarrow and shovel, and is nearly as small! :laughing: Hopefully somebody will want it once it's moderately fixed up.
   / My (hopefully not ill advised) foray to the dark side... #13
That fact it will get thru a gate will go a long ways getting it sold and being so low it will fit under stuff is nice also!
I remember a guy I knew a long time back wanted a basement under his A- frame cabin and hired a company that had really small skid steers and they just drove under it and dug it all out for him this little guy reminds me of that.
   / My (hopefully not ill advised) foray to the dark side... #14
Front axles on 4wd tractors tend to do the larger portion of the work, even though they are the weaker of the two axles. I would remove the front weights, because the tractor has a loader for front ballast. When you need additional weight, fill the bucket half full of dirt. These were my thoughts before I read that there were front axle issues.
   / My (hopefully not ill advised) foray to the dark side... #15
Reminds me of the days we were little boys trying to ride our Tonka Trucks,
shoveling in the sand with the hand operated loader bucket :thumbsup:
Not much has changed since then, only now we have real running engines to take place of our verumm verumm engine sounds we used to make:D
I've been working on fixing up a little yard tractor, and for some reason I am just about as proud of it as I am my Ym 1700;) in fact I even painted it Red:D if I had a chance at scoring a SCUT like that kubota I'd sure grab it up,
   / My (hopefully not ill advised) foray to the dark side... #16
Heck Kubota isn't the Dark Side. I saw that and thought you bought a Russian tractor or something. Maybe even Chinese :D although I couldn't imagine you doing that.
Nothing wrong with a Kubota. They are equal competitors to Yanmar regarding build quality. They just have a different marketing model, top-down from Authorized Dealers, instead of common knowledge shared among DIY Yanmar owners on here. In fact TBN was founded by Kubota owners who wanted to talk to one another. The only difference is I think nearly all of them bought new, instead of 30 years old like us. Enjoy that thing after you get it sorted out!
Long ago, 1974, I rented a tiny 4x4 Kubota one weekend then a tiny 2x4 Yanmar the next weekend to finish the project. (I cut a steep suburban backyard into flat terraces because it was too steep to mow). The 2x4 Yanmar must have been ballasted better or something. I clearly felt it outworked the 4x4 Kubota and they were the same size. I loosened nearly dry dirt with rear rippers and scraper, then carried the waste dirt a couple hundred feet with the loader. Both tractors went through the garden gate so they must have been as small as yours. Hard working, just at miniature scale.
Deepndirt, you and I think alike. This really is a step up from my Tonka skiploader. I wish I could find an absurdly cheaply priced Yanmar crawler dumper tractor to play with too!
California, I remember reading you relating that story before, but I don't recall where. I'm going to be impressed with this little guy, and may have a tough time letting it go. I've noticed that, as you said, the Kubota crew isn't as into DIY stuff as the Yanmar side of things are. Their advice centers around "Find a good dealer..." My inclination is to find a set of diagrams, then rip it all apart myself and see if I can fix it. This thing is older than I am, I'm sure, so any mechanic at a dealership isn't going to have much experience with them anyway. Yanmar people, it seems, tend to work on things themselves first, then call professionals in to attempt to clean up the mess....
I wanted to share the little bit I saw about this thing, though. It's the first Kubota I've ever messed with, and, as I said, some things are very well designed, and others are very poor. I don't see anything here to justify their rise to dominance in the marketplace compared to my Yanmars or the Mitsubishi the girlfriend got. Perhaps the others are different. I"m not trying to start a war, I just found it interesting and wanted to share.
   / My (hopefully not ill advised) foray to the dark side... #18
whats the HP on that thing, or did i miss it?
   / My (hopefully not ill advised) foray to the dark side... #19
The TBN is by far the best and most informative " Tractor website " on the net, but before I joined up here I used to be a member of another website,
You see! I too was an orange tractor owner, I had an L-series 140 it was a CUT 1 cyl. diesel that I restored, No one could ever tell me the year make, the person whom I purchased it fro 12-13 years ago told me he thought it was a '49 but ran like a new one and could hold its own for its size and age:thumbsup: It is when I got a FEL to install onto it and soon realize the loader was much too large for that tractor, Rather than getting a smaller FEL I chose to get a larger tractor,;) and is now where I am today with my My-1700, I wish I could have afford to hold onto the Ol-bota. quite a lot of seat time on that little dude, but I really had no use for 2 tractor's on my size property,
If you cannot find info you need here on TBN, go check these folks out, They are into restoring older Kubota's and might could be of some help locating used parts:thumbsup:
OrangeTractorTalks - Everything Kubota - Powered by vBulletin
incidentally here is a photo of my old L-140
Clemson, 11hp at the PTO is what the plate said.
DeepnDirt, that's a nice looking machine! How did it work for you, was the single cylinder rough, or loud? I'll check out that other forum. Thanks for the lead.
Adams 5 Ton Spreader (A56438)
Adams 5 Ton...
SKID MOUNTED CONTAINMENT (A58214)
SKID MOUNTED...
2013 Godwin Dri-Prime CD103M Towable Trash Pump (A59228)
2013 Godwin...
2016 ISUZU NPRXD 14' BOX TRUCK (A60430)
2016 ISUZU NPRXD...
2000 ITASCA SUNCRUISER 37G CLASS A RV (A58214)
2000 ITASCA...
VOGELE VISION 5103-2 ASPHALT PAVER (A60429)
VOGELE VISION...
