Re-fills: Is there an easier way than two 5-gal diesel jugs??
/ Re-fills: Is there an easier way than two 5-gal diesel jugs?? #61
As well, watch for the plastic tightening ring that it doesn't develop a crack from being put on real tight. I had that happen and it 'leaked'. Puzzled me for a bit before I realized that that ring was cracked. I just snug them down now. So easy to grab the spout and add some extra torque when tightening after filling the can.
/ Re-fills: Is there an easier way than two 5-gal diesel jugs?? #62
Here's my solution: two 55 gallon drums, one on the stand, the other goes to town in my truck for filling. Then it's lifted with the clamp-on forks on the FEL of the Kubota, high enough to gravity feed/fill the drum on the stand. The nozzle, hose and water separator/fuel filter all from TSC for about $100. Gravity feed for the tractor, RTV, truck, and the 10kw Kubota genset in the shed. The 2nd drum gets refilled on the next trip to town, thus there are 110 gallons on hand, which is enough to run the generator 24/7 for over 3 weeks. Normal usage (only when the utility power is down, about 4 hours/day=18 weeks.) A stabilizer is added to prevent algae growth.
/ Re-fills: Is there an easier way than two 5-gal diesel jugs?? #63
The person(s) responsible for the new and improved EPA fuel cans should have their own private h--l. They should be forced to spend the rest of eternity filling an endless line of equipment with their cans/spouts. I like the golf tee vent hole upgrade.
/ Re-fills: Is there an easier way than two 5-gal diesel jugs?? #64
i bought this can by pure luck, but i'm happy i did. i used to just use whatever cans i had empty to get diesel when i needed it. needless to say, it was a confusing mess to determine whether i needed to get gas, diesel, or k1. i got this at home depot several years ago, and i'm sure they sell a different style by now, but i think this is the perfect can for filling a tractor - assuming your tractor has the tank on top of the hood?
C.A.R.B Compliant Plastic Fuel Can - 5 Gallon Diesel - Mfg# 05898
the trick with this is NOT to have any vent holes. if you do, you WILL spill fuel. with this can you are required to lift 5 gallons up to the top of the hood, but that's it. you don't have to hold in any awkward position, you just insert the spout into the tank and then stabilize the can (zero effort) gravity does the rest. the neck on the can has a spring loaded nozzle that opens ONLY when you have the weight of the can resting on the fuel opening. since the only venting is accomplished through the filler, once the tank level reaches the spout, the fuel stops flowing because it can no longer draw air. once the fuel flow stops, take the can off. the spring loaded nozzle automatically shuts off, so there is no fuel spilled, even when the can is upside down.
the only downside i can see if that some newer tractors have huge fuel fill openings. if that is the case, you could always have an adapter made to set over the opening so that the spout can shoulder on and allow it to open correctly. i will say that i have seen people try to misuse these cans a lot. i watched someone try to fill a tractor and they were lifting the can with one hand, then trying to pull back the spring loaded nozzle with the other hand, then try to pour the can into the fuel tank. if you have a top mounted tank on your tractor, these things are the greatest thing since sliced bread.
/ Re-fills: Is there an easier way than two 5-gal diesel jugs?? #65
I think the whole point of the thread is not to have to lift and hold 5 gallons cans of diesel on top of your tractor and stand there thinking about how much you despise that glug glug sound coming from that heavy, slow draining, plastic container you're holding.
You're suggesting exactly what this thread is railing against. :)
Ian
/ Re-fills: Is there an easier way than two 5-gal diesel jugs?? #66
Ian
true to a point, but i was also commenting on all the people talking about the new cans and spouts. the ones i use require no holding of the can or pouring, and rarely do i have any spill at all. many in this thread have trouble with cans, and this style may be a better alternative at a practical cost for them, and it works well if you learn how to use it.
otherwise we've got a lot more information needed. how much will they be willing to spend? do they care if it is legal? is there any electricity? can a small roll around tank be used on the terrain there? the list goes on and on. given the choice, i'd opt for the big outdoor tank with electric pump. i'm sure you can get one installed for a couple thousand dollars, but probably not practical to replace a pair of 5 gallon jugs.
/ Re-fills: Is there an easier way than two 5-gal diesel jugs?? #67
Ok! I must have missed something! :confused: When did the color yellow become the designated color for diesel? I always thought it was Green. I'm getting ready to paint my fuel storage system so which is it! :confused2: All of the stations around here and other places I travel have green hoses for diesel and my plant has green tanks for diesel.
All the "diesel" cans I see in stores are yellow.
/ Re-fills: Is there an easier way than two 5-gal diesel jugs?? #70
My curiosity got to me so I called DOT. The official color desination nation wide is
DRUUUUMMMMM ROOOLL! GREEN!
I don't know who or why someone came up with yellow containers but who ever it was they forgot to tell the man at the top. I asked them about it and they have no ideal!:confused:.
/ Re-fills: Is there an easier way than two 5-gal diesel jugs?? #71
I agree
/ Re-fills: Is there an easier way than two 5-gal diesel jugs?? #72
I believe your source was wrong. I have NEVER seen a green can of any sort. All my research leads me to believe that yellow is indeed the correct color.
Diesel Fuel Container Regulations | eHow.com
Diesel Fuel Can Color? - Page 2 - Toyota FJ Cruiser Forum
California law says yellow too: http://www.arb.ca.gov/regact/pfc/2005/cp501.pdf
From this: Gulf Supply Co., Inc. — Fuel Containers
Eagle 5 Gallon Yellow Safety Diesel Can meets OSHA and NFPA Code 30 requirements and are UL and ULC listed and are FM Factory Mutual approved for the safe handling and storage of diesel fuel and other flammable liquids.
From my research NFPA and OSHA care about can colors, but not DOT. DOT cares about fuel caps, pump handles, etc.
Try this: Google for "Green Diesel can" (with the quotes) and see how many you find. I could not find any. My guess is that there is no such critter.
It would seem pretty strange that all the stores got the color wrong ... but then a whole bunch of "smart" people kept believing Bernie Madoff, too :)
/ Re-fills: Is there an easier way than two 5-gal diesel jugs?? #74
The 5k gallon diesel tank at our dealership is yellow
Gas is red
/ Re-fills: Is there an easier way than two 5-gal diesel jugs?? #75
A green fuel can in the woods? Reminds me of the green camouflage utility knives at Lowe's, I can't keep track of bright orange ones.:laughing:
Diesel fuel pumps are green, the natural color of diesel. Diesel fuel cans are yellow. Construction equipment is yellow.
The C.A.R.B cans take more than twice as long to empty. Try fueling a T250 Bobcat every day. 44 gallons of glugging. The clown(s) who devised the cans do not use them. Wait till the spring loaded slide slips off the fill neck of the tank and pinches your fingers. It hurts every time. Machines with fill necks on the sides (T250 etc.)require steady pressure on the fuel spout.
When is an engineer going to make something/anything easier or more cost effective?:confused:Where did the Deere Con/Bit. booth get to?
/ Re-fills: Is there an easier way than two 5-gal diesel jugs?? #76
The one truth is Gas is always red....
I actually store my diesel in Blue containers (kerosene) since half the year, its mostly K1 mix anyways. Yellow is referenced in the ATSM standard but I have also seen Green for diesel.
I just make sure to clearly label it just as I do my mixed fuel jugs. I put yellow taped stripes on any mixed gas for two cycle.
It seems like gasoline is the only one that is followed with religious zeal!
/ Re-fills: Is there an easier way than two 5-gal diesel jugs?? #77
This is where I got my info. Home | U.S. Department of Transportation I called the hot line and the man referred me to his supervisor who said that Green is the official color designator for diesel. Who can you trust if you can't trust your GOVERNMENT!!!! LOL:laughing:. I am just getting ready to paint a new fuel system that will be transported over dot controlled roads during hay season and want to make sure I am within the law; I am not disagreeing with you but just reporting what I have found out! I will do more research and in fact I will be able to ask several guys this week end that should know cause I will be cooking for one of Washington痴 DOT interoffice function! The state patrol and the weigh scalars will be there! I will report back what I find out.
Apparently they can even be chrome! :thumbsup:
2290d1297623043-bumper-bracket-repair-dump-truck-using-longevity-machines-custom-big-rig_cw9h.jpg
/ Re-fills: Is there an easier way than two 5-gal diesel jugs?? #79
Ok here goes with what I found out. This gets hilarious. :laughing:
I called the people :D that should know the answers and they did not have a clue!
1.It seems that tractor owners know more than the government and the people that or responsible for enforcing the laws. Score one for you guys.:thumbsup:
2.The DOT is more interested in pump handles color- diesel is green.
3.OSHA and Nfpa are interested in tank color. diesel is yellow
4.When I called the national DOT office they said green is for diesel. Tanks, handles and hose.
5.When I called Wa. state patrol they thought I was nuts, did not understand what I was asking until I drew them a picture, and still did not have a answer. They suggested I call the weigh station.
6.When I called the weigh station on I5, just north of Vancouver, Wa. They needed me to also draw them a picture, They finally told me it had to be an approved container for the fuel I was transporting. I asked them what constituted an approved container for diesel and they could not give me an answer. At this time I thanked them and got out of dodge cause the officer:mad: was beginning to smoke a little from under his hat.
7.I was raised in south Texas and all of the diesel tanks at that time were green and gas was red. I moved to south west Washington 30 years ago and all of the diesel tanks around the mill I worked at and in the logging camps had a lot of green diesel tanks. So I assumed that Green was a diesel designation. So since the fine officer that are enforcing these laws on us the public do not really know or understand what color is for diesel, I will paint my tank whatever color I want. :tractor: Kubota ORANGE!
I :dance1:have had more fun and have laughed more in the last hour than in a long time. It was better than watching a Laurel and hardy film. When I get my tank done I will post a picture of it so we can stay on topic! I have learned and had fun doing it Thanks Guys!
/ Re-fills: Is there an easier way than two 5-gal diesel jugs?? #80
I have back troubles so I can't hold the cans. I concocted a gravity fed holder to store my gas cans. I used an old refrigerator (with air holes drilled into the carcase) to store the gasoline for the three mowers I have. I use two 5 gal red cans for the gas. I bought a device which looks and works like a gas pump. It had a plastic hose (since replaced with 5 ft of rubber hose) and the pump handle. Since the refrigerator is stored outside I don't worry about having a fire; also since the refrigerator was designed with insulation, it helps keep the fuel cool -even when its 115 degrees:thumbsup:. I only have one can for the diesel fuel, but I know I will need another. My tractor (CaseIH DX24e) has a 5 gal tank (I think) but it burns a lot when I'm using it.
If the color for the containers is supposed to be GREEN :D, then I'll spray paint the container with Green plastic paint, which is very inexpensive. I really don't like the new design on the diesel cans since it always goes glug, glug, urp.:confused2:
2006 Ford F-750 Fuel and Lube Truck (A59230)
2006 Ford F-750...
2014 Caterpillar 257D Compact Track Loader Skid Steer (A59228)
2014 Caterpillar...
Case Axial-Flow Combine Wheels NO RESERVE (A61307)
Case Axial-Flow...
MINI KID DIRT BIKE (A56859)
MINI KID DIRT BIKE...
2013 Chevrolet Silverado 1500 Crew Cab Pickup Truck (A59230)
2013 Chevrolet...
1994 Fontaine 45ft. 40 Ton T/A Flatbed Trailer (A59230)
1994 Fontaine...
