Re-fills: Is there an easier way than two 5-gal diesel jugs??
   / Re-fills: Is there an easier way than two 5-gal diesel jugs??
Mark
Nice pic. But any description?
Looks like a hand squeeze pump in the nozzle. And a small hose.
Yeah, is that gravity-feed?
Edit: I see ... I guess you stand it up for a gravity-feed situation?
   / Re-fills: Is there an easier way than two 5-gal diesel jugs?? #12
Getting pricy now.
GAS CADDY
A portable fuel system that holds up to 28 Gallons of fuel, and can be rolled over land and then along a dock to your boat.
The Gas Caddy is easily moved on pneumatic tires which have nylon bearings preventing sparks between bearings and the aluminum axle.
The handle grips and the proper design proportions ensure comfortable, easy balance and maneuverability when full.
Features a vented cap and a 10' long, large diameter UL Listed supply hose that facilitates rapid fuel transfer.
The hose is easily coiled on two brackets and neatly held in place while transporting.
A heavy duty 3/4" bronze ball valve is located at the bottom of the tank.
The 3/4" hose nozzle is spring-loaded to eliminate possible leakage.
Constructed of cross-linked polyethylene with a molded-in baffle to provide strength and durability.
Shown with Optional Manual Pump that transfers fuel easily above the height of the caddy.
The Gas Caddy meets all current USCG standards and meets UN and DOT specifications when used according to instructions for transporting gasoline.
38" H x 18" W x 13" D
Gas Caddy with pump: $469.00 + $55.00 S&H *
Gas Caddy without pump: $340.00 + $40.00 S&H*
*S&H is for the contiguous 48 states only.
   / Re-fills: Is there an easier way than two 5-gal diesel jugs?? #14
I bought a bilge pump for a boat that is a manual big rubber diaphram. It is made in US and the old name is the guzzler . I use it to prime a well pump in the spring and it will suck3/4" inlet and 3/4" outlet
The Bosworth Co - Diaphragm Pumps, Y-Valves & Check Valves
It will lift almost 15' of suction. I have been very impressed for well pump priming.
Craig Clayton
   / Re-fills: Is there an easier way than two 5-gal diesel jugs?? #15
With all the crazies around here, I can tell you - the five-gallon jugs are easier than driving your tractor down to the local store.
Well ... I already drive it 4 miles one-way to my property every time I use it :laughing: ... Unfortunately there are no gas stations anywhere nearby :( or I would just stop right in for a fill-up.
   / Re-fills: Is there an easier way than two 5-gal diesel jugs?? #17
that tractor lifts all the weight for you all the time and you cant lift a 5 gallon fuel tank to feed its hunger!!!:D I still like the loader lift gravity feed method.
   / Re-fills: Is there an easier way than two 5-gal diesel jugs?? #18
Quickly and safely transfer fuel with the patented Flo n' go hand pump. Prevents accidental spills and overfilling. Transfers fluids vertically or horizontally on level surfaces with minimal priming. It's like having your own portable fuel pump for refueling personal watercraft, generators, pumps, engine-driven compressors, log splitters, lawn care products and other outdoor power equipment, ATVs, snow mobiles, vehicles and more. Ideal for campers, hunters and outdoor enthusiasts.
Features + Benefits
Transfers fluids on level surfaces with minimal priming
Works standing vertically or lying horizontally
Finger recesses at base and sturdy handle at top so 2 can easily carry if necessary
Drop-tested with a full load onto 6in. wheels for assured dependability and long service life
Dual bress shutoff valves for spillproof disconnection of hand pump
Vented fill cap
Bolt-on hanger for hose storage
Recessed grooves for easy strapping locations and safer transport
See Feature Highlights
What's Included
(1) Fuel caddy
(1) Flo 'n' go hose assembly
(1) Hose hanger
See Available Accessories
Content Links
33631 Product Manual
Key Specs
Compatible With Gasoline, diesel or kerosene fuels
Tank Size (gal.) 14
Pump Type Flo and go (gravity fed)
Hose Length (ft.) 10
Dimensions L x W x H (in.) 16 1/2 x 12 1/2 x 33 11/16
Material Type Polyethylene
Wheels (qty.) 2
Wheel Type Solid
Manufacturer Warranty 12 months limited parts / No labor
Ship Weight 20.0 lbs
Item# 33631
Brand
Shop for Flo n' go
Duramax 14 Gallon Fuel Caddy, Model# 06792
Order Today and Save $15 Item# 33631
Was $129.99
Sale $114.99
I bought one of these and returned it for a refund as I spilled gas every time I used it. Not a lot, but enough to smell up the garage. The gravity part worked well enough but using the hand squeeze pump is awkward. You need one hand to pump the lever and it gets sore after a gallon or so. You need another to hold the lockout and a third to keep the hose from kinking. The lawnmower worked well, but my snowmobile and my motorcycles were the difficult items. I could have rigged up something to hold it higher, but the dripping spout was the main reason for it's return. 94 octane, no ethanol gas is a one hour drive so I've reverted to several 5 gal. gas cans for the time being. My GC2610TLB doesn't use enough fuel for diesel to be a problem using cans and the pumps are within walking distance.
Too many negative reviews on this for me:
   / Re-fills: Is there an easier way than two 5-gal diesel jugs?? #20
diesel fuel storage I took an old lubster 60 gal pit it on wheels and painted green when its gets low I call the bulk man and he filles here at home farm fuel in mn is no tax that saves me about 50 cents a gal. roll it close to the tractor put the hose in and turn the crank no spill and simple.
Sakai SV505 Vibratory Roller (A53317)
Sakai SV505...
YanMar SV40 Mini Excavator
YanMar SV40 Mini...
Kuhn FC400RG (A60462)
2023 CATERPILLAR 120 MOTORGRADER (A60429)
2023 CATERPILLAR...
excavator trenching bucket- one bucket per lot (A56438)
excavator...
2016 Chevrolet Sonic LS Hatchback (A56859)
2016 Chevrolet...
